thinkgeo.mapsuite.androidedition.sqlitebitmaptilecache
ThinkGeo.MapSuite.AndroidEdition.SqliteBitmapTileCache
This class represents the base sqlite bitmap tile cache.
    • ThinkGeo.MapSuite.Core.TileCache
      • ThinkGeo.MapSuite.Core.BitmapTileCache
        • ThinkGeo.MapSuite.AndroidEdition.SqliteBitmapTileCache
SqliteBitmapTileCache()
  • Initializes a new instance of the class.
SqliteBitmapTileCache(String,String)
  • databasePathFilename
    • Description:The database path filename.
  • cacheId
    • Description:The cache identifier.
GetTile(RectangleShape)
GetTile(Int64,Int64)
  • row
    • Type:Int64
  • column
    • Type:Int64
GetTiles(RectangleShape)
GetHigherScaleTile(RectangleShape,Double)
  • tileScale
SaveTile(Tile)
  • tile
    • Type:Tile
SaveTiles(GeoImage,RectangleShape)
DeleteTiles(RectangleShape)
DeleteTile(Tile)
  • tile
    • Type:Tile
ClearCache()
GetTileCore(Int64,Int64)
  • This abstract method returns the BitmapTile corresponding to passed in row and column. Each concrete TileCache need to implement this logic to get tile from a row and column.
  • Description:Returns the BitmapTile corresponding to the passed in row and column.
  • row
    • Type:Int64
    • Description:The target row for the tile to fetch.
  • column
    • Type:Int64
    • Description:The target column for the tile to fetch.
ClearCacheCore()
  • This abstract method will clear all the tiles in the tileCache, for each sub TileCache class must implement this method.
  • This method will not take effect when the ReadOnly is set to true.
SaveTileCore(Tile)
  • This abstract method will save the target tile passed in, for each sub TileCache class must implement this method.
  • tile
    • Type:Tile
    • Description:The target tile to be saved.
DeleteTileCore(Tile)
  • This abstract method will delete the target tile passed in, for each sub TileCache class must implement this method.
  • tile
    • Type:Tile
    • Description:The target tile to be deleted.
uhM=(CacheEntity)
GetHigherScaleTileCore(RectangleShape,Double)
  • tileScale
MergeBitmaps(IEnumerable<BitmapTile>,Double)
  • tilesToMerge
  • scale
OnGottenCacheImage(GottenCacheImageBitmapTileCacheEventArgs)
OnGettingCacheImage(GettingCacheImageBitmapTileCacheEventArgs)
DatabasePathFilename
  • Gets or sets the database path filename.
ExpirationTime
  • Type:TimeSpan
CacheId
  • Gets or sets the id of the TileCache.
TileMatrix
TileAccessMode
NoDataTileImage
LoadingTileImage
ImageFormat
JpegQuality
  • Type:Int16
GottenCacheImage
Event Arguments:GottenCacheImageBitmapTileCacheEventArgs
GettingCacheImage
thinkgeo.mapsuite.androidedition.sqlitebitmaptilecache.txt · Last modified: 2017/03/16 21:59 (external edit)
