thinkgeo.mapsuite.iosedition.mapview
ThinkGeo.MapSuite.iOSEdition.MapView
This class represents the map control.
    • Foundation.NSObject
      • UIKit.UIResponder
        • UIKit.UIView
          • ThinkGeo.MapSuite.iOSEdition.MapView
MapView()
MapView(CGRect)
This constructor is used to programmatically create a new instance of UIView with the specified dimension in the frame. The object will only be displayed once it has been added to a view hierarchy by calling AddSubview in a containing view.This constructor is not invoked when deserializing objects from storyboards or XIB filesinstead the constructor that takes an NSCoder parameter is invoked.
  • frame
    • Type:CGRect
    • Description:Frame used by the view, expressed in iOS points.
LayoutSubviews()
Close()
Closes this instance.
GetSnappedZoomLevelIndex(Double)
Gets the index of the snapped zoom level.
  • scale
    • Description:The scale.
CenterAt(Feature)
Locates the map center to the specified feature.
  • feature
    • Type:Feature
    • Description:The feature.
CenterAt(Double,Double)
Locates the map center to the specified world point.
  • worldX
    • Description:The world x.
  • worldY
    • Description:The world y.
CenterAt(PointShape)
  • worldCenter
Pan(PanDirection,Int32)
Pans the specified direction.
  • percentage
    • Description:The percentage.
Refresh(IEnumerable<Overlay>)
Refreshes the specified overlays.
  • overlays
    • Type:IEnumerable<Overlay>
    • Description:The overlays.
Refresh()
Refreshes this instance.
ZoomIn(Int32)
Zooms the map in for one level.
  • percentage
ZoomOut(Int32)
Zooms the map in by the provided percentage.
  • percentage
ZoomTo(Feature)
Zooms the map to specified feature.
  • feature
    • Type:Feature
ZoomTo(BaseShape)
  • targetShape
    • Type:BaseShape
    • Description:The target shape.
ZoomToScale(Double)
Zooms the map to specified scale.
  • targetScale
    • Description:The target scale.
ZoomTo(PointShape,Double)
This method zooms current map to a specified position and scale.
When calling this method, it doesn't refresh existing Tiles on the current map. For example, if using a TileOverlay such as LayerOverlay; a layer style is changed, Refresh method is proper to call.
  • worldCenter
    • Description:A world center to zoom the map to.
  • scale
    • Description:A double value indicates the scale to zoom the map to.
ZoomInByAnchorPoint(ScreenPointF)
Zooms the in by anchor point.
  • touchPosition
ToWorldCoordinate(ScreenPointF)
Converts the provided screen points to world points.
  • Description:A world coordinate that is converted.
  • screenCoordinate
    • Description:Screen point to be converted.
ToScreenCoordinate(PointShape)
Converts the provided world points to screen points.
  • Description:A screen coordinate that is converted.
  • worldCoordinate
    • Description:World point to be converted.
ZoomToPreviousExtent()
Zooms to previous extent.
ZoomToNextExtent()
Zooms to next extent.
SystemLayoutSizeFittingSize(CGSize,Single,Single)
  • Type:CGSize
  • targetSize
    • Type:CGSize
  • horizontalFittingPriority
    • Type:Single
  • verticalFittingPriority
    • Type:Single
TintColorDidChange()
TraitCollectionDidChange(UITraitCollection)
  • previousTraitCollection
    • Type:UITraitCollection
UpdateConstraints()
UpdateConstraintsIfNeeded()
ViewWithTag(nint)
  • Type:UIView
  • tag
    • Type:nint
WillMoveToSuperview(UIView)
  • newsuper
    • Type:UIView
WillMoveToWindow(UIWindow)
  • window
    • Type:UIWindow
WillRemoveSubview(UIView)
  • uiview
    • Type:UIView
Add(UIView)
  • view
    • Type:UIView
AddSubviews(UIView[])
  • views
    • Type:UIView[]
GetEnumerator()
  • Type:IEnumerator
AccessibilityActivate()
AddConstraint(NSLayoutConstraint)
  • constraint
    • Type:NSLayoutConstraint
AddConstraints(NSLayoutConstraint[])
  • constraints
    • Type:NSLayoutConstraint[]
AddGestureRecognizer(UIGestureRecognizer)
  • gestureRecognizer
    • Type:UIGestureRecognizer
AddMotionEffect(UIMotionEffect)
  • effect
    • Type:UIMotionEffect
AddSubview(UIView)
  • view
    • Type:UIView
AlignmentRectForFrame(CGRect)
  • Type:CGRect
  • frame
    • Type:CGRect
BringSubviewToFront(UIView)
  • view
    • Type:UIView
ContentCompressionResistancePriority(UILayoutConstraintAxis)
  • Type:Single
  • axis
    • Type:UILayoutConstraintAxis
ContentHuggingPriority(UILayoutConstraintAxis)
  • Type:Single
  • axis
ConvertPointFromCoordinateSpace(CGPoint,IUICoordinateSpace)
  • Type:CGPoint
  • point
    • Type:CGPoint
  • coordinateSpace
    • Type:IUICoordinateSpace
ConvertPointFromView(CGPoint,UIView)
  • Type:CGPoint
  • point
    • Type:CGPoint
  • fromView
    • Type:UIView
ConvertPointToCoordinateSpace(CGPoint,IUICoordinateSpace)
  • Type:CGPoint
  • point
    • Type:CGPoint
  • coordinateSpace
ConvertPointToView(CGPoint,UIView)
  • Type:CGPoint
  • point
    • Type:CGPoint
  • toView
    • Type:UIView
ConvertRectFromCoordinateSpace(CGRect,IUICoordinateSpace)
  • Type:CGRect
  • rect
    • Type:CGRect
  • coordinateSpace
ConvertRectFromView(CGRect,UIView)
  • Type:CGRect
  • rect
    • Type:CGRect
  • fromView
    • Type:UIView
ConvertRectToCoordinateSpace(CGRect,IUICoordinateSpace)
  • Type:CGRect
  • rect
    • Type:CGRect
  • coordinateSpace
ConvertRectToView(CGRect,UIView)
  • Type:CGRect
  • rect
    • Type:CGRect
  • toView
    • Type:UIView
DecodeRestorableState(NSCoder)
  • coder
    • Type:NSCoder
Draw(CGRect)
  • rect
    • Type:CGRect
DrawRect(CGRect,UIViewPrintFormatter)
  • area
    • Type:CGRect
  • formatter
    • Type:UIViewPrintFormatter
DrawViewHierarchy(CGRect,Boolean)
  • rect
    • Type:CGRect
  • afterScreenUpdates
EncodeRestorableState(NSCoder)
  • coder
    • Type:NSCoder
EncodeTo(NSCoder)
  • encoder
    • Type:NSCoder
ExchangeSubview(nint,nint)
  • atIndex
    • Type:nint
  • withSubviewAtIndex
    • Type:nint
ExerciseAmbiguityInLayout()
FrameForAlignmentRect(CGRect)
  • Type:CGRect
  • alignmentRect
    • Type:CGRect
GestureRecognizerShouldBegin(UIGestureRecognizer)
  • gestureRecognizer
GetConstraintsAffectingLayout(UILayoutConstraintAxis)
  • axis
HitTest(CGPoint,UIEvent)
  • Type:UIView
  • point
    • Type:CGPoint
  • uievent
    • Type:UIEvent
InsertSubview(UIView,nint)
  • view
    • Type:UIView
  • atIndex
    • Type:nint
InsertSubviewAbove(UIView,UIView)
  • view
    • Type:UIView
  • siblingSubview
    • Type:UIView
InsertSubviewBelow(UIView,UIView)
  • view
    • Type:UIView
  • siblingSubview
    • Type:UIView
InvalidateIntrinsicContentSize()
IsDescendantOfView(UIView)
  • view
    • Type:UIView
LayoutIfNeeded()
LayoutMarginsDidChange()
MovedToSuperview()
MovedToWindow()
NeedsUpdateConstraints()
PointInside(CGPoint,UIEvent)
  • point
    • Type:CGPoint
  • uievent
    • Type:UIEvent
RemoveConstraint(NSLayoutConstraint)
  • constraint
RemoveConstraints(NSLayoutConstraint[])
  • constraints
RemoveFromSuperview()
RemoveGestureRecognizer(UIGestureRecognizer)
  • gestureRecognizer
RemoveMotionEffect(UIMotionEffect)
  • effect
ResizableSnapshotView(CGRect,Boolean,UIEdgeInsets)
  • Type:UIView
  • rect
    • Type:CGRect
  • capInsets
    • Type:UIEdgeInsets
SendSubviewToBack(UIView)
  • view
    • Type:UIView
SetContentCompressionResistancePriority(Single,UILayoutConstraintAxis)
  • priority
    • Type:Single
  • axis
SetContentHuggingPriority(Single,UILayoutConstraintAxis)
  • priority
    • Type:Single
  • axis
SetNeedsDisplay()
SetNeedsDisplayInRect(CGRect)
  • rect
    • Type:CGRect
SetNeedsLayout()
SetNeedsUpdateConstraints()
SizeThatFits(CGSize)
  • Type:CGSize
  • size
    • Type:CGSize
SizeToFit()
SnapshotView(Boolean)
  • Type:UIView
SubviewAdded(UIView)
  • uiview
    • Type:UIView
SystemLayoutSizeFittingSize(CGSize)
  • Type:CGSize
  • size
    • Type:CGSize
AccessibilityDecrement()
AccessibilityElementDidBecomeFocused()
AccessibilityElementDidLoseFocus()
AccessibilityElementIsFocused()
AccessibilityIncrement()
AccessibilityPerformEscape()
AccessibilityPerformMagicTap()
AccessibilityScroll(UIAccessibilityScrollDirection)
  • direction
    • Type:UIAccessibilityScrollDirection
BecomeFirstResponder()
CanPerform(Selector,NSObject)
  • action
    • Type:Selector
  • withSender
    • Type:NSObject
Copy(NSObject)
  • sender
    • Type:NSObject
Cut(NSObject)
  • sender
    • Type:NSObject
Delete(NSObject)
  • sender
    • Type:NSObject
GetTargetForAction(Selector,NSObject)
  • Type:NSObject
  • action
    • Type:Selector
  • sender
    • Type:NSObject
MakeTextWritingDirectionLeftToRight(NSObject)
  • sender
    • Type:NSObject
MakeTextWritingDirectionRightToLeft(NSObject)
  • sender
    • Type:NSObject
MotionBegan(UIEventSubtype,UIEvent)
  • motion
    • Type:UIEventSubtype
  • evt
    • Type:UIEvent
MotionCancelled(UIEventSubtype,UIEvent)
  • motion
  • evt
    • Type:UIEvent
MotionEnded(UIEventSubtype,UIEvent)
  • motion
  • evt
    • Type:UIEvent
Paste(NSObject)
  • sender
    • Type:NSObject
ReloadInputViews()
RemoteControlReceived(UIEvent)
  • theEvent
    • Type:UIEvent
ResignFirstResponder()
RestoreUserActivityState(NSUserActivity)
  • activity
    • Type:NSUserActivity
Select(NSObject)
  • sender
    • Type:NSObject
SelectAll(NSObject)
  • sender
    • Type:NSObject
ToggleBoldface(NSObject)
  • sender
    • Type:NSObject
ToggleItalics(NSObject)
  • sender
    • Type:NSObject
ToggleUnderline(NSObject)
  • sender
    • Type:NSObject
TouchesBegan(NSSet,UIEvent)
  • touches
    • Type:NSSet
  • evt
    • Type:UIEvent
TouchesCancelled(NSSet,UIEvent)
  • touches
    • Type:NSSet
  • evt
    • Type:UIEvent
TouchesEnded(NSSet,UIEvent)
  • touches
    • Type:NSSet
  • evt
    • Type:UIEvent
TouchesMoved(NSSet,UIEvent)
  • touches
    • Type:NSSet
  • evt
    • Type:UIEvent
UpdateUserActivityState(NSUserActivity)
  • activity
PerformSelector(Selector,NSThread,NSObject,Boolean,NSString[])
  • selector
    • Type:Selector
  • onThread
    • Type:NSThread
  • withObject
    • Type:NSObject
  • waitUntilDone
  • nsRunLoopModes
    • Type:NSString[]
PerformSelector(Selector)
  • Type:NSObject
  • aSelector
    • Type:Selector
PerformSelector(Selector,NSObject)
  • Type:NSObject
  • aSelector
    • Type:Selector
  • anObject
    • Type:NSObject
PerformSelector(Selector,NSObject,NSObject)
  • Type:NSObject
  • aSelector
    • Type:Selector
  • object1
    • Type:NSObject
  • object2
    • Type:NSObject
RemoveObserver(NSObject,NSString,IntPtr)
  • observer
    • Type:NSObject
  • keyPath
    • Type:NSString
  • context
    • Type:IntPtr
RemoveObserver(NSObject,String,IntPtr)
  • observer
    • Type:NSObject
  • keyPath
  • context
    • Type:IntPtr
RemoveObserver(NSObject,NSString)
  • observer
    • Type:NSObject
  • keyPath
    • Type:NSString
RemoveObserver(NSObject,String)
  • observer
    • Type:NSObject
  • keyPath
RespondsToSelector(Selector)
  • sel
    • Type:Selector
SetNilValueForKey(NSString)
  • key
    • Type:NSString
SetValueForKey(NSObject,NSString)
  • value
    • Type:NSObject
  • key
    • Type:NSString
SetValueForKeyPath(NSObject,NSString)
  • value
    • Type:NSObject
  • keyPath
    • Type:NSString
SetValueForUndefinedKey(NSObject,NSString)
  • value
    • Type:NSObject
  • undefinedKey
    • Type:NSString
SetValuesForKeysWithDictionary(NSDictionary)
  • keyedValues
    • Type:NSDictionary
  • Type:NSObject
  • key
    • Type:NSString
ValueForKeyPath(NSString)
  • Type:NSObject
  • keyPath
    • Type:NSString
ValueForUndefinedKey(NSString)
  • Type:NSObject
  • key
    • Type:NSString
WillChange(NSKeyValueChange,NSIndexSet,NSString)
  • changeKind
    • Type:NSKeyValueChange
  • indexes
    • Type:NSIndexSet
  • forKey
    • Type:NSString
WillChange(NSString,NSKeyValueSetMutationKind,NSSet)
  • forKey
    • Type:NSString
  • mutationKind
    • Type:NSKeyValueSetMutationKind
  • objects
    • Type:NSSet
WillChangeValue(String)
  • forKey
Dispose()
ConformsToProtocol(IntPtr)
  • protocol
    • Type:IntPtr
DangerousRelease()
DangerousRetain()
  • Type:NSObject
DangerousAutorelease()
  • Type:NSObject
GetNativeField(String)
  • Type:NSObject
  • name
SetNativeField(String,NSObject)
  • name
  • value
    • Type:NSObject
AwakeFromNib()
BeginInvokeOnMainThread(Selector,NSObject)
  • sel
    • Type:Selector
    • Type:NSObject
  • sel
    • Type:Selector
    • Type:NSObject
BeginInvokeOnMainThread(Action)
  • action
    • Type:Action
  • action
    • Type:Action
SetValueForKeyPath(IntPtr,NSString)
  • handle
    • Type:IntPtr
  • keyPath
    • Type:NSString
Equals(NSObject)
    • Type:NSObject
Invoke(Action,Double)
  • action
    • Type:Action
  • delay
Invoke(Action,TimeSpan)
  • action
    • Type:Action
  • delay
    • Type:TimeSpan
AddObserver(String,NSKeyValueObservingOptions,Action<NSObservedChange>)
  • Type:IDisposable
  • key
  • options
    • Type:NSKeyValueObservingOptions
  • observer
    • Type:Action<NSObservedChange>
AddObserver(NSString,NSKeyValueObservingOptions,Action<NSObservedChange>)
  • Type:IDisposable
  • key
    • Type:NSString
  • options
  • observer
Init()
AddObserver(NSObject,NSString,NSKeyValueObservingOptions,IntPtr)
  • observer
    • Type:NSObject
  • keyPath
    • Type:NSString
  • options
  • context
    • Type:IntPtr
AddObserver(NSObject,String,NSKeyValueObservingOptions,IntPtr)
  • observer
    • Type:NSObject
  • keyPath
  • options
  • context
    • Type:IntPtr
Copy()
  • Type:NSObject
DidChange(NSKeyValueChange,NSIndexSet,NSString)
  • changeKind
  • indexes
    • Type:NSIndexSet
  • forKey
    • Type:NSString
DidChange(NSString,NSKeyValueSetMutationKind,NSSet)
  • forKey
    • Type:NSString
  • mutationKind
  • objects
    • Type:NSSet
DidChangeValue(String)
  • forKey
DoesNotRecognizeSelector(Selector)
  • sel
    • Type:Selector
GetDictionaryOfValuesFromKeys(NSString[])
  • Type:NSDictionary
  • keys
    • Type:NSString[]
GetNativeHash()
  • Type:nuint
IsEqual(NSObject)
  • anObject
    • Type:NSObject
IsKindOfClass(Class)
  • aClass
    • Type:Class
IsMemberOfClass(Class)
  • aClass
    • Type:Class
MutableCopy()
  • Type:NSObject
ObserveValue(NSString,NSObject,NSDictionary,IntPtr)
  • keyPath
    • Type:NSString
  • ofObject
    • Type:NSObject
  • change
    • Type:NSDictionary
  • context
    • Type:IntPtr
PerformSelector(Selector,NSObject,Double,NSString[])
  • selector
    • Type:Selector
  • withObject
    • Type:NSObject
  • afterDelay
  • nsRunLoopModes
    • Type:NSString[]
PerformSelector(Selector,NSObject,Double)
  • selector
    • Type:Selector
  • withObject
    • Type:NSObject
  • delay
PerformSelector(Selector,NSThread,NSObject,Boolean)
  • selector
    • Type:Selector
  • onThread
    • Type:NSThread
  • withObject
    • Type:NSObject
  • waitUntilDone
OnLongPress(UIGestureRecognizer)
Called when [long press].
  • e
    • Description:The e.
OnSingleTap(UIGestureRecognizer)
Called when [single tap].
  • e
OnDoubleTap(UIGestureRecognizer)
Called when [double tap].
  • e
OnTouchMove(UIGestureRecognizer)
Called when [touch move].
  • e
OnTouchUp(UIGestureRecognizer)
Called when [touch up].
  • e
OnTouchDown(UIGestureRecognizer)
Called when [touch down].
  • e
OnTouchPinch(UIGestureRecognizer)
Called when [touch pinch].
  • e
Dispose(Boolean)
Releases the resources used by the UIView object.
This Dispose method releases the resources used by the UIView class.This method is called by both the Dispose() method and the object finalizer (Finalize). When invoked by the Dispose method, the parameter disposing is set to and any managed object references that this object holds are also disposed or released; when invoked by the object finalizer, on the finalizer thread the value is set to . Calling the Dispose method when you are finished using the UIView ensures that all external resources used by this managed object are released as soon as possible. Once you have invoked the Dispose method, the object is no longer useful and you should no longer make any calls to it. For more information on how to override this method and on the Dispose/IDisposable pattern, read the ``Implementing a Dispose Method'' document at http:msdn.microsoft.com/en-us/library/fs2xkftw.aspx
  • disposing
    • Description:If set to , the method is invoked directly and will dispose manage and unmanaged resources; If set to the method is being called by the garbage collector finalizer and should only release unmanaged resources.
PanCore(PanDirection,Int32)
This function will pan the currentExtent based on a direction and percentage.
This method will change the current extent by panning according to the direction and percentage specified.
  • Description:None.
  • direction
    • Description:This parameter is the direction in which you want to pan.
  • percentage
    • Description:This parameter is the percentage by which you want to pan.
RefreshCore()
Refreshes current map control.
Refreshes all the existing overlays and map tools.
ZoomInCore(Int32)
  • percentage
    • Description:A scale to zoom the map in.
ZoomOutCore(Int32)
Zooms the map out by the provided percentage.
  • percentage
ZoomInByAnchorPointCore(ScreenPointF)
Zooms the in by anchor point core.
  • touchPosition
ZoomToCore(RectangleShape)
Zooms the map in by the provided extent and locates to extent.
ZoomToScaleCore(Double)
This method zooms current map to a specified scale.
  • targetScale
OnCurrentExtentChanged(CurrentExtentChangedMapViewEventArgs)
Raises the event.
OnCurrentExtentChanging(CurrentExtentChangingMapViewEventArgs)
Raises the event.
OnCurrentScaleChanging(CurrentScaleChangingMapViewEventArgs)
Raises the event.
OnCurrentScaleChanged(CurrentScaleChangedMapViewEventArgs)
Raises the event.
MarkDirty()
InitializeHandle(IntPtr)
  • handle
    • Type:IntPtr
InitializeHandle(IntPtr,String)
  • handle
    • Type:IntPtr
  • initSelector
ClearHandle()
CurrentExtent
Gets or sets the current extent for the MapControl.
RestrictExtent
CurrentScale
Gets the current scale for the MapControl.
AdornmentOverlay
Gets the adornment overlay for the MapControl.
EditOverlay
Gets or sets the edit overlay for the MapControl.
ExtentOverlay
Gets or sets the extent overlay for the MapControl.
InteractiveOverlays
MapUnit
Gets or sets the map unit for the MapControl.
Overlays
Gets the overlays for the MapControl.
  • Type:UIView
TrackOverlay
Gets or sets the track overlay for the MapControl.
ZoomLevelSet
Gets or sets the zoom level set for the MapControl.
MinimumScale
This property gets and sets a minimum scale when navigating the map. When you keep zooming in, and the target scale is smaller than the minimum scale, the zooming operation will be stopped.
MaximumScale
This property gets and sets a maximum scale when navigating the map. When you keep zooming out, and the target scale is bigger than the maximum scale, the zooming operation will be stopped.
ClassHandle
  • Type:IntPtr
AccessibilityActivationPoint
  • Type:CGPoint
AccessibilityElementsHidden
AccessibilityFrame
  • Type:CGRect
AccessibilityHint
AccessibilityIdentifier
AccessibilityLabel
AccessibilityLanguage
AccessibilityNavigationStyle
  • Type:UIAccessibilityNavigationStyle
AccessibilityPath
  • Type:UIBezierPath
AccessibilityTraits
  • Type:UIAccessibilityTrait
AccessibilityValue
AccessibilityViewIsModal
AlignmentRectInsets
  • Type:UIEdgeInsets
Alpha
  • Type:nfloat
AutoresizingMask
  • Type:UIViewAutoresizing
AutosizesSubviews
BackgroundColor
  • Type:UIColor
Bounds
  • Type:CGRect
Center
  • Type:CGPoint
ClearsContextBeforeDrawing
ClipsToBounds
Constraints
ContentMode
  • Type:UIViewContentMode
ContentScaleFactor
  • Type:nfloat
ContentStretch
  • Type:CGRect
ExclusiveTouch
Frame
  • Type:CGRect
GestureRecognizers
  • Type:UIGestureRecognizer[]
HasAmbiguousLayout
Hidden
  • Type:CGSize
IsAccessibilityElement
Layer
  • Type:CALayer
LayoutMargins
  • Type:UIEdgeInsets
MaskView
  • Type:UIView
MotionEffects
  • Type:UIMotionEffect[]
MultipleTouchEnabled
Opaque
PreservesSuperviewLayoutMargins
RestorationIdentifier
ShouldGroupAccessibilityChildren
Subviews
  • Type:UIView[]
Superview
  • Type:UIView
Tag
  • Type:nint
TintAdjustmentMode
  • Type:UIViewTintAdjustmentMode
TintColor
  • Type:UIColor
TraitCollection
Transform
  • Type:CGAffineTransform
TranslatesAutoresizingMaskIntoConstraints
UserInteractionEnabled
ViewForBaselineLayout
  • Type:UIView
ViewPrintFormatter
Window
  • Type:UIWindow
AccessibilityCustomActions
  • Type:UIAccessibilityCustomAction[]
CanBecomeFirstResponder
CanResignFirstResponder
InputAccessoryView
  • Type:UIView
InputAccessoryViewController
  • Type:UIInputViewController
InputView
  • Type:UIView
InputViewController
IsFirstResponder
KeyCommands
  • Type:UIKeyCommand[]
NextResponder
  • Type:UIResponder
TextInputContextIdentifier
  • Type:NSString
TextInputMode
  • Type:UITextInputMode
UndoManager
  • Type:NSUndoManager
UserActivity
SuperHandle
  • Type:IntPtr
Handle
  • Type:IntPtr
Class
  • Type:Class
DebugDescription
Description
IsProxy
RetainCount
  • Type:nuint
Self
  • Type:NSObject
Superclass
  • Type:Class
Zone
  • Type:NSZone
OverlaysView
Gets the overlays view.
  • Type:UIView
IsDirectBinding
InFinalizerQueue
CurrentExtentChanging N/A
Event Arguments:CurrentExtentChangingMapViewEventArgs
CurrentExtentChanged N/A
Event Arguments:CurrentExtentChangedMapViewEventArgs
CurrentScaleChanging N/A
Event Arguments:CurrentScaleChangingMapViewEventArgs
CurrentScaleChanged N/A
Event Arguments:CurrentScaleChangedMapViewEventArgs
MapLongPress This event raises when [map long press].
Event Arguments:UIGestureRecognizer
MapSingleTap This event raises when [map single tap].
MapDoubleTap This event raises when [map double tap].
MapTouchMove This event raises when [map touch move].
MapTouchUp This event raises when [map touch up].
MapTouchDown This event raises when [map touch down].
MapTouchPinch This event raises when [map touch pinch].
thinkgeo.mapsuite.iosedition.mapview.txt · Last modified: 2017/03/16 21:59 (external edit)
