This class is the base class for all types of RoutingSource.
GetRouteSegmentByFeatureId(String)
GetRouteSegmentsNearestTo(BaseShape,FeatureSource,GeographyUnit,Int32)
UpdateRouteSegment(RouteSegment)
OnCommittingTransaction(RoutingCommittingTransactionEventArgs)
OnCommittedTransaction(RoutingCommittedTransactionEventArgs)
GetRouteSegmentByFeatureIdCore(String)
GetRouteSegmentsNearestToCore(BaseShape,FeatureSource,GeographyUnit,Int32)
CommitTransactionCore(RoutingTransactionBuffer)
Various methods on the RoutingSource require that it be in an open state. If one of those methods is called when the state is not open, then the method will throw an exception. To enter the open state, you must call the RoutingSource's Open method.
This property returns true if the RoutingSource is in a transaction and false if it is not.
To enter a transaction, you must first call the BeginTransaction method of the RoutingSource. It is possible that some RoutingSource are read-only and do not allow edits. To end a transaction, you must either call CommitTransaction or RollbackTransaction.
This property returns whether the RoutingSource allows edits or is read-only.
This property is useful to check if a specific RoutingSource accepts editing. If you call BeginTransaction and this property is false, then an exception will be raised. For developers who are creating or extending a RoutingSource, it is expected that you override this virtual method if the new RoutingSource you are creating allows edits.
This event is raised after the CommitTransaction method is called, but before the CommitTransactionCore is called. This allows you access to the TransactionBuffer before the transaction is committed. It also allows you to cancel the pending commit of the transaction.
This event is raised before the CommitTransactionCore is called and allows you access to the TransactionBuffer before the transaction is committed. It also allows you to cancel the pending transaction. The TransactionBuffer is the object that stores all of the pending transactions and is accessible through this event to allow you to either add, remove or modify transactions. In the event that you cancel the CommitTransaction method, the transaction remains intact and you will still be editing. This makes it a nice place to possibly check for connectivity before the TransactionCore code is run, which is where the records are actually committed. Calling the RollBackTransaction method is the only way to permanently cancel a pending transaction without committing it.
Event Arguments:RoutingCommittingTransactionEventArgs
This event is raised after the CommitTransaction and the CommitTransactionCore are called and allows you access to the TransactionBuffer and the TransactionResults object before CommitTransaction method is returned.
This event is raised after the CommitTransactionCore is called and allows you access to the TransactionBuffer and the TransactionResults object before CommitTransaction method is returned. With this event, you can analyse the results of the transaction and do any cleanup code necessary. In the event some of the records did not commit, you can handle those items here. The TransactionResults object is passed out of the CommitTransaction method so you could analyze it then; however, this is the only place where you have access to both the TransactionResults object and the TransactionBuffer object at the same time. These are useful together to try and determine what went wrong and possibly try and re-commit them. At the time of this event you will technically be out of the current transaction.
Event Arguments:RoutingCommittedTransactionEventArgs
