thinkgeo.mapsuite.androidedition.currentscalechangingmapvieweventargs
ThinkGeo.MapSuite.AndroidEdition.CurrentScaleChangingMapViewEventArgs
Use to send data when map's current scale is changing.
      • ThinkGeo.MapSuite.AndroidEdition.CurrentScaleChangingMapViewEventArgs
CurrentScaleChangingMapViewEventArgs(Double,Double)
  • Initializes a new instance of the class.
  • oldScale
    • Description:The old scale.
  • newScale
    • Description:The new scale.
OldScale
  • Gets or sets the old scale.
NewScale
  • Gets or sets the new scale.
thinkgeo.mapsuite.androidedition.currentscalechangingmapvieweventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
