thinkgeo.mapsuite.iosedition.vertexaddingtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.iOSEdition.VertexAddingTrackInteractiveOverlayEventArgs
Provides data for the VertexAdding. event.
      • ThinkGeo.MapSuite.iOSEdition.VertexAddingTrackInteractiveOverlayEventArgs
VertexAddingTrackInteractiveOverlayEventArgs()
VertexAddingTrackInteractiveOverlayEventArgs(Vertex,Feature,Boolean)
  • addingVertex
    • Type:Vertex
    • Description:This parameter specified the vertex is going to be added.
  • affectedFeature
    • Type:Feature
    • Description:This parameter specified the feature to be used to add vertex on when tracking shape.
  • cancel
Cancel
AddingVertex
This property gets or sets the feature to be used to add vertex on when tracking shape.
AffectedFeature
This property gets or sets the Feature to be used to add vertex to.
thinkgeo.mapsuite.iosedition.vertexaddingtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
