thinkgeo.mapsuite.iosedition.vertexmovingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.iOSEdition.VertexMovingEditInteractiveOverlayEventArgs
Provides data for the VertexMoving. event.
      • ThinkGeo.MapSuite.iOSEdition.VertexMovingEditInteractiveOverlayEventArgs
VertexMovingEditInteractiveOverlayEventArgs()
VertexMovingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex)
  • cancel
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • movingVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex to be moved.
VertexMovingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex,PointShape)
  • cancel
    • Description:if set to true [cancel].
    • Type:Feature
    • Description:The affected vertex feature.
  • movingVertex
    • Type:Vertex
    • Description:The moving vertex.
  • targetVertex
AffectedVertexFeature
This property gets or sets the Feature to be used to move vertex.
MovingVertex
This property gets or sets the vertex to be moved.
TargetVertex
Gets or sets the target vertex.
Cancel
thinkgeo.mapsuite.iosedition.vertexmovingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
