thinkgeo.mapsuite.portablecore.geocodegenerator
ThinkGeo.MapSuite.Core.GeoCodeGenerator
This class generates code that recreates any given object.
    • ThinkGeo.MapSuite.Core.GeoCodeGenerator
GeoCodeGenerator()
  • Creates an instance of GeoCodeGenerator.
GeoCodeGenerator(GeoCodeFormatter)
GenerateCode(Object)
  • Generates code that recreates an object.
  • Description:The generated code.
  • sourceObject
    • Description:The object to generate code for.
GenerateCode(Object,String)
  • sourceObject
  • pathFileName
    • Description:The path to save the generated code.
GenerateCode(Object,Stream)
  • sourceObject
  • stream
    • Type:Stream
    • Description:The stream to save the generated code into.
Formatter
  • Gets or sets the Formatter. The Formatter determines what kind of program code will be generated.
thinkgeo.mapsuite.portablecore.geocodegenerator.txt · Last modified: 2017/03/16 21:59 (external edit)
