This class repesents a routeSegment, which is a base element in routing.
RouteSegment(String,Int32,Single,PointShape,IEnumerable<String>,PointShape,IEnumerable<String>)
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#Distance
Gets or sets a value representing the weight of the routeSegment. It can represent, for example, the routeSegment length.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#Weight
Gets or sets a value representing the type of routeSegment. You can define a value that represents kind of routeSegment, for example: 0 represents a local routeSegment, 1 represents a major routeSegment, 2 represents a highway.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#RouteSegmentType
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#StartPoint
Gets a value represents the adjacent feature ids of start point.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#StartPointAdjacentIds
Gets or sets a value representing the ending vertex of the routeSegment.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#EndPoint
Gets a value representing the adjacent feature IDs of the end point.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#EndPointAdjacentIds
Gets or sets a value representing the feature ID of the routeSegment. It is an identity of a single routeSegment, thus you cannot set the feature ID to two or more routeSegments.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#FeatureId
Gets or sets a value representing the next driving direction of the routeSegment. For example, if you are driving on the current routeSegment and will turn right on the next routeSegment, the value will be Right.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RouteSegment#DrivingDirection
