thinkgeo.mapsuite.routing.routingresult
ThinkGeo.MapSuite.Routing.RoutingResult
This class represents the result of routing. RoutingResult is the roads collection consisting of the route, turn-by-turn directions and other information like total distance and route path.
    • ThinkGeo.MapSuite.Routing.RoutingResult
RoutingResult()
  • This is the class constructor.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#RoutingResult.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#MemberwiseClone.28.29
OrderedStops
Gets a PointShape collection that represent the best order in which the locations are visited.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#OrderedStops
Route
Gets or sets established lines which consist of route segments.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#Route
Distance
Gets or sets a value representing the distance of the route.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#Distance
Weight
Gets or sets a value representing the sum weight of the route.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#Weight
Features
Gets a collection of features representing the route.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#Features
RouteSegments
Gets a collection of route segments representing the route.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingResult#RouteSegments
1RQ=
  • Type:Collection<Int32>
2BQ=
thinkgeo.mapsuite.routing.routingresult.txt · Last modified: 2017/03/16 21:59 (external edit)
