thinkgeo.mapsuite.iosedition
ThinkGeo.MapSuite.iOSEdition
iOSEdition
Classes
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
  • AdornmentOverlay
    This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
B
  • BingMapsOverlay
    This class represents an overlay that requesting from Bing Maps Imagery Service.
  • BingMapsTileOverlay
C
D
E
  • EditEndedEditInteractiveOverlayEventArgs
    Class EditEndedEditInteractiveOverlayEventArgs.
  • EditInteractiveOverlay
  • ExtentInteractiveOverlay
    This class inherits from InterativeOverlay abstract class. This specified overlay describle the Extent Changing interative process with MapControl using Mouse or Keyborad.
F
G
I
  • InteractionArguments
    This class encapsulates the information and simple method for interactive actions.
  • InteractiveOverlay
    This class inherits from Overlay abstract class. This specified overlay describe the interactive process with MapControl using Mouse or Keyboard.
  • InteractiveResult
    This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay.
L
  • LayerOverlay
    This class represents a group of layers; each layer can be of any layer type.
  • LayerTileView
    Represents an TileView that maintains one Layer.
M
  • MapArguments
    Contains important properties and methods of current map object.
  • MapBoxOverlay
    Class MapBoxTileOverlay.
  • MapTool
    This class represents the base class of map tool controls.
  • MapTools
    Contains the different map tools as properties and acts as an entrance for setting these map controls.
  • MapView
    This class represents the map control.
  • Marker
    Represents a marker control on the map.
  • MarkerOverlay
    This class represents an overlay which maintaining markers.
O
  • OpenStreetMapOverlay
    This class represents an overlay that requesting images from OpenStreet Map Service.
  • OpenStreetMapTileOverlay
  • Overlay
    This class is the base class of all overlays in this overlay system.
P
  • Popup
    This class represents a popup control for placing on the map.
  • PopupOverlay
    This class represents an overlay to place popups on the map.
S
T
U
  • UriTileView
    Represents a tile for requesting from an Uri.
V
W
  • WmsOverlay
    Represents an overlay object that gets map images from the WMS server you specify.
  • WorldMapKitOverlay
    This class represents an WmsOverlay which has MapSuite world map kit server integrated.
Z
Structures
Enums
C
  • ControlPointType
    This enumeration specified the control point type when editing a shape. The deafault value is None
E
  • ExtentChangedType
    This enumeration specifies the type of extent change that has occurred when doing interactive actions with InterativeOverlay.
I
  • InteractiveOverlayDrawType
    This enumeration specifies the mode to draw the InterativeOverlay when doing interactive actions with InterativeOverlay.
L
M
O
P
  • ProcessOtherOverlaysMode
    This enumeration specifies the mode to process other overlays when doing interactive actions with InterativeOverlay.
T
  • TileSnappingMode
    Enum TileSnappingMode
  • TileType
    This enum represents the tile type in the tile overlay.
  • TrackMode
    TrackMode enumeration sets how the map will react to user interaction.
  • TransitionEffect
    This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
Interfaces
thinkgeo.mapsuite.iosedition.1442997043.txt.gz · Last modified: 2015/09/23 08:30 by admin
