<!– NamespacePage –> <!– AndroidEdition –>
| Name | Summary |
| AdornmentOverlay | |
| AndroidGeoCanvas | This class represents a canvas that is used to draw geographic shapes. It is intended to be inherited for the implementation of different drawing systems. |
| BingMapsTileOverlay | This class represents an overlay that requesting from Bing Maps Imagery Service. |
| CenterCoordinateMapTool | Represents the coordinates of the map center, display in the lower right corner of the map. |
| ControlPointSelectedEditInteractiveOverlayEventArgs | Provides data for the ControlPointSelected event. |
| ControlPointSelectingEditInteractiveOverlayEventArgs | Provides data for the ControlPointSelecting event. |
| CurrentExtentChangedMapViewEventArgs | Use to send data when map's extent is changed. |
| CurrentExtentChangingMapViewEventArgs | Use to send data when map's extent is changing. |
| CurrentScaleChangedMapViewEventArgs | Use to send data when map's current scale is changed. |
| CurrentScaleChangingMapViewEventArgs | Use to send data when map's current scale is changing. |
| DrawingExceptionOverlayEventArgs | Provides data for the DrawingExceptionOverlay event. |
| DrawnExceptionOverlayEventArgs | Provides data for the DrawnExceptionOverlay event. |
| EditEndedEditInteractiveOverlayEventArgs | Provides data for the FeatureEdited event. |
| EditInteractiveOverlay | This class inherits from InterativeOverlay abstract class. This specified overlay describle the EditShape interative process with MapControl using Mouse or Keyborad. |
| ExtentInteractiveOverlay | This class inherits from InterativeOverlay abstract class. This specified overlay describle the Extent Changing interative process with MapControl using Mouse or Keyborad. |
| FeatureDraggedEditInteractiveOverlayEventArgs | Provides data for the FeatureDragged event. |
| FeatureDraggingEditInteractiveOverlayEventArgs | Provides data for the FeatureDragging event. |
| FeatureResizedEditInteractiveOverlayEventArgs | Provides data for the FeatureResized event. |
| FeatureResizingEditInteractiveOverlayEventArgs | Provides data for the FeatureResizing event. |
| FeatureRotatedEditInteractiveOverlayEventArgs | Provides data for the FeatureRotated event. |
| FeatureRotatingEditInteractiveOverlayEventArgs | Provides data for the FeatureRotating event. |
| GoogleMapsTileOverlay | This class represents the GoogleMapsOverlay which requests images from Google's image server by its StaticAPI. |
| InteractionArguments | This class encapsulates the information and simple method for interative actions. |
| InteractiveOverlay | This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad. |
| InteractiveResult | This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay. |
| LayerOverlay | This class represents a group of layers; each layer can be of any layer type. |
| LayerTileView | This class represents the base class of tile which is the element to form tile overlay. |
| MapArguments | Contains important properties and methods of current map object. |
| MapTool | This class represents the base class of map controls. |
| MapTools | Contains the different map tools as properties and acts as an entrance for setting these map controls. |
| MapView | This class represents the map control. |
| Marker | Represents a marker control on the map. |
| MarkerOverlay | This class represents an overlay which maintaining markers. |
| MouseMovedTrackInteractiveOverlayEventArgs | Provides data for the MouseMoved. event. |
| OpenStreetMapOverlay | This class represents an overlay that requesting images from OpenStreet Map Service. |
| OpenStreetMapTileOverlay | This class represents an overlay that requesting images from OpenStreet Map Service. |
| Overlay | This class is the base class of all overlays in this overlay system. |
| Popup | This class represents a popup control for placing on the map. |
| PopupOverlay | This class represents an overlay to place popups on the map. |
| Resource | |
| SqliteBitmapTileCache | This class represents the base sqlite bitmap tile cache |
| TileOverlay | Represents an overlay that maintains tiles. |
| TrackEndedTrackInteractiveOverlayEventArgs | This is the default constructor of this parameter. |
| TrackEndingTrackInteractiveOverlayEventArgs | Provides data for the TrackEnding. event. |
| TrackInteractiveOverlay | This class inherits from InterativeOverlay abstract class. This specified overlay describle the TrackShape interative process with MapControl using Mouse or Keyborad. |
| TrackStartedTrackInteractiveOverlayEventArgs | Provides data for the TrackStarted. event. |
| TrackStartingTrackInteractiveOverlayEventArgs | Provides data for the TrackStarting. event. |
| TransformArguments | Class TransformArguments. |
| VertexAddedEditInteractiveOverlayEventArgs | Provides data for the VertexAdded. event. |
| VertexAddedTrackInteractiveOverlayEventArgs | Provides data for the VertexAdded. event. |
| VertexAddingEditInteractiveOverlayEventArgs | Provides data for the VertexAdding. event. |
| VertexAddingTrackInteractiveOverlayEventArgs | Provides data for the VertexAdding. event. |
| VertexMovedEditInteractiveOverlayEventArgs | Provides data for the VertexMoved. event. |
| VertexMovingEditInteractiveOverlayEventArgs | Provides data for the VertexMoving. event. |
| VertexRemovedEditInteractiveOverlayEventArgs | Provides data for the VertexRemoved. event. |
| VertexRemovingEditInteractiveOverlayEventArgs | Provides data for the VertexRemoving. event. |
| WmsOverlay | Represents an overlay object that gets map images from the WMS server you specify. |
| WorldMapKitOverlay | This class represents an WmsOverlay which has MapSuite world map kit server integrated. |
| ZoomMapTool | Represents the zooming panel in the upper left corner of the map. |
| Name | Summary |
| Name | Summary |
| ControlPointType | This enumeration specified the control point type when editing a shape. The deafault value is None |
| ExtentChangedType | |
| InteractiveOverlayDrawType | This enumeration specifies the mode to draw the InterativeOverlay when doing interactive actions with InterativeOverlay. |
| LockLayerMode | This enum represents the lock mode while drawing layers. |
| MapDoubleTapMode | This class specifies MapView DoubleTap. |
| OverlayRefreshType | Represents how the overlay refreshes. |
| ProcessOtherOverlaysMode | |
| TileSnappingMode | Represents how the tile overlay snapping. |
| TileType | This enum represents the tile type in the tile overlay. |
| TrackMode | TrackMode enumeration sets how the map will react to user interaction. |
| TransitionEffect | Represents how the overlay transition. |
| Name | Summary |
<!– AndroidEdition –> Note: * – not public released, might be removed in the next release. AndroidEdition ThinkGeo.MapSuite.AndroidEdition UpdateDocumentation
