thinkgeo.mapsuite.routing.dijkstraroutingalgorithm
ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm
This class represents a routing algorithm that is based on the Dijkstra algorithm.
    • ThinkGeo.MapSuite.Routing.RoutingAlgorithm
      • ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm
DijkstraRoutingAlgorithm()
  • This is a constructor for this class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm#DijkstraRoutingAlgorithm.28.29
GetRoute(RoutingSource,String,String)
  • This method returns a RoutingResult based on the extent you provided.
  • This method is the concrete wrapper for the abstract method GetRouteCore. This method gets the routing result based on the extent you provided. In this method, you are repsonsible for implementing a routing algorithm to get the path between two routeSegments.
  • Type:Collection<RouteSegment>
  • Description:Routing result that contains path information.
  • routingSource
    • Description:The routing source that contains the routeSegments to route on.
  • startFeatureId
    • Description:The feature ID which represents the starting routeSegment.
  • endFeatureId
    • Description:The feature ID which represents the ending routeSegment.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm#GetType.28.29
GetRouteCore(RoutingSource,String,String)
  • This abstract method is called from the concrete public method GetRoute. This method gets the routing result based on the extent you provided. In this method, you are repsonsible for implementing a routing algorithm to get the path between two routeSegments.
  • routingSource
  • startFeatureId
  • endFeatureId
OnFindingRoute(FindingRouteRoutingAlgorithmEventArgs)
  • This method allows you to raise the FindingRoute event from a derived class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm#OnFindingRoute.28FindingRouteRoutingAlgorithmEventArgs.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm#MemberwiseClone.28.29
GeographyUnit
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm#GeographyUnit
DistanceUnit
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.DijkstraRoutingAlgorithm#DistanceUnit
FindingRoute This event is called after finding the adjacent routeSegments.
Event Arguments:FindingRouteRoutingAlgorithmEventArgs
thinkgeo.mapsuite.routing.dijkstraroutingalgorithm.txt · Last modified: 2017/03/16 21:59 (external edit)
