thinkgeo.mapsuite.androidedition.interactiveoverlay
ThinkGeo.MapSuite.AndroidEdition.InteractiveOverlay
This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad.
InteractiveOverlay()
  • Default constructor of this abstract class.
TouchUp(InteractionArguments)
  • This method will simulate the TouchUp interaction.
  • This method is the concrete wrapper for its virtual Core method. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • e
TouchDown(InteractionArguments)
  • This method will simulate the TouchDown interaction.
  • e
TouchMove(InteractionArguments)
  • This method will simulate the TouchMove interaction.
  • e
TouchPointerDown(InteractionArguments)
  • This method will simulate the TouchPointerDown interaction.
  • e
SingleTap(InteractionArguments)
  • This method will simulate the SingleTap interaction.
  • e
DoubleTap(InteractionArguments)
  • This method will simulate the DoubleTap interaction.
  • e
LongPress(InteractionArguments)
  • This method will simulate the LongPress interaction.
  • e
Refresh(IEnumerable<RectangleShape>)
Refresh(TimeSpan)
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,RequestDrawingBufferTimeType)
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Refresh(RectangleShape,TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Refresh(IEnumerable<RectangleShape>,TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
GetBoundingBox()
Initialize(MapArguments)
Refresh()
Refresh(RectangleShape)
Draw(MapArguments,OverlayRefreshType)
PostTransform(TransformArguments,MapArguments)
Close()
Open()
Dispose()
InitializeCore(MapArguments)
  • This protected virtual method is the Core method of Initialize API.
  • mapArguments
    • Description:This parameter maintains current map information for calculating mechanism.
DrawCore(MapArguments,OverlayRefreshType)
  • This method draws the InterativeOverlay abstract class. You have to override this API in its sub concrete classes, Or you will see nothing.
  • This method draws the representation of the overlay based on the extent you provided. When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
  • Description:none
  • mapArguments
  • refreshType
    • Description:This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode.
TouchUpCore(InteractionArguments)
  • This protected virtual method is the Core method of TouchUp API.
  • e
TouchDownCore(InteractionArguments)
  • This protected virtual method is the Core method of TouchDown API.
  • e
TouchMoveCore(InteractionArguments)
  • This protected virtual method is the Core method of TouchMove API.
  • e
TouchPointerDownCore(InteractionArguments)
  • This protected virtual method is the Core method of TouchPointerDown API.
  • e
SingleTapCore(InteractionArguments)
  • This protected virtual method is the Core method of SingleTap API.
  • e
DoubleTapCore(InteractionArguments)
  • This protected virtual method is the Core method of MouseDoubleClick API.
  • e
LongPressCore(InteractionArguments)
  • This protected virtual method is the Core method of LongPress API.
  • e
PostTransformCore(TransformArguments,MapArguments)
  • This protected virtual method is the Core method of PostTransform API.
  • transformInfo
    • Description:This parameter maintains the transfrom information for calculating transform.
  • mapArguments
Dispose(Boolean)
  • This method dispose unmanaged resource used in this class.
  • disposing
GetBoundingBoxCore()
RefreshCore()
RefreshCore(RectangleShape)
CloseCore()
OpenCore()
  • exception
    • Type:Exception
  • ex
    • Type:Exception
OnDrawingException(DrawingExceptionOverlayEventArgs)
OnDrawnException(DrawnExceptionOverlayEventArgs)
InteractiveView
  • Gets or sets Overlay's the interactiveView.
AutoRefreshInterval
  • Type:TimeSpan
DrawingExceptionMode
IsEmpty
IsVisible
Attribution
OverlayView
DrawingQuality
Opacity
MapArguments
CanRefreshRegion
DrawingException
Event Arguments:DrawingExceptionOverlayEventArgs
DrawnException
Event Arguments:DrawnExceptionOverlayEventArgs
thinkgeo.mapsuite.androidedition.interactiveoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
