thinkgeo.mapsuite.iosedition.interactionarguments
ThinkGeo.MapSuite.iOSEdition.InteractionArguments
This class encapsulates the information and simple method for interactive actions.
    • ThinkGeo.MapSuite.iOSEdition.InteractionArguments
InteractionArguments()
Constructor of InteractionArguments class.
ScreenPointers
Gets the screen pointers.
  • Type:Collection<CGPoint>
CurrentExtent
Gets or sets the current extent.
ScreenX
Gets or sets the screen x.
  • Type:nfloat
ScreenY
Gets or sets the screen y.
  • Type:nfloat
MapUnit
Gets or sets the map unit.
MapWidth
Gets or sets the width of the map.
  • Type:nfloat
MapHeight
Gets or sets the height of the map.
  • Type:nfloat
Scale
Gets or sets the scale.
CurrentResolution
Gets or sets the current resolution.
WorldX
Gets or sets the world x.
WorldY
Gets or sets the world y.
SearchingTolerance
Gets or sets the searching tolerance.
Velocity
Gets or sets the velocity.
  • Type:CGPoint
ZoomLevelSet
Gets or sets the zoom level set.
thinkgeo.mapsuite.iosedition.interactionarguments.txt · Last modified: 2017/03/16 21:59 (external edit)
