thinkgeo.mapsuite.androidedition.featureresizingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.FeatureResizingEditInteractiveOverlayEventArgs
Provides data for the FeatureResizing. event.
      • ThinkGeo.MapSuite.AndroidEdition.FeatureResizingEditInteractiveOverlayEventArgs
FeatureResizingEditInteractiveOverlayEventArgs()
FeatureResizingEditInteractiveOverlayEventArgs(Feature,Boolean,PointShape,PointShape)
  • resizingFeature
    • Type:Feature
    • Description:This parameter specified the target feature to be resized.
  • cancel
  • sourceControlPoint
    • Description:This parameter specified the source control point to be resized.
  • targetControlPoint
    • Description:This parameter specified the target control point to be resized.
ResizingFeature
  • This property gets or sets the Feature to be used to resized.
SourceControlPoint
  • This property gets or sets the source control point to resize.
TargetControlPoint
  • This property gets or sets the target control point to resize.
Cancel
  • This property gets or sets the action to be canceled or not.
thinkgeo.mapsuite.androidedition.featureresizingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
