thinkgeo.mapsuite.iosedition.overlay
ThinkGeo.MapSuite.iOSEdition.Overlay
This class is the base class of all overlays in this overlay system.
Overlay()
Refresh(IEnumerable<RectangleShape>)
Refresh(TimeSpan)
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,RequestDrawingBufferTimeType)
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Refresh(RectangleShape,TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Refresh(IEnumerable<RectangleShape>,TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
RemoveAllAnimations()
GetBoundingBox()
Gets the bounding box.
  • Description:A RectangleShape value for the overlay.
Initialize(MapArguments)
Initializes the specified map arguments.
  • mapArguments
Refresh()
Refreshes this instance.
Refresh(RectangleShape)
Draw(MapArguments,OverlayRefreshType)
This method draws the overlay by the specified arguments.
  • mapArguments
    • Description:This parameter indicates an mapArguments to draw the overlay.
  • refreshType
    • Description:This parameter indicates whether this overlay needs to be refresh or not.
PostTransform(TransformArguments,MapArguments)
Posts the transform for the overlay.
  • mapArguments
Close()
Closes this instance.
Dispose()
Disposes this instance.
RemoveAllAnimationCore()
GetBoundingBoxCore()
Gets the bounding box core.
RefreshCore()
Refreshes the core.
RefreshCore(RectangleShape)
DrawCore(MapArguments,OverlayRefreshType)
  • mapArguments
  • refreshType
PostTransformCore(TransformArguments,MapArguments)
  • mapArguments
CloseCore()
Closes the core.
InitializeCore(MapArguments)
Initializes the core.
  • mapArgument
Draws the exception.
  • geoCanvas
  • exception
    • Type:Exception
    • Description:The exception.
Draws the exception core.
  • geoCanvas
  • ex
    • Type:Exception
    • Description:The ex.
OnDrawingException(DrawingExceptionOverlayEventArgs)
Handles the event.
OnDrawnException(DrawnExceptionOverlayEventArgs)
Handles the event.
Dispose(Boolean)
Releases unmanaged and - optionally - managed resources.
  • disposing
    • Description:true to release both managed and unmanaged resources; false to release only unmanaged resources.
PrepareInertialPanInternal(RectangleShape,RectangleShape,MapArguments)
PrepareInertialPan(RectangleShape,RectangleShape,MapArguments)
AutoRefreshInterval
  • Type:TimeSpan
Gets or sets the name.
DrawingExceptionMode
This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
IsVisible
Gets or sets a value indicating whether this instance is visible.
IsEmpty
Gets a value indicating whether this instance is empty.
Attribution
Gets or sets the attribution.
OverlayView
Gets or sets the overlay view.
  • Type:UIView
DrawingQuality
Gets or sets the drawing quality.
Opacity
Gets or sets the opacity.
MapArguments
Gets or sets the map arguments.
CanRefreshRegion
DrawingException This event raises when [drawing exception].
Event Arguments:DrawingExceptionOverlayEventArgs
DrawnException This event raises when [drawn exception].
Event Arguments:DrawnExceptionOverlayEventArgs
thinkgeo.mapsuite.iosedition.overlay.txt · Last modified: 2017/03/16 21:59 (external edit)
