thinkgeo.mapsuite.androidedition.vertexmovededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.VertexMovedEditInteractiveOverlayEventArgs
Provides data for the VertexMoved. event.
      • ThinkGeo.MapSuite.AndroidEdition.VertexMovedEditInteractiveOverlayEventArgs
VertexMovedEditInteractiveOverlayEventArgs()
VertexMovedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • movedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex moved.
AffectedVertexFeature
  • This property gets or sets the Feature to be used to remove vertex.
MovedVertex
  • This property gets or sets the vertex moved.
thinkgeo.mapsuite.androidedition.vertexmovededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
