thinkgeo.mapsuite.androidedition.controlpointselectededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.ControlPointSelectedEditInteractiveOverlayEventArgs
Provides data for the ControlPointSelected event.
      • ThinkGeo.MapSuite.AndroidEdition.ControlPointSelectedEditInteractiveOverlayEventArgs
ControlPointSelectedEditInteractiveOverlayEventArgs()
ControlPointSelectedEditInteractiveOverlayEventArgs(Feature)
  • selectedFeature
    • Type:Feature
    • Description:This parameter specified the feature selected.
SelectedFeature
  • This property gets or sets the selected feature.
thinkgeo.mapsuite.androidedition.controlpointselectededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
