thinkgeo.mapsuite.androidedition.featuredraggededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.FeatureDraggedEditInteractiveOverlayEventArgs
Provides data for the FeatureDragged event.
      • ThinkGeo.MapSuite.AndroidEdition.FeatureDraggedEditInteractiveOverlayEventArgs
FeatureDraggedEditInteractiveOverlayEventArgs()
FeatureDraggedEditInteractiveOverlayEventArgs(Feature)
  • draggedFeature
    • Type:Feature
    • Description:This parameter specified the feature dragged.
DraggedFeature
  • This property gets or sets the Feature dragged.
thinkgeo.mapsuite.androidedition.featuredraggededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
