thinkgeo.mapsuite.iosedition.trackendedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.iOSEdition.TrackEndedTrackInteractiveOverlayEventArgs
      • ThinkGeo.MapSuite.iOSEdition.TrackEndedTrackInteractiveOverlayEventArgs
TrackEndedTrackInteractiveOverlayEventArgs()
TrackEndedTrackInteractiveOverlayEventArgs(BaseShape)
  • trackShape
    • Type:BaseShape
    • Description:This parameter specified the tracked shape.
TrackShape
This property gets or sets the tracked shape.
thinkgeo.mapsuite.iosedition.trackendedtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
