thinkgeo.mapsuite.iosedition.transformarguments
ThinkGeo.MapSuite.iOSEdition.TransformArguments
Represents an arguments that transform map control.
    • ThinkGeo.MapSuite.iOSEdition.TransformArguments
TransformArguments()
TransformArguments(Single,Single,Single,RectangleShape,Single,Single)
  • x
    • Type:Single
    • Description:The x.
  • y
    • Type:Single
    • Description:The y.
  • scale
    • Type:Single
    • Description:The scale.
  • processingExtent
  • centerX
    • Type:Single
    • Description:The center x.
  • centerY
    • Type:Single
    • Description:The center y.
PostScale(Single,nfloat,nfloat)
Posts the scale of MapControl.
  • scale
    • Type:Single
  • centerX
    • Type:nfloat
  • centerY
    • Type:nfloat
PostTranslate(nfloat,nfloat)
Posts the translate of MapControl.
  • offsetX
    • Type:nfloat
    • Description:The offset x.
  • offsetY
    • Type:nfloat
    • Description:The offset y.
Reset()
Resets this instance of MapControl.
Set(TransformArguments)
Sets the specified matrix of MapControl.
CenterX
Gets or sets the center x of MapControl.
  • Type:nfloat
CenterY
Gets or sets the center y of MapControl.
  • Type:nfloat
ProcessingExtent
Gets or sets the processing extent of MapControl.
Scale
Gets or sets the scale of MapControl.
  • Type:Single
X
Gets or sets the x of MapControl.
  • Type:nfloat
Y
Gets or sets the y of MapControl.
  • Type:nfloat
Rotation
Gets or sets the rotation of MapControl.
  • Type:Single
InertiallyPan
thinkgeo.mapsuite.iosedition.transformarguments.txt · Last modified: 2017/03/16 21:59 (external edit)
