thinkgeo.mapsuite.androidedition.vertexmovingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.VertexMovingEditInteractiveOverlayEventArgs
Provides data for the VertexMoving. event.
      • ThinkGeo.MapSuite.AndroidEdition.VertexMovingEditInteractiveOverlayEventArgs
VertexMovingEditInteractiveOverlayEventArgs()
VertexMovingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex)
  • cancel
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • movingVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex to be moved.
AffectedVertexFeature
  • This property gets or sets the Feature to be used to move vertex.
MovingVertex
  • This property gets or sets the vertex to be moved.
Cancel
  • This property gets or sets the action to be canceled or not.
thinkgeo.mapsuite.androidedition.vertexmovingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
