A
This class represents a canvas that is used to draw geographic shapes. It is intended to be inherited for the implementation of different drawing systems.
B
This class represents an overlay that requesting from Bing Maps Imagery Service.
C
Represents the coordinates of the map center, display in the lower right corner of the map.
Provides data for the ControlPointSelected event.
Use to send data when map's extent is changed.
Use to send data when map's extent is changing.
Use to send data when map's current scale is changed.
Use to send data when map's current scale is changing.
D
Provides data for the DrawingExceptionOverlay event.
Provides data for the DrawnExceptionOverlay event.
E
Provides data for the FeatureEdited event.
This class inherits from InterativeOverlay abstract class. This specified overlay describle the Extent Changing interative process with MapControl using Mouse or Keyborad.
F
Provides data for the FeatureDragged event.
Provides data for the FeatureDragging. event.
Provides data for the FeatureResized. event.
Provides data for the FeatureResizing. event.
Provides data for the FeatureRotated. event.
Provides data for the FeatureRotating. event.
G
This class represents the GoogleMapsOverlay which requests images from Google's image server by its StaticAPI.
I
This class encapsulates the information and simple method for interative actions.
This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad.
This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay.
L
This class represents a group of layers; each layer can be of any layer type.
This class represents the base class of tile which is the element to form tile overlay.
M
Contains important properties and methods of current map object.
Class MapBoxTileOverlay.
This class represents the base class of map controls.
Contains the different map tools as properties and acts as an entrance for setting these map controls.
This class represents the map control.
Represents a marker control on the map.
This class represents an overlay which maintaining markers.
Provides data for the MouseMoved. event.
O
This class represents an overlay that requesting images from OpenStreet Map Service.
This class is the base class of all overlays in this overlay system.
P
This class represents a popup control for placing on the map.
This class represents an overlay to place popups on the map.
R
S
This class represents the base sqlite bitmap tile cache.
T
Represents an overlay that maintains tiles.
Provides data for the TrackEnding. event.
This class inherits from InterativeOverlay abstract class. This specified overlay describle the TrackShape interative process with MapControl using Mouse or Keyborad.
Provides data for the TrackStarted. event.
Provides data for the TrackStarting. event.
Class TransformArguments.
V
Provides data for the VertexAdded. event.
Provides data for the VertexAdding. event.
Provides data for the VertexMoved. event.
Provides data for the VertexMoving. event.
Provides data for the VertexRemoved. event.
Provides data for the VertexRemoving. event.
W
Represents an overlay object that gets map images from the WMS server you specify.
This class represents an WmsOverlay which has MapSuite world map kit server integrated.
Z
Represents the zooming panel in the upper left corner of the map.
C
This enumeration specified the control point type when editing a shape. The deafault value is None
E
I
This enumeration specifies the mode to draw the InterativeOverlay when doing interactive actions with InterativeOverlay.
L
This enum represents the lock mode while drawing layers.
M
Enum MapBoxImageFormat
Enum MapBoxMapId
This class specifies MapView DoubleTap.
O
Represents how the overlay refreshes.
P
T
Represents how the tile overlay snapping.
This enum represents the tile type in the tile overlay.
TrackMode enumeration sets how the map will react to user interaction.
Represents how the overlay transition.
