thinkgeo.mapsuite.androidedition.controlpointtype
ThinkGeo.MapSuite.AndroidEdition.ControlPointType
  • This enumeration specified the control point type when editing a shape. The deafault value is None
Items
  • Summary:Default value of this enumeration.
Drag
  • Summary:This enumeration item means that the control point is for Drag.
Rotate
  • Summary:This enumeration item means that the control point is for Rotate.
Resize
  • Summary:This enumeration item means that the control point is for Resize.
Vertex
  • Summary:This enumeration item means that the control point is for change the vertex postion.
thinkgeo.mapsuite.androidedition.controlpointtype.txt · Last modified: 2017/03/16 21:59 (external edit)
