thinkgeo.mapsuite.desktopedition.extentinteractiveoverlay
Table of Contents
ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay
<!– Class –> This class inherits from the interactiveOverlay abstract class. This specified overlay describes the Extent Changing interactive process with the MapControl using the Mouse or Keyboard.
Public MethodExtentInteractiveOverlay Default constructor of the class. If you use this constructor, please set the properties correctly or it will use their default values.
Public MethodDraw GeoCanvas Overlay This method draws the Overlay.
Public MethodDrawPreview GeoCanvas Overlay This method will be used to draw preview tiles to the canvas.
Public MethodGetType Object
Public MethodKeyDown KeyEventInteractionArguments InteractiveOverlay This method will simulate the KeyDown interaction.
Public MethodKeyUp KeyEventInteractionArguments InteractiveOverlay This method will simulate the KeyUp interaction.
Public MethodMouseClick InteractionArguments InteractiveOverlay This method will simulate the MouseClick interaction.
Public MethodMouseDoubleClick InteractionArguments InteractiveOverlay This method will simulate the MouseDoubleClick interaction.
Public MethodMouseDown InteractionArguments InteractiveOverlay This method will simulate the MouseDown interaction.
Public MethodMouseMove InteractionArguments InteractiveOverlay This method will simulate the MouseMove interaction.
Public MethodMouseUp InteractionArguments InteractiveOverlay This method will simulate the MouseUp interaction.
Public MethodMouseWheel InteractionArguments InteractiveOverlay This method will simulate the MouseWheel interaction.
Public MethodRefresh GeoCanvas, RectangleShape Overlay
Public MethodRequestDrawing RectangleShape, TimeSpan, RequestDrawingBufferTimeType Overlay
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan Overlay
Public MethodRequestDrawing IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType Overlay
Public MethodRequestDrawing TimeSpan, RequestDrawingBufferTimeType Overlay
Public MethodRequestDrawing TimeSpan Overlay
Public MethodRequestDrawing IEnumerable<RectangleShape> Overlay
Public MethodRequestDrawing RectangleShape Overlay
Public MethodRequestDrawing Overlay
Public MethodRequestDrawing RectangleShape, TimeSpan Overlay
Public MethodToString Object
Public MethodStatic Memberget_InteractiveClickInterval InteractiveOverlay
Public MethodStatic Memberset_InteractiveClickInterval Int32 InteractiveOverlay
Protected MethodDrawAttributionCore GeoCanvas Overlay
Protected MethodDrawCore GeoCanvas Overlay(overriden) This method draws the ExtentInteractiveOverlay.
Protected MethodDrawException GeoCanvas, Exception Overlay This method will draw on the canvas when an exception occurs during the drawing process.
Protected MethodDrawExceptionCore GeoCanvas, Exception Overlay This method is the Core method of DrawException, which can be overridden if you want to change its logic. This method will draw on the canvas when an exception occurs during drawing process.
Protected MethodDrawPreviewCore GeoCanvas Overlay This is the core method of DrawPreview which is intended to be overridden by its concrete sub class.
Protected MethodKeyDownCore KeyEventInteractionArguments InteractiveOverlay This protected virtual method is the Core method of KeyDown API.
Protected MethodKeyUpCore KeyEventInteractionArguments InteractiveOverlay This protected virtual method is the Core method of KeyDown API.
Protected MethodMouseClickCore InteractionArguments InteractiveOverlay(overriden) This overrides the MouseClick logic in its base class.
Protected MethodMouseDoubleClickCore InteractionArguments InteractiveOverlay(overriden) This overrides the MouseDoubleClick logic in its base class interactiveOverlay.
Protected MethodMouseDownCore InteractionArguments InteractiveOverlay(overriden) This overrides the MouseDown logic in its base class interactiveOverlay.
Protected MethodMouseMoveCore InteractionArguments InteractiveOverlay(overriden) This overrides the MouseMove logic in its base class interactiveOverlay.
Protected MethodMouseUpCore InteractionArguments InteractiveOverlay(overriden) This overrides the MouseUp logic in its base class interactiveOverlay.
Protected MethodMouseWheelCore InteractionArguments InteractiveOverlay(overriden) This overrides the MouseWheel logic in its base class interactiveOverlay.
Protected MethodOnDrawing DrawingOverlayEventArgs Overlay This event will be fired before Overlay is drawn.
Protected MethodOnDrawingAttribution DrawingAttributionOverlayEventArgs Overlay
Protected MethodOnDrawn DrawnOverlayEventArgs Overlay This event will be fired after Overlay is drawn.
Protected MethodOnDrawnAttribution DrawnAttributionOverlayEventArgs Overlay
Protected MethodOnMapKeyDown MapKeyDownInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when MapKeyDown is called.
Protected MethodOnMapKeyUp MapKeyUpInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when MapKeyUp is called.
Protected MethodOnMapMouseClick MapMouseClickInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when MapMouseClick is called.
Protected MethodOnMapMouseDoubleClick MapMouseDoubleClickInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when MapMouseDoubleClick is called.
Protected MethodOnMapMouseDown MapMouseDownInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when MapMouseDown is called.
Protected MethodOnMapMouseMove MapMouseMoveInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when MapMouseMove is called.
Protected MethodOnMapMouseUp MapMouseUpInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when MapMouseUp is called.
Protected MethodOnMapMouseWheel MapMouseWheelInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when MapMouseWheel is called.
Protected MethodOnRequestedDrawing RequestedDrawingOverlayEventArgs Overlay
Protected MethodOnRequestingDrawing RequestingDrawingOverlayEventArgs Overlay
Protected MethodRefreshCore GeoCanvas, RectangleShape Overlay
Public PropertyAttribution String Overlay
Public PropertyAutoRefreshInterval TimeSpan Overlay
Public PropertyDoubleLeftClickMode MapDoubleLeftClickMode This property gets or sets the DoubleLeftClickMode used for the ExtentInteractiveOverlay.
Public PropertyDoubleRightClickMode MapDoubleRightClickMode This property gets or sets the DoubleRightClickMode used for the ExtentInteractiveOverlay.
Public PropertyDrawingExceptionMode DrawingExceptionMode Overlay This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
Public PropertyDrawingTime TimeSpan Overlay This property gets the last drawing time for the Overlay.
Public PropertyExtentChangedType ExtentChangedType This property gets or sets the ExtentChangedType for the ExtentInteractiveOverlay.
Public PropertyIsBase Boolean Overlay Gets or sets a value that indicates whether the overlay is a base overlay. The default value is false.
Public PropertyIsEmpty Boolean Overlay(overriden) This property overrides its property in the base class by watching the feature count in trackZoomLayer. If it is empty, we can skip drawing it for better performance.
Public PropertyIsVisible Boolean Overlay Gets or sets a value that indicates whether the overlay is visible on the map.
Public PropertyLeftClickDragKey Keys This property gets or sets the Keys used in LeftClickDrag for the ExtentInteractiveOverlay.
Public PropertyLeftClickDragMode MapLeftClickDragMode This property gets or sets the LeftClickDragMode used for the ExtentInteractiveOverlay.
Public PropertyLock OverlayLock Overlay This property gets the OverlayLock object.
Public PropertyMouseWheelMode MapMouseWheelMode This property gets or sets the MouseWheelMode used for the ExtentInteractiveOverlay.
Public PropertyName String Overlay Gets or sets the name of the overlay, which can be used to represent a specific overlay.
Public PropertyPanMode MapPanMode This property gets or sets the PanMode used for the ExtentInteractiveOverlay.
Public PropertyPreviewTileCache BitmapTileCache Overlay This property gets or sets the preview tile cache system. In order for this system to work, you must be in multi-threaded mode and have the tile cache set.
Public PropertyRightClickDragKey Keys This property gets or sets the Keys used in RightClickDrag for the ExtentInteractiveOverlay.
Public PropertyRightClickDragMode MapRightClickDragMode This property gets or sets the RightClickDragMode used for the ExtentInteractiveOverlay.
Public PropertyTileCache BitmapTileCache Overlay This property gets or sets the TileCache used for the overlay.
Public PropertyZoomPercentage Int32 Gets or sets the zoom percentage when using the mouse wheel or double-clicking to zoom the MapControl.
Protected PropertyPanAndTrackZoomState PanAndTrackZoomState This protected property gets and sets the PanAndTrackZoomState with the information stored.
Protected PropertyTrackZoomInLayer InMemoryFeatureLayer
Public EventDrawing DrawingOverlayEventArgs Overlay This event will be fired before the Overlay is drawn.
Public EventDrawingAttribution DrawingAttributionOverlayEventArgs Overlay
Public EventDrawn DrawnOverlayEventArgs Overlay This event will be fired after the Overlay is drawn.
Public EventDrawnAttribution DrawnAttributionOverlayEventArgs Overlay
Public EventMapKeyDown MapKeyDownInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when the key is pressed down when focusing on the Map.
Public EventMapKeyUp MapKeyUpInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when the key is released up when focusing on the Map.
Public EventMapMouseClick MapMouseClickInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when the Mouse button is clicked (mouse up and mouse down in the same postion) on the Map.
Public EventMapMouseDoubleClick MapMouseDoubleClickInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when the Mouse button is double-clicked on the Map.
Public EventMapMouseDown MapMouseDownInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when the Mouse button is pressed (down) on the Map.
Public EventMapMouseMove MapMouseMoveInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when the Mouse is moved on the Map.
Public EventMapMouseUp MapMouseUpInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when the Mouse button is released (up) on the Map.
Public EventMapMouseWheel MapMouseWheelInteractiveOverlayEventArgs InteractiveOverlay This event will be fired when the Mouse wheel is scrolled while the cursor is over the Map.
Public EventRequestedDrawing RequestedDrawingOverlayEventArgs Overlay
Public EventRequestingDrawing RequestingDrawingOverlayEventArgs Overlay
ExtentInteractiveOverlay()
Name Type Description
Go Back
Draw(GeoCanvas)
This method is the concrete wrapper for the abstract method DrawCore. This method draws the representation of the overlay based on the extent you provided.As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
Return Type Description
Void<!– System.Void –>
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas object to draw on.
<!– ThinkGeo.MapSuite.DesktopEdition.Overlay –> Go Back
DrawPreview(GeoCanvas)
TilesExistingType<!– ThinkGeo.MapSuite.DesktopEdition.TilesExistingType –> The tile existing type, which indicates whether any tiles exist.
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
KeyDown(KeyEventInteractionArguments)
This method is the concrete wrapper for its virtual Core method. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
InteractiveResult<!– ThinkGeo.MapSuite.DesktopEdition.InteractiveResult –> Interaction results of this method.
interactionArguments KeyEventInteractionArguments<!– ThinkGeo.MapSuite.DesktopEdition.KeyEventInteractionArguments –> This parameter represents the interaction auguments for the method.
<!– ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay –> Go Back
KeyUp(KeyEventInteractionArguments)
MouseClick(InteractionArguments)
interactionArguments InteractionArguments<!– ThinkGeo.MapSuite.DesktopEdition.InteractionArguments –> This parameter represents the interaction auguments for the method.
MouseDoubleClick(InteractionArguments)
MouseDown(InteractionArguments)
MouseMove(InteractionArguments)
MouseUp(InteractionArguments)
MouseWheel(InteractionArguments)
Refresh(GeoCanvas, RectangleShape)
extent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
RequestDrawing(RectangleShape, TimeSpan, RequestDrawingBufferTimeType)
extentToRefresh RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –>
bufferTime TimeSpan<!– System.TimeSpan –>
bufferTimeType RequestDrawingBufferTimeType<!– ThinkGeo.MapSuite.Core.RequestDrawingBufferTimeType –>
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan)
extentsToRefresh IEnumerable<RectangleShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.RectangleShape} –>
RequestDrawing(IEnumerable<RectangleShape>, TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(TimeSpan, RequestDrawingBufferTimeType)
RequestDrawing(TimeSpan)
RequestDrawing()
RequestDrawing(RectangleShape, TimeSpan)
String<!– System.String –>
get_InteractiveClickInterval()
<!– static –>
set_InteractiveClickInterval(Int32)
<!– static –>
value Int32<!– System.Int32 –>
DrawAttributionCore(GeoCanvas)
DrawCore(GeoCanvas)
This method draws the representation of the overlay based on the extent you provided.When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
canvas GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> This parameter is the canvas object or a GeoImage to draw on.
<!– ThinkGeo.MapSuite.DesktopEdition.Overlay(overriden) –> Go Back
DrawException(GeoCanvas, Exception)
e Exception<!– System.Exception –> This parameter is the exception that is occurring.
DrawExceptionCore(GeoCanvas, Exception)
DrawPreviewCore(GeoCanvas)
KeyDownCore(KeyEventInteractionArguments)
KeyUpCore(KeyEventInteractionArguments)
MouseClickCore(InteractionArguments)
<!– ThinkGeo.MapSuite.DesktopEdition.InteractiveOverlay(overriden) –> Go Back
MouseDoubleClickCore(InteractionArguments)
MouseDownCore(InteractionArguments)
MouseMoveCore(InteractionArguments)
MouseUpCore(InteractionArguments)
MouseWheelCore(InteractionArguments)
OnDrawing(DrawingOverlayEventArgs)
e DrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawingOverlayEventArgs –> The OverlayDrawingEventArgs passed for the event raised.
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
args DrawingAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawingAttributionOverlayEventArgs –>
OnDrawn(DrawnOverlayEventArgs)
e DrawnOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawnOverlayEventArgs –> The OverlayDrawnEventArgs passed for the event raised.
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
args DrawnAttributionOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.DrawnAttributionOverlayEventArgs –>
OnMapKeyDown(MapKeyDownInteractiveOverlayEventArgs)
e MapKeyDownInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.MapKeyDownInteractiveOverlayEventArgs –> The MapKeyDownInteractiveOverlayEventArgs passed for the event raised.
OnMapKeyUp(MapKeyUpInteractiveOverlayEventArgs)
e MapKeyUpInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.MapKeyUpInteractiveOverlayEventArgs –> The MapKeyUpInteractiveOverlayEventArgs passed for the event raised.
OnMapMouseClick(MapMouseClickInteractiveOverlayEventArgs)
e MapMouseClickInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.MapMouseClickInteractiveOverlayEventArgs –> The MapMouseClickInteractiveOverlayEventArgs passed for the event raised.
OnMapMouseDoubleClick(MapMouseDoubleClickInteractiveOverlayEventArgs)
e MapMouseDoubleClickInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.MapMouseDoubleClickInteractiveOverlayEventArgs –> The MapMouseDoubleClickInteractiveOverlayEventArgs passed for the event raised.
OnMapMouseDown(MapMouseDownInteractiveOverlayEventArgs)
e MapMouseDownInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.MapMouseDownInteractiveOverlayEventArgs –> The MapMouseDownInteractiveOverlayEventArgs passed for the event raised.
OnMapMouseMove(MapMouseMoveInteractiveOverlayEventArgs)
e MapMouseMoveInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.MapMouseMoveInteractiveOverlayEventArgs –> The MapMouseMoveInteractiveOverlayEventArgs passed for the event raised.
OnMapMouseUp(MapMouseUpInteractiveOverlayEventArgs)
e MapMouseUpInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.MapMouseUpInteractiveOverlayEventArgs –> The MapMouseUpInteractiveOverlayEventArgs passed for the event raised.
OnMapMouseWheel(MapMouseWheelInteractiveOverlayEventArgs)
e MapMouseWheelInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelInteractiveOverlayEventArgs –> The MapMouseWheelInteractiveOverlayEventArgs passed for the event raised.
OnRequestedDrawing(RequestedDrawingOverlayEventArgs)
eventArgs RequestedDrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.RequestedDrawingOverlayEventArgs –>
OnRequestingDrawing(RequestingDrawingOverlayEventArgs)
eventArgs RequestingDrawingOverlayEventArgs<!– ThinkGeo.MapSuite.DesktopEdition.RequestingDrawingOverlayEventArgs –>
RefreshCore(GeoCanvas, RectangleShape)
Attribution
Return Type
AutoRefreshInterval
Return Type
DoubleLeftClickMode
Return Type
MapDoubleLeftClickMode<!– ThinkGeo.MapSuite.DesktopEdition.MapDoubleLeftClickMode –>
<!– ThinkGeo.MapSuite.DesktopEdition.ExtentInteractiveOverlay –> Go Back
Return Type
MapDoubleRightClickMode<!– ThinkGeo.MapSuite.DesktopEdition.MapDoubleRightClickMode –>
Return Type
DrawingExceptionMode<!– ThinkGeo.MapSuite.Core.DrawingExceptionMode –>
DrawingTime
We track the drawing time for the Overlay and report it back in this method. This is useful to determine the speed of various Overlays.
Return Type
ExtentChangedType
Return Type
ExtentChangedType<!– ThinkGeo.MapSuite.DesktopEdition.ExtentChangedType –>
IsBase
Return Type
IsEmpty
Return Type
IsVisible
Return Type
LeftClickDragKey
Return Type
Keys<!– System.Windows.Forms.Keys –>
LeftClickDragMode
Return Type
MapLeftClickDragMode<!– ThinkGeo.MapSuite.DesktopEdition.MapLeftClickDragMode –>
Lock
Return Type
OverlayLock<!– ThinkGeo.MapSuite.DesktopEdition.OverlayLock –>
MouseWheelMode
Return Type
MapMouseWheelMode<!– ThinkGeo.MapSuite.DesktopEdition.MapMouseWheelMode –>
Return Type
PanMode
Return Type
MapPanMode<!– ThinkGeo.MapSuite.DesktopEdition.MapPanMode –>
PreviewTileCache
Return Type
BitmapTileCache<!– ThinkGeo.MapSuite.Core.BitmapTileCache –>
RightClickDragKey
Return Type
RightClickDragMode
Return Type
MapRightClickDragMode<!– ThinkGeo.MapSuite.DesktopEdition.MapRightClickDragMode –>
TileCache
The TileCache system is always used for better performance, especially in the case where your application tiles can be pregenerated.
Return Type
ZoomPercentage
Return Type
Return Type
PanAndTrackZoomState<!– ThinkGeo.MapSuite.DesktopEdition.PanAndTrackZoomState –>
TrackZoomInLayer
Return Type
InMemoryFeatureLayer<!– ThinkGeo.MapSuite.Core.InMemoryFeatureLayer –>
Drawing
Event Arguments
Event Arguments
DrawingAttribution
Event Arguments
Event Arguments
Drawn
Event Arguments
Event Arguments
DrawnAttribution
Event Arguments
Event Arguments
MapKeyDown
Event Arguments
Event Arguments
MapKeyUp
Event Arguments
Event Arguments
MapMouseClick
Event Arguments
Event Arguments
MapMouseDoubleClick
Event Arguments
Event Arguments
MapMouseDown
Event Arguments
Event Arguments
MapMouseMove
Event Arguments
Event Arguments
MapMouseUp
Event Arguments
Event Arguments
MapMouseWheel
Event Arguments
Event Arguments
RequestedDrawing
Event Arguments
Event Arguments
RequestingDrawing
Event Arguments
Event Arguments
NOTOC DesktopEdition ThinkGeo.MapSuite.DesktopEdition UpdateDocumentation
thinkgeo.mapsuite.desktopedition.extentinteractiveoverlay.1440040130.txt.gz · Last modified: 2015/09/22 08:10 (external edit)
