thinkgeo.mapsuite.iosedition.maparguments
ThinkGeo.MapSuite.iOSEdition.MapArguments
Contains important properties and methods of current map object.
    • ThinkGeo.MapSuite.iOSEdition.MapArguments
MapArguments()
MapArguments(RectangleShape,GeographyUnit,Single,Single)
  • screenWidth
    • Type:Single
    • Description:Width of the screen.
  • screenHeight
    • Type:Single
    • Description:Height of the screen.
CurrentExtent
Gets or sets the current extent.
MapUnit
Gets or sets the GeographyUnit for the map.
ScreenWidth
Gets or sets the width of current map object in screen coordinate.
  • Type:nfloat
ScreenHeight
Gets or sets the height of current map object in screen coordinate.
  • Type:nfloat
CurrentScale
Gets or sets a double value that indicates the current scale of the map.
MaximumScale
MinimumScale
CurrentResolution
Gets or sets a double value that indicates the current resolution of the map.
ZoomLevelSet
Gets or sets the zoom level set.
CustomData
Gets the custom data.
  • Type:Dictionary<String,Object>
thinkgeo.mapsuite.iosedition.maparguments.txt · Last modified: 2017/03/16 21:59 (external edit)
