This layer can show start coordinates, end coordinates, a collection of in-between stops and the resulting paths with specified styles.
RoutingLayer(IEnumerable<LineShape>)
RoutingLayer(PointShape,PointShape,IEnumerable<PointShape>,IEnumerable<LineShape>)
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#XOffsetInPixelOfStopOrder
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#YOffsetInPixelOfStopOrder
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Routes
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#StartPoint
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#EndPoint
Gets a collection that holds the stop coordinates between StartPoint and EndPoint for routing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#StopPoints
If this property is not set, the default style is a small green marker representing the route start point.
If this property is not set, the default style is a small red marker representing the route end point.
If this property is not set, the default style is a small yellow marker representing a stop.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#StopTextStyle
If this property is not set, the default style is a purple pen with semitransparent color.
Gets and sets the value that represents whether to show the ordinal number of each of the StopPoints when drawing layer. The default value is true.
If this property is set to false, the text representing the sequence number of each stop will not be shown. This is ensured in the Draw method.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#RequestDrawingInterval
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsOpen
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#HasBoundingBox
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#DrawingTime
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Name
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#DrawAttributionCore.28GeoCanvas.2C_String.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsVisible
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#Transparency
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsNegative
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsGrayscale
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#DrawingExceptionMode
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#IsOpenCore
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnRequestedDrawing.28RequestedDrawingLayerEventArgs.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnRequestingDrawing.28RequestingDrawingLayerEventArgs.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnDrawingProgressChanged.28DrawingProgressChangedEventArgs.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnDrawingException.28DrawingExceptionLayerEventArgs.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnDrawnException.28DrawnExceptionLayerEventArgs.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnDrawingAttribution.28DrawingAttributionLayerEventArgs.29
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingLayer#OnDrawnAttribution.28DrawnAttributionLayerEventArgs.29
