thinkgeo.mapsuite.androidedition.currentextentchangedmapvieweventargs
ThinkGeo.MapSuite.AndroidEdition.CurrentExtentChangedMapViewEventArgs
Use to send data when map's extent is changed.
      • ThinkGeo.MapSuite.AndroidEdition.CurrentExtentChangedMapViewEventArgs
CurrentExtentChangedMapViewEventArgs()
  • Initializes a new instance of the class.
CurrentExtentChangedMapViewEventArgs(RectangleShape,RectangleShape)
OldExtent
  • Gets or sets the old extent.
NewExtent
  • Gets or sets the new extent.
thinkgeo.mapsuite.androidedition.currentextentchangedmapvieweventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
