<!– Enumeration –> This enumeration specifies the style of dashed lines drawn with a GeoPen object.
| Name | Summary |
| Solid | Specifies a solid line. |
| Custom | Specifies a user-defined custom dash style. |
| DashDot | Specifies a line consisting of a repeating pattern of dash-dot. |
| DashDotDot | Specifies a line consisting of a repeating pattern of dash-dot-dot. |
| Dot | Specifies a line consisting of dots. |
| Dash | Specifies a line consisting of dashes. |
