thinkgeo.mapsuite.portablecore.iconvalueitem
ThinkGeo.MapSuite.Core.IconValueItem
This class is a single item in an IconValueStyle.
    • ThinkGeo.MapSuite.Core.IconValueItem
IconValueItem()
  • This is the constructor for the class.
  • If you use the constructor, then you should set all the properties manually.
IconValueItem(String,String,TextStyle)
  • You would typically use this constructor if you are using an icon that's located on disk. If you need to use an image from a stream instead, there is another overload that takes a GeoImage.
  • fieldValue
    • Description:This parameter is the value you want to match.
  • iconPathFilename
    • Description:This parameter is the path and filename of the image you want to use.
  • textStyle
    • Type:TextStyle
    • Description:This parameter is the TextStyle of how you want the text drawn.
IconValueItem(String,GeoImage,TextStyle)
  • You will typically use this overload if you need to use a stream for the image. If you need to use a file located on disk instead, there is another overload that takes the path and filename to an image.
  • fieldValue
  • iconImage
    • Type:GeoImage
    • Description:This parameter is the GeoImage of the image you want to use.
  • textStyle
    • Type:TextStyle
GetIconImage()
  • This method gets the icon we will draw as a GeoImage.
  • This method is used when drawing to get the image as a GeoImage. We will internally either pass along the GeoImage the user set, or create a GeoImage from the IconFilePathName that was set.
  • Type:GeoImage
  • Description:This method gets the icon we will draw as a GeoImage.
TextStyle
  • This property gets and sets the style that will be used to draw the text in the icon.
  • None
FieldValue
  • This property gets and sets the field value that has to match in the IconValueStyle.
  • For an explanation on how the IconValueStyle works, see the IconValueStyle Class remarks.
IconFilePathName
  • This property gets and sets the path and filename of the icon that will be drawn.
  • If you need to use a GeoImage, you can set the GeoImage in the constructor or use the property.
TextValueLengthMin
  • This property gets and sets the minimum string length for this item to match.
  • This is an important property because it is used to ensure that that a properly sized icon is used to draw things like road signs. For example, you can set the minimum and maximum values so that the sign icon for a single-digit road number uses one icon, while a two-digit road uses another, wider sign icon in a separate IconValueItem.
TextValueLengthMax
  • This property gets and sets the maximum string length for this item to match.
thinkgeo.mapsuite.portablecore.iconvalueitem.txt · Last modified: 2017/03/16 21:59 (external edit)
