<!– Class –> Represents an overlay object that gets images from the Yahoo Maps server.
The YahooOverlay registers Yahoo Maps' Javascript library to the page and gets the images from the Yahoo Maps server. The YahooOverlay can only be the base overlay of the map, which acts as the background layer over which other overlays are laid.
YahooOverlay | Initialize an instance of the YahooOverlay class. | ||
YahooOverlay | String | Initialize an instance of the YahooOverlay class with the overlay identifier specified. | |
YahooOverlay | String, YahooMapType | Initialize an instance of the YahooOverlay class with the overlay identifier and the Yahoo map type specified. |
MemberwiseClone | Object | ||
OnTick | EventArgs | Overlay | Raises the Tick event of the MarkerOverlay. |
RegisterJavaScriptLibraryCore | Page | Overlay(overriden) | Registers the Yahoo Maps Javascript library URL string to the client HTML page. |
AutoRefreshInterval | TimeSpan | Overlay | Gets or sets the time interval in which the MarkerOverlay refreshes itself. |
Id | String | Overlay | Gets the identifier for the overlay to be found. |
IsBaseOverlay | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is a base overlay. |
IsVisible | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
IsVisibleInOverlaySwitcher | Boolean | Overlay | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. |
JavaScriptLibraryUri | Uri | Gets or sets a URI used for loading the Yahoo Maps Javascript library. | |
Name | String | Overlay | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. |
Opacity | Single | Overlay | Gets or sets the opacity level of the overlay. |
YahooMapType | YahooMapType | Gets or sets a value that determines which type of Yahoo Map to display. |
HasTickEvent | Boolean | Overlay(overriden) | Don't support auto tick event by default. |
OverlayType | String | Overlay(overriden) | Gets a string that indicates the overlay type. |
| id | String<!– System.String –> | The identifier string used for finding the overlay. |
| yahooMapType | YahooMapType<!– ThinkGeo.MapSuite.WebEdition.YahooMapType –> | The map type of the overlay. |
Returns a JSON string which contains the information for creating an overlay at the client side.
| String<!– System.String –> | A JSON string which is used to create an overlay at the client side. |
<!– ThinkGeo.MapSuite.WebEdition.Overlay –> Go Back
| e | EventArgs<!– System.EventArgs –> | An System.EventArgs object that contains the event data. |
| page | Page<!– System.Web.UI.Page –> | The page object which contains the map. |
<!– ThinkGeo.MapSuite.WebEdition.Overlay(overriden) –> Go Back
| TimeSpan<!– System.TimeSpan –> |
| Uri<!– System.Uri –> |
<!– ThinkGeo.MapSuite.WebEdition.YahooOverlay –> Go Back
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
| Event Arguments |
NOTOC WebEdition ThinkGeo.MapSuite.WebEdition UpdateDocumentation
