thinkgeo.mapsuite.routing.routingengine
ThinkGeo.MapSuite.Routing.RoutingEngine
This class is for finding a route.
    • ThinkGeo.MapSuite.Routing.RoutingEngine
RoutingEngine()
  • The default settings are: RoutingSource is null, routingAlgorithm is Dijkstra, FeatureSource is null, GeographyUnit is DecimalDegree, DistanceUnit is Kilometer.
RoutingEngine(RoutingSource)
RoutingEngine(RoutingSource,FeatureSource)
RoutingEngine(RoutingSource,RoutingAlgorithm)
RoutingEngine(RoutingSource,RoutingAlgorithm,FeatureSource)
RoutingEngine(RoutingSource,RoutingAlgorithm,FeatureSource,GeographyUnit)
RoutingEngine(RoutingSource,RoutingAlgorithm,FeatureSource,GeographyUnit,DistanceUnit)
GetRouteSegments(String,String)
  • This method returns a sequential routeSegments collection consisting of the route based on RoutingSource and does not use a FeatureSource.
  • This method for users who don't know the feature source. If the user knows the feature source, they should use GetRoute to get more information. This method is one of the most common routing requirements for a simple path, wherein a customer inputs two feature IDs that represent routeSegments and then finds a route. The route will be calculated from a specified start routeSegment to a specified end routeSegment.
  • startFeatureId
    • Description:This parameter is the start point of the route.
  • endFeatureId
    • Description:This parameter is the end point of the route.
GetRoute(PointShape,PointShape)
  • This method returns the routing path based on two points.
  • This method generates turn-by-turn driving directions for any route. It cannot be changed by overriding GetRouteCore. This method is for users who know the feature source. If the user does not know the feature source, they should use GetRouteSegments instead. This method is one of the most common routing requirements for a simple path, wherein a customer inputs two points and then finds a route. The route will be calculated from a specified start point to a specified end point.
  • startPoint
    • Description:This parameter is the start point which represents a routeSegment for the start of the route.
  • endPoint
    • Description:This parameter is the end point which represents a routeSegment for the end of the route.
GetRoute(PointShape,IEnumerable<PointShape>)
  • For the most updated Info for this topic, please check it here:
  • stops
GetRoute(PointShape,IEnumerable<PointShape>,Int32)
  • stops
  • iterations
GetRoute(PointShape,PointShape,IEnumerable<PointShape>)
  • stops
GetRoute(PointShape,PointShape,IEnumerable<PointShape>,Int32)
  • stops
  • iterations
GetRoute(String,IEnumerable<String>)
  • startFeatureId
  • stopFeatureIds
    • Type:IEnumerable<String>
GetRoute(String,IEnumerable<String>,Int32)
  • startFeatureId
  • stopFeatureIds
  • iterations
GetRoute(String,String)
  • This method returns the routing path based on two feature IDs that represent two routeSegments.
  • This method generates turn-by-turn driving directions for any route. It cannot be changed by overriding GetRouteCore. This method is for users who know the feature source. If the user does not know the feature source, they should use GetRouteSegments instead. This method is one of the most common routing requirements for a simple path, wherein a customer inputs two feature IDs that represent routeSegments and gets back a route. The route will be calculated from a specified start routeSegment to a specified end routeSegment.
  • startFeatureId
    • Description:This parameter is the start feature ID which represents a routeSegment for the start of the route.
  • endFeatureId
    • Description:This parameter is the end feature ID which represents a routeSegment for the end of the route.
GetRoute(String,String,IEnumerable<String>)
  • startFeatureId
  • endFeatureId
  • stopFeatureIds
GetRoute(String,String,IEnumerable<String>,Int32)
  • startFeatureId
  • endFeatureId
  • stopFeatureIds
  • iterations
GenerateServiceArea(PointShape,TimeSpan)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#GenerateServiceArea.28PointShape.2C_TimeSpan.29
  • drivingTime
    • Type:TimeSpan
GenerateServiceArea(PointShape,TimeSpan,Double,GeographyUnit)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#GenerateServiceArea.28PointShape.2C_TimeSpan.2C_Double.2C_GeographyUnit.29
  • drivingTime
    • Type:TimeSpan
  • gridSize
GenerateServiceArea(String,TimeSpan)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#GenerateServiceArea.28String.2C_TimeSpan.29
  • centerFeatureId
  • drivingTime
    • Type:TimeSpan
GenerateServiceArea(String,TimeSpan,Double,GeographyUnit)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#GenerateServiceArea.28String.2C_TimeSpan.2C_Double.2C_GeographyUnit.29
  • centerFeatureId
  • drivingTime
    • Type:TimeSpan
  • gridSize
GenerateServiceArea(Double,Double,TimeSpan,Single,SpeedUnit)
  • This method returns a polygon that represents the service area around any location on a map.
  • You can define service ranges based on limits of speed and time. A service area is a region that encompasses all accessible routes (such as streets). The default geography unit for a feature source is decimal degrees. The default distance unit for the average speed is kilometers. For example, the 5-minute service area for a point includes all the streets that can be reached within five minutes from that point.
  • Description:A polygon that represents the service area.
  • centerX
    • Description:This parameter is the x coordinate of center point that represents the center of the service area.
  • centerY
    • Description:This parameter is the y coordinate of center point that represents the center of the service area.
  • drivingTime
    • Type:TimeSpan
    • Description:This parameter represents the time interval used to find the boundaries of the service area.
  • averageSpeed
    • Type:Single
    • Description:This parameter represents the average speed traveled inside the service area.
  • speedUnit
    • Type:SpeedUnit
    • Description:This parameter represents the unit of average speed traveled inside the service area.
GenerateServiceArea(PointShape,TimeSpan,Single,SpeedUnit)
  • centerPoint
    • Description:This parameter is the point that represents the center of the service area.
  • drivingTime
    • Type:TimeSpan
  • averageSpeed
    • Type:Single
  • speedUnit
    • Type:SpeedUnit
GenerateServiceArea(PointShape,TimeSpan,Single,SpeedUnit,Double,GeographyUnit)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#GenerateServiceArea.28PointShape.2C_TimeSpan.2C_Single.2C_SpeedUnit.2C_Double.2C_GeographyUnit.29
  • drivingTime
    • Type:TimeSpan
  • averageSpeed
    • Type:Single
  • gridSize
GenerateServiceArea(String,TimeSpan,Single,SpeedUnit)
  • centerFeatureId
    • Description:This parameter is the feature ID that represents the center of the service area.
  • drivingTime
    • Type:TimeSpan
  • averageSpeed
    • Type:Single
  • speedUnit
    • Type:SpeedUnit
GenerateServiceArea(String,TimeSpan,Single,SpeedUnit,Double,GeographyUnit)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#GenerateServiceArea.28String.2C_TimeSpan.2C_Single.2C_SpeedUnit.2C_Double.2C_GeographyUnit.29
  • centerFeatureId
  • drivingTime
    • Type:TimeSpan
  • averageSpeed
    • Type:Single
  • gridSize
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#GetType.28.29
GetAngleBetweenTwoLines(LineShape,LineShape)
  • This method returns the angle between two lines.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#GetAngleBetweenTwoLines.28LineShape.2C_LineShape.29
  • Description:The angle from first to the end line shape
  • fromLine
    • Type:LineShape
    • Description:This parameter is the line that the angle is caucluated from
  • toLine
    • Type:LineShape
    • Description:The parameter is the other line used to calculate the angle besed on the from line
GetDrivingDirection(LineShape,LineShape)
  • This method returns the DrivingDirection based on the from line shape.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#GetDrivingDirection.28LineShape.2C_LineShape.29
  • Description:The driving direction from the first to then end line shape.
  • fromLine
    • Type:LineShape
    • Description:This parameter is the line that DrivingDirection is caucluated from
  • toLine
    • Type:LineShape
    • Description:This parameter is the other line used to calculate the direction based on the from line shape
GetRouteCore(String,String,IEnumerable<String>,Int32)
  • startFeatureId
  • endFeatureId
  • stopFeatureIds
  • iterations
GetRouteCoreWithPoints(PointShape,PointShape,IEnumerable<PointShape>,Int32)
  • stops
  • iterations
OnGettingRouteViaVisitStops(GettingRouteViaVisitStopsRoutingEngineEventArgs)
  • This method allows you to raise the GetRouteViaVisitStops event from a derived class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#OnGettingRouteViaVisitStops.28GettingRouteViaVisitStopsRoutingEngineEventArgs.29
OnGeneratingServiceArea(GeneratingServiceAreaRoutingEngineEventArgs)
  • This method allows you to raise the GeneratingServiceArea event from a derived class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#OnGeneratingServiceArea.28GeneratingServiceAreaRoutingEngineEventArgs.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#Finalize.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#MemberwiseClone.28.29
RoutingAlgorithm
Gets or sets a value that represents the routingAlgorithm used for finding the route.
RoutingSource
Gets or sets a routingSource object for finding the route.
GeographyUnit
Gets or sets a value that represents the geography unit of the FeatureSource.
DistanceUnit
Gets or sets a value that represents the distance unit of the route.
FeatureSource
Gets or sets a value that represents the FeatureSource used for finding the route.
RoutingResultsType
Gets or sets a value that represents how much data is returned in the routing results.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.Routing.RoutingEngine#RoutingResultsType
GeneratingServiceArea This event is called during the generating service area.
This event is called during the generating service area. It wil be called many times during call the GenerateServiceArea method.
Event Arguments:GeneratingServiceAreaRoutingEngineEventArgs
GettingRouteViaVisitStops This event is called during the calculating best visit sequence
This event is called during the calculating best visit sequence. It wil be called many times during calling the GetRouteViaVisitStops method.
Event Arguments:GettingRouteViaVisitStopsRoutingEngineEventArgs
thinkgeo.mapsuite.routing.routingengine.txt · Last modified: 2017/03/16 21:59 (external edit)
