<!– Class –> This class inherits from InterativeOverlay abstract class. This specified overlay describle the EditShape interative process with MapControl using Mouse or Keyborad.
*System.Object ThinkGeo.MapSuite.AndroidEdition.Overlay *ThinkGeo.MapSuite.AndroidEdition.InteractiveOverlay ThinkGeo.MapSuite.AndroidEdition.EditInteractiveOverlay
EditInteractiveOverlay | Default constructor of the class. If you use thi constructor, please set the properties correctly or it will use their default values. |
CalculateAllControlPoints | This method calculates all control points. | ||
ClearAllControlPoints | This method clears all control points in corresponding layer. | ||
Close | Overlay | This method will simulate the Close interaction. | |
DeleteTrackShape | Delete the selected track shape. | ||
Dispose | Overlay | This method dispose unmanaged resource used in this class. | |
DoubleTap | InteractionArguments | InteractiveOverlay | This method will simulate the DoubleTap interaction. |
Draw | MapArguments, OverlayRefreshType | Overlay | This method draws the overlay with the provided extent in world coordinate. |
GetBoundingBox | Overlay | This method gets a bounding box of the Overlay. | |
Initialize | MapArguments | Overlay | This method initializes overlay object. |
LongPress | InteractionArguments | InteractiveOverlay | This method will simulate the LongPress interaction. |
Open | Overlay | This method will simulate the Open interaction. | |
PostTransform | TransformArguments, MapArguments | Overlay | This method will simulate the PostTransform interaction. |
Refresh | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
SingleTap | InteractionArguments | InteractiveOverlay | This method will simulate the SingleTap interaction. |
ToString | Object | ||
TouchDown | InteractionArguments | InteractiveOverlay | This method will simulate the TouchDown interaction. |
TouchMove | InteractionArguments | InteractiveOverlay | This method will simulate the TouchMove interaction. |
TouchPointerDown | InteractionArguments | InteractiveOverlay | This method will simulate the TouchPointerDown interaction. |
TouchUp | InteractionArguments | InteractiveOverlay | This method will simulate the TouchUp interaction. |
AddVertex | PointShape, Double | This is the method to add vertex from a feature. | |
AddVertexCore | Feature, PointShape, Double | This is the Core method of AddVertex which encapsulate the logic. | |
CalculateDragControlPoints | This method caculates the Drag control points for all the features in the EditShapesLayer. You can override its logic by rewrite its core method. | ||
CalculateDragControlPointsCore | Feature | This is the core API for the CalculateDragControlPoints, you can override this method if you want to change its logic. | |
CalculateResizeControlPoints | This method caculates the Resize control points for all the features in the EditShapesLayer. You can override its logic by rewrite its core method. | ||
CalculateResizeControlPointsCore | Feature | This is the core API for the CalculateResizeControlPoints, you can override this method if you want to change its logic. | |
CalculateRotateControlPoints | This method caculates the Rotate control points for all the features in the EditShapesLayer. You can override its logic by rewrite its core method. | ||
CalculateRotateControlPointsCore | Feature | This is the core API for the CalculateRotateControlPoints, you can override this method if you want to change its logic. | |
CalculateVertexControlPoints | This method caculates the vertex control points for all the features in the EditShapesLayer. You can override its logic by rewrite its core method. | ||
CalculateVertexControlPointsCore | Feature | This is the core API for the CalculateVertexControlPoints, you can override this method if you want to change its logic. | |
CloseCore | Overlay | This protected virtual method is the Core method of Close API. | |
Dispose | Boolean | Overlay(overriden) | |
DoubleTapCore | InteractionArguments | InteractiveOverlay(overriden) | |
DragFeature | Feature, PointShape, PointShape | This is the method to Drag a feature. | |
DragFeatureCore | Feature, PointShape, PointShape | This is the Core method of DragFeature which encapsulate the logic. | |
DrawCore | MapArguments, OverlayRefreshType | Overlay(overriden) | This method draws the EditInterativeOverlay. |
DrawException | GeoCanvas, Exception | Overlay | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
DrawExceptionCore | GeoCanvas, Exception | Overlay | This method will draw on the canvas when the layer.Draw throw exception and the DrawExceptionMode is set to DrawException instead of ThrowException. |
EndEditing | PointShape | This method End the editing for the interative editing on the feature in the EditShapesLayer. You can override its logic by rewrite its core method. | |
EndEditingCore | PointShape | This is the core method of EndEditing method. This method End the editing for the interative editing on the feature in the EditShapesLayer. | |
Finalize | Object(overriden) | ||
GetBoundingBoxCore | Overlay | This method returns the bounding box of the Overlay. | |
InitializeCore | MapArguments | Overlay(overriden) | |
LongPressCore | InteractionArguments | InteractiveOverlay | This protected virtual method is the Core method of LongPress API. |
MemberwiseClone | Object | ||
MoveVertex | Feature, PointShape, PointShape | This is the method to move vertex from a feature. | |
MoveVertexCore | Feature, PointShape, PointShape | This is the Core method of MoveVertex which encapsulate the logic. | |
OnControlPointSelected | ControlPointSelectedEditInteractiveOverlayEventArgs | This event will be fired after control point selected. | |
OnControlPointSelecting | ControlPointSelectingEditInteractiveOverlayEventArgs | This event will be fired before control point selected. | |
OnDrawingException | DrawingExceptionOverlayEventArgs | Overlay | This method raises before the overlay is drawing exception. |
OnDrawnException | DrawnExceptionOverlayEventArgs | Overlay | This method raises after the overlay is drawn exception. |
OnEditEnded | Feature | ||
OnFeatureDragged | FeatureDraggedEditInteractiveOverlayEventArgs | This event will be fired after dragging the feature. | |
OnFeatureDragging | FeatureDraggingEditInteractiveOverlayEventArgs | This event will be fired before dragging the feature. | |
OnFeatureResized | FeatureResizedEditInteractiveOverlayEventArgs | This event will be fired after resizing the feature. | |
OnFeatureResizing | FeatureResizingEditInteractiveOverlayEventArgs | This event will be fired before resizing the feature. | |
OnFeatureRotated | FeatureRotatedEditInteractiveOverlayEventArgs | This event will be fired after rotating the feature. | |
OnFeatureRotating | FeatureRotatingEditInteractiveOverlayEventArgs | This event will be fired before rotating the feature. | |
OnVertexAdded | VertexAddedEditInteractiveOverlayEventArgs | This event will be fired after vertex added to the edit feature. | |
OnVertexAdding | VertexAddingEditInteractiveOverlayEventArgs | This event will be fired before vertex added to the edit feature. | |
OnVertexMoved | VertexMovedEditInteractiveOverlayEventArgs | This event will be fired after moving the feature. | |
OnVertexMoving | VertexMovingEditInteractiveOverlayEventArgs | This event will be fired before moving the feature. | |
OnVertexRemoved | VertexRemovedEditInteractiveOverlayEventArgs | This event will be fired after vertex removed from the edit feature. | |
OnVertexRemoving | VertexRemovingEditInteractiveOverlayEventArgs | This event will be fired before vertex removed from the edit feature. | |
OpenCore | Overlay | This protected virtual method is the Core method of Open API. | |
PostTransformCore | TransformArguments, MapArguments | Overlay(overriden) | |
RefreshCore | Overlay | This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles. | |
RemoveVertex | PointShape, Double | This is the method to remove vertex from a feature. | |
RemoveVertexCore | Feature, Vertex, Double | This is the Core method of RemoveVertex which encapsulate the logic. | |
ResizeFeature | Feature, PointShape, PointShape | This is the method to Resize a feature. | |
ResizeFeatureCore | Feature, PointShape, PointShape | This is the Core method of ResizeFeature which encapsulate the logic. | |
RotateFeature | Feature, PointShape, PointShape | This is the method to Rotate a feature. | |
RotateFeatureCore | Feature, PointShape, PointShape | This is the Core method of RotateFeature which encapsulate the logic. | |
SetSelectedControlPoint | PointShape, Double | This protected method is to set the control point. | |
SetSelectedControlPointCore | PointShape, Double | This protected virtual method is the Core method of SetSelectedControlPoint API. | |
SingleTapCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseClick logic in its base class. |
TouchDownCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseDown logic in its base class InterativeOverlay. |
TouchMoveCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseMove logic in its base class InterativeOverlay. |
TouchPointerDownCore | InteractionArguments | InteractiveOverlay | This protected virtual method is the Core method of TouchPointerDown API. |
TouchUpCore | InteractionArguments | InteractiveOverlay(overriden) | This overrides the MouseUp logic in its base class InterativeOverlay. |
Attribution | String | Overlay | Gets or sets the attribution for this overlay. |
CanAddVertex | Boolean | Gets a value which indicates whether the shape can Add new vertex. | |
CanDrag | Boolean | Gets a value which indicates whether the shape can be dragged. | |
CanRemoveVertex | Boolean | Gets a value which indicates whether the shape can remove a existing vertex. | |
CanReshape | Boolean | Gets a value which indicates whether the shape can be reshaped. | |
CanResize | Boolean | Gets a value which indicates whether the shape can be resized. | |
CanRotate | Boolean | Gets a value which indicates whether the shape can be rotated. | |
DragControlPointsLayer | InMemoryFeatureLayer | This property gets the InMemoryFeatureLayer which holds the control points for drag. | |
DrawingExceptionMode | DrawingExceptionMode | Overlay | This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing. |
DrawingQuality | DrawingQuality | Overlay | Gets or sets the drawingQuality for this overlay. |
EditShapesLayer | InMemoryFeatureLayer | This property gets the InMemoryFeatureLayer which holds the edit shapes. | |
ExistingControlPointsLayer | InMemoryFeatureLayer | This property gets the InMemoryFeatureLayer which holds the control points which represents the existing vertices of the edit shapes. | |
InteractiveView | TileView | InteractiveOverlay | Gets or sets Overlay's the interactiveView. |
IsEmpty | Boolean | Overlay(overriden) | This property override its property in base class by watching the feature count in editShapesLayer. If it is empty ,we can skip drawing it for better performance. |
IsVisible | Boolean | Overlay | Gets or sets if this overlay is visible. |
MapArguments | MapArguments | Overlay | Gets or sets the mapArguments for this overlay. |
Name | String | Overlay | Gets or sets the name of this overaly. |
Opacity | Double | Overlay | Gets or sets the opacity for this overlay. |
ResizeControlPointsLayer | InMemoryFeatureLayer | This property gets the InMemoryFeatureLayer which holds the control points for resize. | |
RotateControlPointsLayer | InMemoryFeatureLayer | This property gets the InMemoryFeatureLayer which holds the control points for rotate. | |
TrackMode | TrackMode | Gets or sets a mode of TrackOverlay. |
ControlPointType | ControlPointType | This property gets or sets the ControlPointType for the control points of the edit shapes. | |
OriginalEditingFeature | Feature | This property gets the feature represents the original editing feature. | |
SelectControlPointFeature | Feature | This property gets the feature represents the select control points of the edit shapes. |
First, it will clear all control points. Then it will calculate each control points according to their settings.
<!– ThinkGeo.MapSuite.AndroidEdition.EditInteractiveOverlay –> Go Back
<!– ThinkGeo.MapSuite.AndroidEdition.Overlay –> Go Back
Should set TrackMode as EditShape mode first, use mouse select one shape, and then call <strong>DeleteTrackShape</strong>, it will delete the selected shape.
This method is the concrete wrapper for its virtual Core method.
| InteractiveResult<!– ThinkGeo.MapSuite.AndroidEdition.InteractiveResult –> | Interaction results of this method. |
| e | InteractionArguments<!– ThinkGeo.MapSuite.AndroidEdition.InteractionArguments –> | This parameter is the interaction auguments for the method. |
<!– ThinkGeo.MapSuite.AndroidEdition.InteractiveOverlay –> Go Back
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.AndroidEdition.MapArguments –> | This parameter maintains current map information for calculating mechanism. |
| refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.AndroidEdition.OverlayRefreshType –> | This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode. |
This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay.
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | A RectangleShape indicating the bounding box of this overlay. |
This is a wrapper method for the virtual method InitializeCore.
| transformInfo | TransformArguments<!– ThinkGeo.MapSuite.AndroidEdition.TransformArguments –> | This parameter maintains the transfrom information for calculating transform. |
This method is the concrete wrapper for the abstract method AddVertexCore.
| Boolean<!– System.Boolean –> | True if add vertex succeed , other wise return false. |
| targetPointShape | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifies the point shape to search the vertex. |
| searchingTolerance | Double<!– System.Double –> | This parameter specifes the searching tolerance to search the vetex. |
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> | Returns a vertex added feature. |
| targetFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specifies the target feature to be add vertex from. |
| targetPointShape | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifies the target vertex to be added. |
| IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> | A collection of features stands for the Drag control points. |
| feature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | The target feature to caculate the control point. |
| IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> | A collection of features stands for the Resize control points. |
| IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> | A collection of features stands for the Rotate control points. |
| IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.Core.Feature} –> | A collection of features stands for the Vertex control points. |
| isDisposing | Boolean<!– System.Boolean –> |
<!– ThinkGeo.MapSuite.AndroidEdition.Overlay(overriden) –> Go Back
| interactionArguments | InteractionArguments<!– ThinkGeo.MapSuite.AndroidEdition.InteractionArguments –> |
<!– ThinkGeo.MapSuite.AndroidEdition.InteractiveOverlay(overriden) –> Go Back
This method is the concrete wrapper for the abstract method DragFeatureCore.
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> | Returns a dragged feature. |
| sourceFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specifies the source feature to be dragged. |
| sourceControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifes the source control point to drag the feature. |
| targetControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifes the target control point to drag the feature. |
This method draws the representation of the overlay based on the extent you provided.
When implementing this abstract method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties that allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
| mapArguments | MapArguments<!– ThinkGeo.MapSuite.AndroidEdition.MapArguments –> | This parameter is the arguments for current map. |
| refreshType | OverlayRefreshType<!– ThinkGeo.MapSuite.AndroidEdition.OverlayRefreshType –> | This parameter is current refreshType, could be pan or redraw. |
| geoCanvas | GeoCanvas<!– ThinkGeo.MapSuite.Core.GeoCanvas –> | |
| exception | Exception<!– System.Exception –> |
| ex | Exception<!– System.Exception –> |
| targetPointShape | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This is the targetPointShape possible be used when overriding. |
| RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> | This method returns the bounding box of the Overlay. |
This method is the concrete wrapper for the abstract method MoveVertexCore.
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> | Returns a rotated feature. |
| sourceFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specifies the source feature to be move vertex from. |
| sourceControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifes the source control point to move vertex from the feature. |
| targetControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifes the target control point to move vertex from the feature. |
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> | Returns a vertex moved feature. |
| e | ControlPointSelectedEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.ControlPointSelectedEditInteractiveOverlayEventArgs –> | The ControlPointSelectedEditInteractiveOverlayEventArgs passed for the event raised. |
| e | ControlPointSelectingEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.ControlPointSelectingEditInteractiveOverlayEventArgs –> | The ControlPointSelectingEditInteractiveOverlayEventArgs passed for the event raised. |
| args | DrawingExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.DrawingExceptionOverlayEventArgs –> | This parameter is the event argument for DrawingException event. |
| args | DrawnExceptionOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.DrawnExceptionOverlayEventArgs –> | This parameter is the event argument for DrawingException event. |
| editedFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> |
| e | FeatureDraggedEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.FeatureDraggedEditInteractiveOverlayEventArgs –> | The FeatureDraggedEditInteractiveOverlayEventArgs passed for the event raised. |
| e | FeatureDraggingEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.FeatureDraggingEditInteractiveOverlayEventArgs –> | The FeatureDraggingEditInteractiveOverlayEventArgs passed for the event raised. |
| e | FeatureResizedEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.FeatureResizedEditInteractiveOverlayEventArgs –> | The FeatureResizedEditInteractiveOverlayEventArgs passed for the event raised. |
| e | FeatureResizingEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.FeatureResizingEditInteractiveOverlayEventArgs –> | The FeatureResizingEditInteractiveOverlayEventArgs passed for the event raised. |
| e | FeatureRotatedEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.FeatureRotatedEditInteractiveOverlayEventArgs –> | The FeatureRotatedEditInteractiveOverlayEventArgs passed for the event raised. |
| e | FeatureRotatingEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.FeatureRotatingEditInteractiveOverlayEventArgs –> | The FeatureRotatingEditInteractiveOverlayEventArgs passed for the event raised. |
| e | VertexAddedEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.VertexAddedEditInteractiveOverlayEventArgs –> | The VertexAddedEditInteractiveOverlayEventArgs passed for the event raised. |
| e | VertexAddingEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.VertexAddingEditInteractiveOverlayEventArgs –> | The VertexAddingEditInteractiveOverlayEventArgs passed for the event raised. |
| e | VertexMovedEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.VertexMovedEditInteractiveOverlayEventArgs –> | The VertexMovedEditInteractiveOverlayEventArgs passed for the event raised. |
| e | VertexMovingEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.VertexMovingEditInteractiveOverlayEventArgs –> | The VertexMovingEditInteractiveOverlayEventArgs passed for the event raised. |
| e | VertexRemovedEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.VertexRemovedEditInteractiveOverlayEventArgs –> | The VertexRemovedEditInteractiveOverlayEventArgs passed for the event raised. |
| e | VertexRemovingEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.VertexRemovingEditInteractiveOverlayEventArgs –> | The VertexRemovingEditInteractiveOverlayEventArgs passed for the event raised. |
| transformInfo | TransformArguments<!– ThinkGeo.MapSuite.AndroidEdition.TransformArguments –> | |
This method is the concrete wrapper for the abstract method RemoveVertexCore.
| Boolean<!– System.Boolean –> | True if remove vertex succeed , other wise return false. |
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> | Returns a vertex removed feature. |
| editShapeFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specifies the target feature to be remove vertex from. |
| selectedVertex | Vertex<!– ThinkGeo.MapSuite.Core.Vertex –> | This parameter specifies the selected vertex to search the vertex. |
This method is the concrete wrapper for the abstract method ResizeFeatureCore.
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> | Returns a resized feature. |
| sourceFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specifies the source feature to be resized. |
| sourceControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifes the source control point to resize the feature. |
| targetControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifes the target control point to resize the feature. |
This method is the concrete wrapper for the abstract method RotateFeatureCore.
| sourceFeature | Feature<!– ThinkGeo.MapSuite.Core.Feature –> | This parameter specifies the source feature to be rotated. |
| sourceControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifes the source control point to rotate the feature. |
| targetControlPoint | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter specifes the target control point to rotate the feature. |
| Boolean<!– System.Boolean –> | Returns true if control point are found and set correct, other wise, returns false. |
| targetPointShape | PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> | This parameter is target point shape we determine to edit. |
| searchingTolerance | Double<!– System.Double –> | This parameter is the searchinig tolerance to seach the control point. |
| Feature<!– ThinkGeo.MapSuite.Core.Feature –> | A feature stands for the selected control point. |
| interactionArguments | InteractionArguments<!– ThinkGeo.MapSuite.AndroidEdition.InteractionArguments –> | This parameter is the interaction auguments for the method. |
Every control points for drag are not the existing vertex of the edit shapes.
| InMemoryFeatureLayer<!– ThinkGeo.MapSuite.Core.InMemoryFeatureLayer –> |
| DrawingQuality<!– ThinkGeo.MapSuite.Core.DrawingQuality –> |
Every control points in this layer are the existing vertices of the edit shapes.
| TileView<!– ThinkGeo.MapSuite.AndroidEdition.TileView –> |
Every control points for resize are not the existing vertex of the edit shapes.
Every control points for rotate are not the existing vertex of the edit shapes.
The default mode is TrackMode.None which means you cannot draw or edit features at client. By setting the mode to TrackMode.Point, TrackMode.Line, TrackMode.Polygon etc., you could add point, line or polygon to the FeatureOverlay. Setting the mode to TrackMode.Edit, you could edit the shapes at the client side.
| TrackMode<!– ThinkGeo.MapSuite.AndroidEdition.TrackMode –> |
| ControlPointType<!– ThinkGeo.MapSuite.AndroidEdition.ControlPointType –> |
This event will be fired after select the control point.
| Event Arguments |
This event will be fired before select the control point.
| Event Arguments |
Occurs before exception is drawing on map.
| Event Arguments |
Occurs after exception is drawn on map.
| Event Arguments |
| Event Arguments |
| EditEndedEditInteractiveOverlayEventArgs<!– ThinkGeo.MapSuite.AndroidEdition.EditEndedEditInteractiveOverlayEventArgs –> |
This event will be fired after drag the feature.
| Event Arguments |
This event will be fired before drag the feature.
| Event Arguments |
This event will be fired after resize the feature.
| Event Arguments |
This event will be fired before resize the feature.
| Event Arguments |
This event will be fired after rotate the feature.
| Event Arguments |
This event will be fired before rotate the feature.
| Event Arguments |
This event will be fired after add the vertex.
| Event Arguments |
This event will be fired before add the vertex.
| Event Arguments |
This event will be fired after move the vertex.
| Event Arguments |
This event will be fired before move the vertex.
| Event Arguments |
This event will be fired after remove the vertex.
| Event Arguments |
This event will be fired before remove the vertex.
| Event Arguments |
NOTOC AndroidEdition ThinkGeo.MapSuite.AndroidEdition UpdateDocumentation
