thinkgeo.mapsuite.routing.findingrouteroutingalgorithmeventargs
ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs
This class represents the parameters passed out through the FindingRoute event.
      • ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs
FindingRouteRoutingAlgorithmEventArgs()
  • This is the default constructor.
FindingRouteRoutingAlgorithmEventArgs(RouteSegment)
  • This is the constructor that passed the routeSegment.
  • routeSegment
    • Description:The routeSegment that you want pass out by event.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#GetType.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.FindingRouteRoutingAlgorithmEventArgs#MemberwiseClone.28.29
RouteSegment
Gets or sets the value that represents the current routeSegment during route.
The default value is null if you call the default constructor.
IsPathTermination
Gets or sets the value that represents whether the current routeSegment is the terminus. The default value is false.
If you set the value to true, it will make the current routeSegment the terminus, which will break the route and return the path that has been routed thus far.
thinkgeo.mapsuite.routing.findingrouteroutingalgorithmeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
