A
This class represents a routing algorithm that is based on the A* algorithm.
B
This class represents a routing algorithm that is based on the Bidirectional algorithm.
This class represents the parameters passed out through the BuildingRoutingData event.
D
This class represents a routing algorithm that is based on the Dijkstra algorithm.
F
This class represents the parameters passed out through the FindingRoute event.
G
This class represents the parameters passed out through the FindingServiceArea event.
This class represents the parameters passed out through the GettingTspVisitRoute event.
R
This class repesents a routeSegment, which is a base element in routing.
This class is the base class for all types of RoutingAlgorithm.
This class is for finding a route.
This layer can show start coordinates, end coordinates, a collection of in-between stops and the resulting paths with specified styles.
This class represents the result of routing. RoutingResult is the roads collection consisting of the route, turn-by-turn directions and other information like total distance and route path.
This class is the base class for all types of RoutingSource.
This class represents a RoutingSource based on an .rtg file.
S
This class represents the event arguments for the StreamLoading event.
B
This enumeration represents whether routing data should be rebuilt or not.
D
This describes a set of enumerations that list the driving directions.
R
This enumeration represents what the routing results will return.
S
This enumeration represents the speed unit. The default value is kilometer per hour.
