thinkgeo.mapsuite.portablecore.multiplefeaturelayer
ThinkGeo.MapSuite.Core.MultipleFeatureLayer
This class represents a Layer backed by multiple Shape Files.
      • ThinkGeo.MapSuite.Core.FeatureLayer
        • ThinkGeo.MapSuite.Core.MultipleFeatureLayer
MultipleFeatureLayer()
  • This is the default constructor for the class.
MultipleFeatureLayer(IEnumerable<FeatureSource>)
  • This constructor gets the layer ready to use.
  • featureSources
    • Type:IEnumerable<FeatureSource>
    • Description:This parameter represents the FeatureSources in this class that you want to use.
GetThreadSafetyLevel()
CloneDeep()
  • Type:Layer
Open()
Close()
GetBoundingBox()
RequestDrawing()
RequestDrawing(TimeSpan)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
SetupTools()
SetupToolsCore()
OpenCore()
CloseCore()
GetBoundingBoxCore()
GetThreadSafetyLevelCore()
CloneDeepCore()
  • Type:Layer
  • e
    • Type:Exception
  • e
    • Type:Exception
  • attribution
FeatureSources
  • This property gets the FeatureSources you want to use.
HasBoundingBox
  • This property checks to see if a Layer has a BoundingBox or not. If it has no BoundingBox, it will throw an exception when you call the GetBoundingBox() and GetFullExtent() APIs. In MultipleFeatureLayer, we override this API and mark it as true.
  • The default implementation in the base class returns false.
WrappingExtent
WrappingMode
EditTools
FeatureIdsToExclude
  • Type:Collection<String>
QueryTools
MaxRecordsToDraw
DrawingMarginInPixel
  • Type:Single
FeatureSource
DrawingQuality
ZoomLevelSet
DrawingMarginPercentage
IsOpen
DrawingTime
  • Type:TimeSpan
IsVisible
Transparency
  • Type:Single
IsNegative
IsGrayscale
DrawingExceptionMode
Attribution
RequestDrawingInterval
  • Type:TimeSpan
FetchedCount
  • Type:Int64
FetchedBytes
  • Type:Int64
StyleTime
  • Type:TimeSpan
FetchTime
  • Type:TimeSpan
IsOpenCore
DrawingFeatures
DrawingException
DrawnException
DrawingAttribution
DrawnAttribution
RequestedDrawing
RequestingDrawing
thinkgeo.mapsuite.portablecore.multiplefeaturelayer.txt · Last modified: 2017/03/16 21:59 (external edit)
