thinkgeo.mapsuite.androidedition.featuredraggingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.FeatureDraggingEditInteractiveOverlayEventArgs
Provides data for the FeatureDragging. event.
      • ThinkGeo.MapSuite.AndroidEdition.FeatureDraggingEditInteractiveOverlayEventArgs
FeatureDraggingEditInteractiveOverlayEventArgs()
FeatureDraggingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • draggingFeature
    • Type:Feature
    • Description:This parameter specified the target feature to be dragged.
  • cancel
  • sourceControlPoint
    • Description:This parameter specified the source control point to be dragged.
  • targetControlPoint
    • Description:This parameter specified the target control point to be dragged.
DraggingFeature
  • This property gets or sets the Feature to be used to dragged.
SourceControlPoint
  • This property gets or sets the source control point to drag.
TargetControlPoint
  • This property gets or sets the target control point to drag.
Cancel
  • This property gets or sets the action to be canceled or not.
thinkgeo.mapsuite.androidedition.featuredraggingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
