thinkgeo.mapsuite.routing.gettingrouteviavisitstopsroutingengineeventargs
ThinkGeo.MapSuite.Routing.GettingRouteViaVisitStopsRoutingEngineEventArgs
This class represents the parameters passed out through the GettingTspVisitRoute event.
      • ThinkGeo.MapSuite.Routing.GettingRouteViaVisitStopsRoutingEngineEventArgs
GettingRouteViaVisitStopsRoutingEngineEventArgs()
This is the default constructor with no parameters
GettingRouteViaVisitStopsRoutingEngineEventArgs(IEnumerable<Int32>,IEnumerable<RouteSegment>)
This is the constructor that passed the current bestVisitSequence of locations and default isTermination value “false”
  • visitSequence
    • Type:IEnumerable<Int32>
    • Description:The current bestVisitSequence of locations that you want to pass out by event.
  • routeSegments
    • Type:IEnumerable<RouteSegment>
    • Description:The RouteSement collection that represents current route
GettingRouteViaVisitStopsRoutingEngineEventArgs(IEnumerable<Int32>,IEnumerable<RouteSegment>,Boolean)
This is the constructor that passed the current bestVisitSequence of locations and a value representing whether stops current calculating.
  • visitSequence
  • routeSegments
    • Description:A collection of route segments representing the route.
  • terminated
    • Description:A value represents whether stops current calculating.
Terminate
Gets or sets the value that allows you stops the calculating and return current result. The default value is false.
If you set the value to true, it will stops the calculating and return current result.
RouteSegments
Gets a collection of route segments representing the route.
VisitSequence
Gets a number collection that represent the order in which the stops are visited.
  • Type:Collection<Int32>
TotalDistance
The totalCost of current route
thinkgeo.mapsuite.routing.gettingrouteviavisitstopsroutingengineeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
