thinkgeo.mapsuite.androidedition.gpsmarker
ThinkGeo.MapSuite.AndroidEdition.GpsMarker
    • Java.Lang.Object
      • Android.Views.View
        • Android.Widget.ImageView
          • ThinkGeo.MapSuite.AndroidEdition.Marker
            • ThinkGeo.MapSuite.AndroidEdition.GpsMarker
GpsMarker(Context)
  • context
    • Type:Context
Dispose()
SetImageState(Int32[],Boolean)
  • state
    • Type:Int32[]
  • merge
SetImageURI(Uri)
  • uri
    • Type:Uri
SetMaxHeight(Int32)
  • maxHeight
SetMaxWidth(Int32)
  • maxWidth
SetScaleType(ScaleType)
  • scaleType
    • Type:ScaleType
ClearColorFilter()
GetScaleType()
  • Type:ScaleType
OnCreateDrawableState(Int32)
  • Type:Int32[]
  • extraSpace
SetAdjustViewBounds(Boolean)
  • adjustViewBounds
SetAlpha(Int32)
  • alpha
SetBaseline(Int32)
  • baseline
SetColorFilter(ColorFilter)
  • cf
    • Type:ColorFilter
SetColorFilter(Color)
  • color
    • Type:Color
SetColorFilter(Color,Mode)
  • color
    • Type:Color
  • mode
    • Type:Mode
SetImageBitmap(Bitmap)
  • bm
    • Type:Bitmap
SetImageDrawable(Drawable)
  • drawable
    • Type:Drawable
SetImageLevel(Int32)
  • level
SetImageResource(Int32)
  • resId
SetOnApplyWindowInsetsListener(IOnApplyWindowInsetsListener)
  • listener
    • Type:IOnApplyWindowInsetsListener
SetOnClickListener(IOnClickListener)
  • l
    • Type:IOnClickListener
SetOnCreateContextMenuListener(IOnCreateContextMenuListener)
  • l
    • Type:IOnCreateContextMenuListener
SetOnDragListener(IOnDragListener)
  • l
    • Type:IOnDragListener
SetOnGenericMotionListener(IOnGenericMotionListener)
  • l
    • Type:IOnGenericMotionListener
SetOnHoverListener(IOnHoverListener)
  • l
    • Type:IOnHoverListener
SetOnKeyListener(IOnKeyListener)
  • l
    • Type:IOnKeyListener
SetOnLongClickListener(IOnLongClickListener)
  • l
    • Type:IOnLongClickListener
SetOnSystemUiVisibilityChangeListener(IOnSystemUiVisibilityChangeListener)
  • l
    • Type:IOnSystemUiVisibilityChangeListener
SetOnTouchListener(IOnTouchListener)
  • l
    • Type:IOnTouchListener
SetPadding(Int32,Int32,Int32,Int32)
  • left
  • top
  • right
  • bottom
SetPaddingRelative(Int32,Int32,Int32,Int32)
  • start
  • top
  • end
  • bottom
SetScrollContainer(Boolean)
  • isScrollContainer
SetTag(Int32,Object)
  • key
  • tag
SetWillNotCacheDrawing(Boolean)
  • willNotCacheDrawing
SetWillNotDraw(Boolean)
  • willNotDraw
SetX(Single)
  • x
    • Type:Single
SetY(Single)
  • y
    • Type:Single
SetZ(Single)
  • z
    • Type:Single
ShowContextMenu()
StartActionMode(ICallback)
  • Type:ActionMode
  • callback
    • Type:ICallback
StartAnimation(Animation)
  • animation
    • Type:Animation
StartDrag(ClipData,DragShadowBuilder,Object,Int32)
  • data
    • Type:ClipData
  • shadowBuilder
    • Type:DragShadowBuilder
  • myLocalState
  • flags
StartNestedScroll(ScrollAxis)
  • axes
    • Type:ScrollAxis
StopNestedScroll()
UnscheduleDrawable(Drawable)
  • who
    • Type:Drawable
UnscheduleDrawable(Drawable,IRunnable)
  • who
    • Type:Drawable
  • what
    • Type:IRunnable
WillNotCacheDrawing()
WillNotDraw()
PostOnAnimationDelayed(IRunnable,Int64)
  • action
    • Type:IRunnable
  • delayMillis
    • Type:Int64
RefreshDrawableState()
RemoveCallbacks(IRunnable)
  • action
    • Type:IRunnable
RemoveOnAttachStateChangeListener(IOnAttachStateChangeListener)
  • listener
    • Type:IOnAttachStateChangeListener
RemoveOnLayoutChangeListener(IOnLayoutChangeListener)
  • listener
    • Type:IOnLayoutChangeListener
RequestApplyInsets()
RequestFitSystemWindows()
RequestFocus()
RequestFocus(FocusSearchDirection)
  • direction
    • Type:FocusSearchDirection
RequestFocus(FocusSearchDirection,Rect)
  • direction
  • previouslyFocusedRect
    • Type:Rect
RequestFocusFromTouch()
RequestLayout()
RequestRectangleOnScreen(Rect)
  • rectangle
    • Type:Rect
RequestRectangleOnScreen(Rect,Boolean)
  • rectangle
    • Type:Rect
  • immediate
RequestUnbufferedDispatch(MotionEvent)
  • e
    • Type:MotionEvent
RestoreHierarchyState(SparseArray)
  • container
    • Type:SparseArray
SaveHierarchyState(SparseArray)
  • container
    • Type:SparseArray
ScheduleDrawable(Drawable,IRunnable,Int64)
  • who
    • Type:Drawable
  • what
    • Type:IRunnable
  • when
    • Type:Int64
ScrollBy(Int32,Int32)
  • x
  • y
ScrollTo(Int32,Int32)
  • x
  • y
SendAccessibilityEvent(EventTypes)
  • eventType
    • Type:EventTypes
SendAccessibilityEventUnchecked(AccessibilityEvent)
  • e
    • Type:AccessibilityEvent
SetAccessibilityDelegate(AccessibilityDelegate)
  • delegate
    • Type:AccessibilityDelegate
SetBackgroundColor(Color)
  • color
    • Type:Color
SetBackgroundDrawable(Drawable)
  • background
    • Type:Drawable
SetBackgroundResource(Int32)
  • resid
SetCameraDistance(Single)
  • distance
    • Type:Single
SetFadingEdgeLength(Int32)
  • length
SetFitsSystemWindows(Boolean)
  • fitSystemWindows
SetLayerPaint(Paint)
  • paint
    • Type:Paint
SetLayerType(LayerType,Paint)
  • layerType
    • Type:LayerType
  • paint
    • Type:Paint
SetMinimumHeight(Int32)
  • minHeight
SetMinimumWidth(Int32)
  • minWidth
OnPopulateAccessibilityEvent(AccessibilityEvent)
  • e
OnRtlPropertiesChanged(LayoutDirection)
  • layoutDirection
    • Type:LayoutDirection
OnScreenStateChanged(ScreenState)
  • screenState
    • Type:ScreenState
OnStartTemporaryDetach()
OnTouchEvent(MotionEvent)
  • e
    • Type:MotionEvent
OnTrackballEvent(MotionEvent)
  • e
    • Type:MotionEvent
OnWindowFocusChanged(Boolean)
  • hasWindowFocus
OnWindowSystemUiVisibilityChanged(SystemUiFlags)
  • visible
    • Type:SystemUiFlags
PerformAccessibilityAction(GlobalAction,Bundle)
  • action
    • Type:GlobalAction
  • arguments
    • Type:Bundle
PerformClick()
PerformHapticFeedback(FeedbackConstants)
  • feedbackConstant
    • Type:FeedbackConstants
PerformHapticFeedback(FeedbackConstants,FeedbackFlags)
  • feedbackConstant
  • flags
    • Type:FeedbackFlags
PerformLongClick()
PlaySoundEffect(SoundEffects)
  • soundConstant
    • Type:SoundEffects
Post(IRunnable)
  • action
    • Type:IRunnable
PostDelayed(IRunnable,Int64)
  • action
    • Type:IRunnable
  • delayMillis
    • Type:Int64
PostInvalidate()
PostInvalidate(Int32,Int32,Int32,Int32)
  • left
  • top
  • right
  • bottom
PostInvalidateDelayed(Int64)
  • delayMilliseconds
    • Type:Int64
PostInvalidateDelayed(Int64,Int32,Int32,Int32,Int32)
  • delayMilliseconds
    • Type:Int64
  • left
  • top
  • right
  • bottom
PostInvalidateOnAnimation()
PostInvalidateOnAnimation(Int32,Int32,Int32,Int32)
  • left
  • top
  • right
  • bottom
PostOnAnimation(IRunnable)
  • action
    • Type:IRunnable
OnApplyWindowInsets(WindowInsets)
  • Type:WindowInsets
  • insets
    • Type:WindowInsets
OnCancelPendingInputEvents()
OnCheckIsTextEditor()
OnCreateInputConnection(EditorInfo)
  • Type:IInputConnection
  • outAttrs
    • Type:EditorInfo
OnDragEvent(DragEvent)
  • e
    • Type:DragEvent
OnFilterTouchEventForSecurity(MotionEvent)
  • e
    • Type:MotionEvent
OnFinishTemporaryDetach()
OnGenericMotionEvent(MotionEvent)
  • e
    • Type:MotionEvent
OnHoverChanged(Boolean)
  • hovered
OnHoverEvent(MotionEvent)
  • e
    • Type:MotionEvent
OnInitializeAccessibilityEvent(AccessibilityEvent)
  • e
OnInitializeAccessibilityNodeInfo(AccessibilityNodeInfo)
  • info
    • Type:AccessibilityNodeInfo
OnKeyDown(Keycode,KeyEvent)
  • keyCode
    • Type:Keycode
  • e
    • Type:KeyEvent
OnKeyLongPress(Keycode,KeyEvent)
  • keyCode
    • Type:Keycode
  • e
    • Type:KeyEvent
OnKeyMultiple(Keycode,Int32,KeyEvent)
  • keyCode
    • Type:Keycode
  • repeatCount
  • e
    • Type:KeyEvent
OnKeyPreIme(Keycode,KeyEvent)
  • keyCode
    • Type:Keycode
  • e
    • Type:KeyEvent
OnKeyShortcut(Keycode,KeyEvent)
  • keyCode
    • Type:Keycode
  • e
    • Type:KeyEvent
OnKeyUp(Keycode,KeyEvent)
  • keyCode
    • Type:Keycode
  • e
    • Type:KeyEvent
FindViewsWithText(IList<View>,String,FindViewsWith)
  • outViews
    • Type:IList<View>
  • searched
  • flags
    • Type:FindViewsWith
FindViewWithTag(Object)
  • Type:View
  • tag
InvokeFitsSystemWindows()
FocusSearch(FocusSearchDirection)
  • Type:View
  • direction
ForceLayout()
GetDrawableState()
  • Type:Int32[]
GetDrawingCache(Boolean)
  • Type:Bitmap
  • autoScale
GetDrawingRect(Rect)
  • outRect
    • Type:Rect
GetFocusables(FocusSearchDirection)
  • Type:IList<View>
  • direction
GetFocusedRect(Rect)
  • r
    • Type:Rect
GetGlobalVisibleRect(Rect)
  • r
    • Type:Rect
GetGlobalVisibleRect(Rect,Point)
  • r
    • Type:Rect
  • globalOffset
    • Type:Point
GetHitRect(Rect)
  • outRect
    • Type:Rect
GetLocalVisibleRect(Rect)
  • r
    • Type:Rect
GetLocationInWindow(Int32[])
  • location
    • Type:Int32[]
GetLocationOnScreen(Int32[])
  • location
    • Type:Int32[]
GetTag(Int32)
  • key
GetWindowVisibleDisplayFrame(Rect)
  • outRect
    • Type:Rect
GetX()
  • Type:Single
GetY()
  • Type:Single
GetZ()
  • Type:Single
Invalidate()
Invalidate(Rect)
  • dirty
    • Type:Rect
  • l
  • t
  • r
  • b
InvalidateDrawable(Drawable)
  • drawable
    • Type:Drawable
InvalidateOutline()
JumpDrawablesToCurrentState()
Layout(Int32,Int32,Int32,Int32)
  • l
  • t
  • r
  • b
Measure(Int32,Int32)
  • widthMeasureSpec
  • heightMeasureSpec
OffsetLeftAndRight(Int32)
  • offset
OffsetTopAndBottom(Int32)
  • offset
DispatchDrawableHotspotChanged(Single,Single)
  • x
    • Type:Single
  • y
    • Type:Single
DispatchGenericMotionEvent(MotionEvent)
  • e
    • Type:MotionEvent
DispatchKeyEvent(KeyEvent)
  • e
    • Type:KeyEvent
DispatchKeyEventPreIme(KeyEvent)
  • e
    • Type:KeyEvent
DispatchKeyShortcutEvent(KeyEvent)
  • e
    • Type:KeyEvent
DispatchNestedFling(Single,Single,Boolean)
  • velocityX
    • Type:Single
  • velocityY
    • Type:Single
  • consumed
DispatchNestedPreFling(Single,Single)
  • velocityX
    • Type:Single
  • velocityY
    • Type:Single
DispatchNestedPrePerformAccessibilityAction(Action,Bundle)
  • action
    • Type:Action
  • arguments
    • Type:Bundle
DispatchNestedPreScroll(Int32,Int32,Int32[],Int32[])
  • dx
  • dy
  • consumed
    • Type:Int32[]
  • offsetInWindow
    • Type:Int32[]
DispatchNestedScroll(Int32,Int32,Int32,Int32,Int32[])
  • dxConsumed
  • dyConsumed
  • dxUnconsumed
  • dyUnconsumed
  • offsetInWindow
    • Type:Int32[]
DispatchPopulateAccessibilityEvent(AccessibilityEvent)
  • e
DispatchSystemUiVisibilityChanged(SystemUiFlags)
  • visibility
DispatchTouchEvent(MotionEvent)
  • e
    • Type:MotionEvent
DispatchTrackballEvent(MotionEvent)
  • e
    • Type:MotionEvent
DispatchUnhandledMove(View,FocusSearchDirection)
  • focused
    • Type:View
  • direction
DispatchWindowFocusChanged(Boolean)
  • hasFocus
DispatchWindowSystemUiVisiblityChanged(SystemUiFlags)
  • visible
DispatchWindowVisibilityChanged(ViewStates)
  • visibility
    • Type:ViewStates
Draw(Canvas)
  • canvas
    • Type:Canvas
  • x
    • Type:Single
  • y
    • Type:Single
FindFocus()
  • Type:View
FindViewById(Int32)
  • Type:View
  • id
FindViewsWithText(IList<View>,ICharSequence,FindViewsWith)
  • outViews
    • Type:IList<View>
  • searched
    • Type:ICharSequence
  • flags
BringToFront()
BuildDrawingCache()
BuildDrawingCache(Boolean)
  • autoScale
BuildLayer()
CallOnClick()
CancelLongPress()
CanResolveLayoutDirection()
CanResolveTextAlignment()
CanResolveTextDirection()
CanScrollHorizontally(Int32)
  • direction
CanScrollVertically(Int32)
  • direction
CheckInputConnectionProxy(View)
  • view
    • Type:View
ClearAnimation()
ClearFocus()
ComputeScroll()
ComputeSystemWindowInsets(WindowInsets,Rect)
  • Type:WindowInsets
  • in
    • Type:WindowInsets
  • outLocalInsets
    • Type:Rect
CreateAccessibilityNodeInfo()
CreateContextMenu(IContextMenu)
  • menu
    • Type:IContextMenu
DestroyDrawingCache()
DispatchApplyWindowInsets(WindowInsets)
  • Type:WindowInsets
  • insets
    • Type:WindowInsets
DispatchConfigurationChanged(Configuration)
  • newConfig
    • Type:Configuration
DispatchDisplayHint(ViewStates)
  • hint
    • Type:ViewStates
DispatchDragEvent(DragEvent)
  • e
    • Type:DragEvent
AddChildrenForAccessibility(IList<View>)
  • children
    • Type:IList<View>
AddFocusables(IList<View>,FocusSearchDirection)
  • views
    • Type:IList<View>
  • direction
AddFocusables(IList<View>,FocusSearchDirection,FocusablesFlags)
  • views
    • Type:IList<View>
  • direction
  • focusableMode
    • Type:FocusablesFlags
AddOnAttachStateChangeListener(IOnAttachStateChangeListener)
  • listener
AddOnLayoutChangeListener(IOnLayoutChangeListener)
  • listener
AddTouchables(IList<View>)
  • views
    • Type:IList<View>
Animate()
  • Type:ViewPropertyAnimator
AnnounceForAccessibility(ICharSequence)
  • text
AnnounceForAccessibility(String)
  • text
FindViewById(Int32)
  • Type:T
  • id
Post(Action)
  • action
    • Type:Action
PostDelayed(Action,Int64)
  • action
    • Type:Action
  • delayMillis
    • Type:Int64
RemoveCallbacks(Action)
  • action
    • Type:Action
ScheduleDrawable(Drawable,Action,Int64)
  • who
    • Type:Drawable
  • what
    • Type:Action
  • when
    • Type:Int64
UnscheduleDrawable(Drawable,Action)
  • who
    • Type:Drawable
  • what
    • Type:Action
DispatchSystemUiVisibilityChanged(Int32)
  • visibility
Wait()
Wait(Int64)
  • millis
    • Type:Int64
Wait(Int64,Int32)
  • millis
    • Type:Int64
  • nanos
Dispose()
ToArray()
  • Type:T[]
  • o
Notify()
NotifyAll()
DispatchDraw(Canvas)
  • canvas
    • Type:Canvas
Dispose(Boolean)
  • disposing
InitializeSize()
OnMeasure(Int32,Int32)
  • widthMeasureSpec
  • heightMeasureSpec
SetFrame(Int32,Int32,Int32,Int32)
  • l
  • t
  • r
  • b
VerifyDrawable(Drawable)
  • who
    • Type:Drawable
SetMeasuredDimension(Int32,Int32)
  • measuredWidth
  • measuredHeight
OnOverScrolled(Int32,Int32,Boolean,Boolean)
  • scrollX
  • scrollY
  • clampedX
  • clampedY
OnRestoreInstanceState(IParcelable)
  • state
    • Type:IParcelable
OnSaveInstanceState()
  • Type:IParcelable
OnScrollChanged(Int32,Int32,Int32,Int32)
  • l
  • t
  • oldl
  • oldt
OnSetAlpha(Int32)
  • alpha
OnSizeChanged(Int32,Int32,Int32,Int32)
  • w
  • h
  • oldw
  • oldh
OnVisibilityChanged(View,ViewStates)
  • changedView
    • Type:View
  • visibility
    • Type:ViewStates
OnWindowVisibilityChanged(ViewStates)
  • visibility
    • Type:ViewStates
OverScrollBy(Int32,Int32,Int32,Int32,Int32,Int32,Int32,Int32,Boolean)
  • deltaX
  • deltaY
  • scrollX
  • scrollY
  • scrollRangeX
  • scrollRangeY
  • maxOverScrollX
  • maxOverScrollY
  • isTouchEvent
OnAnimationEnd()
OnAnimationStart()
OnAttachedToWindow()
OnConfigurationChanged(Configuration)
  • newConfig
OnCreateContextMenu(IContextMenu)
  • menu
    • Type:IContextMenu
  • Type:Int32[]
  • extraSpace
OnDetachedFromWindow()
OnDisplayHint(Int32)
  • hint
OnDraw(Canvas)
  • canvas
    • Type:Canvas
OnDrawScrollBars(Canvas)
  • canvas
    • Type:Canvas
OnFinishInflate()
OnFocusChanged(Boolean,FocusSearchDirection,Rect)
  • gainFocus
  • direction
    • Type:Rect
OnLayout(Boolean,Int32,Int32,Int32,Int32)
  • changed
  • left
  • top
  • right
  • bottom
FitSystemWindows(Rect)
  • insets
    • Type:Rect
InitializeFadingEdge(TypedArray)
  • a
    • Type:TypedArray
InitializeScrollbars(TypedArray)
  • a
    • Type:TypedArray
DispatchGenericFocusedEvent(MotionEvent)
  • e
    • Type:MotionEvent
DispatchGenericPointerEvent(MotionEvent)
  • e
    • Type:MotionEvent
DispatchHoverEvent(MotionEvent)
  • e
    • Type:MotionEvent
DispatchRestoreInstanceState(SparseArray)
  • container
    • Type:SparseArray
DispatchSaveInstanceState(SparseArray)
  • container
    • Type:SparseArray
DispatchSetActivated(Boolean)
  • activated
DispatchSetPressed(Boolean)
  • pressed
DispatchSetSelected(Boolean)
  • selected
DispatchVisibilityChanged(View,ViewStates)
  • changedView
    • Type:View
  • visibility
    • Type:ViewStates
DrawableStateChanged()
AwakenScrollBars(Int32,Boolean)
  • startDelay
  • invalidate
ComputeHorizontalScrollExtent()
ComputeHorizontalScrollOffset()
ComputeHorizontalScrollRange()
ComputeVerticalScrollExtent()
ComputeVerticalScrollOffset()
ComputeVerticalScrollRange()
AwakenScrollBars()
AwakenScrollBars(Int32)
  • startDelay
SetHandleOnDeserialized(StreamingContext)
  • context
    • Type:StreamingContext
Dispose(Boolean)
  • disposing
SetHandle(IntPtr,JniHandleOwnership)
  • value
    • Type:IntPtr
  • transfer
    • Type:JniHandleOwnership
Clone()
JavaFinalize()
AccuracyRadius
Position
XOffset
YOffset
AdjustViewBounds
BaselineAlignBottom
ColorFilter
  • Type:ColorFilter
CropToPadding
Drawable
  • Type:Drawable
ImageAlpha
ImageMatrix
  • Type:Matrix
ImageTintList
  • Type:ColorStateList
ImageTintMode
  • Type:Mode
MaxHeight
MaxWidth
AccessibilityLiveRegion
  • Type:AccessibilityLiveRegion
AccessibilityNodeProvider
  • Type:AccessibilityNodeProvider
AccessibilityTraversalAfter
AccessibilityTraversalBefore
Activated
Alpha
  • Type:Single
Animation
  • Type:Animation
ApplicationWindowToken
  • Type:IBinder
Background
  • Type:Drawable
BackgroundTintList
BackgroundTintMode
  • Type:Mode
Baseline
Bottom
CameraDistance
  • Type:Single
Clickable
ClipBounds
  • Type:Rect
ClipToOutline
ContentDescriptionFormatted
ContentDescription
Context
  • Type:Context
Display
  • Type:Display
DrawingCache
  • Type:Bitmap
DrawingCacheBackgroundColor
  • Type:Color
DrawingCacheEnabled
DrawingCacheQuality
  • Type:DrawingCacheQuality
DrawingTime
  • Type:Int64
DuplicateParentStateEnabled
Elevation
  • Type:Single
Enabled
FilterTouchesWhenObscured
FitsSystemWindows
Focusable
FocusableInTouchMode
Handler
  • Type:Handler
HapticFeedbackEnabled
HasFocus
HasFocusable
HasNestedScrollingParent
HasOnClickListeners
HasOverlappingRendering
HasTransientState
HasWindowFocus
Height
HorizontalFadingEdgeEnabled
HorizontalFadingEdgeLength
HorizontalScrollBarEnabled
Hovered
Id
ImportantForAccessibility
  • Type:ImportantForAccessibility
IsAccessibilityFocused
IsAttachedToWindow
IsDirty
IsFocused
IsHardwareAccelerated
IsImportantForAccessibility
IsInEditMode
IsInLayout
IsInTouchMode
IsLaidOut
IsLayoutDirectionResolved
IsLayoutRequested
IsOpaque
IsPaddingRelative
IsScrollContainer
IsShown
IsTextAlignmentResolved
IsTextDirectionResolved
KeepScreenOn
KeyDispatcherState
  • Type:DispatcherState
LabelFor
LayerType
  • Type:LayerType
LayoutDirection
LayoutParameters
  • Type:LayoutParams
Left
LongClickable
Matrix
  • Type:Matrix
MeasuredHeight
MeasuredHeightAndState
MeasuredState
MeasuredWidth
MeasuredWidthAndState
MinimumHeight
MinimumWidth
NestedScrollingEnabled
NextFocusDownId
NextFocusForwardId
NextFocusLeftId
NextFocusRightId
NextFocusUpId
OnFocusChangeListener
  • Type:IOnFocusChangeListener
OutlineProvider
  • Type:ViewOutlineProvider
OverScrollMode
  • Type:OverScrollMode
Overlay
  • Type:ViewOverlay
PaddingBottom
PaddingEnd
PaddingLeft
PaddingRight
PaddingStart
PaddingTop
Parent
  • Type:IViewParent
ParentForAccessibility
  • Type:IViewParent
PivotX
  • Type:Single
PivotY
  • Type:Single
Pressed
Resources
  • Type:Resources
Right
RootView
  • Type:View
Rotation
  • Type:Single
RotationX
  • Type:Single
RotationY
  • Type:Single
SaveEnabled
SaveFromParentEnabled
ScaleX
  • Type:Single
ScaleY
  • Type:Single
ScrollBarDefaultDelayBeforeFade
ScrollBarFadeDuration
ScrollBarSize
ScrollBarStyle
  • Type:ScrollbarStyles
ScrollX
ScrollY
ScrollbarFadingEnabled
Selected
SolidColor
SoundEffectsEnabled
StateListAnimator
  • Type:StateListAnimator
SystemUiVisibility
  • Type:StatusBarVisibility
Tag
TextAlignment
  • Type:TextAlignment
TextDirection
  • Type:TextDirection
Top
TouchDelegate
  • Type:TouchDelegate
Touchables
  • Type:IList<View>
TransitionName
TranslationX
  • Type:Single
TranslationY
  • Type:Single
TranslationZ
  • Type:Single
VerticalFadingEdgeEnabled
VerticalFadingEdgeLength
VerticalScrollBarEnabled
VerticalScrollbarPosition
  • Type:ScrollbarPosition
VerticalScrollbarWidth
ViewTreeObserver
  • Type:ViewTreeObserver
Visibility
  • Type:ViewStates
Width
WindowId
  • Type:WindowId
WindowToken
  • Type:IBinder
WindowVisibility
  • Type:ViewStates
ApplyWindowInsets
  • Type:ApplyWindowInsetsHandler
Handle
  • Type:IntPtr
Class
  • Type:Class
ThresholdClass
  • Type:IntPtr
ThresholdType
BottomFadingEdgeStrength
  • Type:Single
BottomPaddingOffset
ContextMenuInfo
  • Type:IContextMenuContextMenuInfo
HorizontalScrollbarHeight
IsPaddingOffsetRequired
LeftFadingEdgeStrength
  • Type:Single
LeftPaddingOffset
RightFadingEdgeStrength
  • Type:Single
RightPaddingOffset
SuggestedMinimumHeight
SuggestedMinimumWidth
TopFadingEdgeStrength
  • Type:Single
TopPaddingOffset
WindowAttachCount
ViewAttachedToWindow
Event Arguments:ViewAttachedToWindowEventArgs
ViewDetachedFromWindow
Event Arguments:ViewDetachedFromWindowEventArgs
LayoutChange
Event Arguments:LayoutChangeEventArgs
Click
Event Arguments:
ContextMenuCreated
Event Arguments:CreateContextMenuEventArgs
Drag
Event Arguments:DragEventArgs
GenericMotion
Event Arguments:GenericMotionEventArgs
Hover
Event Arguments:HoverEventArgs
KeyPress
Event Arguments:KeyEventArgs
LongClick
Event Arguments:LongClickEventArgs
Event Arguments:SystemUiVisibilityChangeEventArgs
Touch
Event Arguments:TouchEventArgs
FocusChange
Event Arguments:FocusChangeEventArgs
thinkgeo.mapsuite.androidedition.gpsmarker.txt · Last modified: 2017/03/16 21:59 (external edit)
