thinkgeo.mapsuite.androidedition.vertexremovededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.VertexRemovedEditInteractiveOverlayEventArgs
Provides data for the VertexRemoved. event.
      • ThinkGeo.MapSuite.AndroidEdition.VertexRemovedEditInteractiveOverlayEventArgs
VertexRemovedEditInteractiveOverlayEventArgs()
VertexRemovedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • removedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex removed.
AffectedVertexFeature
  • This property gets or sets the Feature to be used to remove vertex.
RemovedVertex
  • This property gets or sets the vertex removed.
thinkgeo.mapsuite.androidedition.vertexremovededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
