thinkgeo.mapsuite.routing.buildingroutingdatartgroutingsourceeventargs
ThinkGeo.MapSuite.Routing.BuildingRoutingDataRtgRoutingSourceEventArgs
This class represents the parameters passed out through the BuildingRoutingData event.
      • ThinkGeo.MapSuite.Routing.BuildingRoutingDataRtgRoutingSourceEventArgs
BuildingRoutingDataRtgRoutingSourceEventArgs()
  • This is the default constructor.
BuildingRoutingDataRtgRoutingSourceEventArgs(RouteSegment,LineShape)
  • This is the constructor that passed the routeSegment.
  • routeSegment
    • Description:The routeSegment that you want pass out by event.
  • lineShape
    • Type:LineShape
    • Description:The lineShape that you want pass out by event.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.BuildingRoutingDataRtgRoutingSourceEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.BuildingRoutingDataRtgRoutingSourceEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.BuildingRoutingDataRtgRoutingSourceEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.BuildingRoutingDataRtgRoutingSourceEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.BuildingRoutingDataRtgRoutingSourceEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.BuildingRoutingDataRtgRoutingSourceEventArgs#MemberwiseClone.28.29
LineShape
Gets or sets the value that represents the current lineShape during build.
The default value is null if you call the default constructor.
RouteSegment
Gets or sets the value that represents the current routeSegment during route.
Cancel
Gets or sets the value that represents whether the building data is cancelled. The default value is false.
If you set the value to true, it will cancel building routing data.
thinkgeo.mapsuite.routing.buildingroutingdatartgroutingsourceeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
