thinkgeo.mapsuite.routing.generatingservicearearoutingengineeventargs
ThinkGeo.MapSuite.Routing.GeneratingServiceAreaRoutingEngineEventArgs
This class represents the parameters passed out through the FindingServiceArea event.
      • ThinkGeo.MapSuite.Routing.GeneratingServiceAreaRoutingEngineEventArgs
GeneratingServiceAreaRoutingEngineEventArgs()
  • This is the default constructor with no parameters
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.GeneratingServiceAreaRoutingEngineEventArgs#GeneratingServiceAreaRoutingEngineEventArgs.28.29
GeneratingServiceAreaRoutingEngineEventArgs(RouteSegment)
  • This is the constructor that passed the routeSegment.
  • routeSegment
    • Description:The routeSegment that you want pass out by event.
GeneratingServiceAreaRoutingEngineEventArgs(RouteSegment,IEnumerable<String>)
  • This is the constructor that passed the routeSegment and accessible feature ids.
  • routeSegment
  • accessibleFeatureIds
    • Type:IEnumerable<String>
    • Description:The accessibleFeatureIds that you want pass out by event.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.GeneratingServiceAreaRoutingEngineEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.GeneratingServiceAreaRoutingEngineEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.GeneratingServiceAreaRoutingEngineEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.GeneratingServiceAreaRoutingEngineEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.GeneratingServiceAreaRoutingEngineEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.GeneratingServiceAreaRoutingEngineEventArgs#MemberwiseClone.28.29
RouteSegment
Gets or sets the value that represents the current routeSegment during route.
The default value is null if you call the default constructor.
Terminate
Gets or sets the value that represents whether the current routeSegment is the terminus. The default value is false.
If you set the value to true, it will make the current routeSegment the terminus, which will break the route and return the path that has been routed thus far.
AccessibleFeatureIds
Gets a collection of Feature ids that have been accessed
  • Type:Collection<String>
thinkgeo.mapsuite.routing.generatingservicearearoutingengineeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
