thinkgeo.mapsuite.routing.routingcommittedtransactioneventargs
ThinkGeo.MapSuite.Routing.RoutingCommittedTransactionEventArgs
      • ThinkGeo.MapSuite.Routing.RoutingCommittedTransactionEventArgs
RoutingCommittedTransactionEventArgs(RoutingTransactionBuffer)
  • This is the constructor of the event arguments.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittedTransactionEventArgs#RoutingCommittedTransactionEventArgs.28RoutingTransactionBuffer.29
  • transactionBuffer
RoutingCommittedTransactionEventArgs()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittedTransactionEventArgs#RoutingCommittedTransactionEventArgs.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittedTransactionEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittedTransactionEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittedTransactionEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittedTransactionEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittedTransactionEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingCommittedTransactionEventArgs#MemberwiseClone.28.29
TransactionBuffer
This property returns the transaction buffer that has been committed.
thinkgeo.mapsuite.routing.routingcommittedtransactioneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
