thinkgeo.mapsuite.iosedition.vertexremovingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.iOSEdition.VertexRemovingEditInteractiveOverlayEventArgs
Provides data for the VertexRemoving. event.
      • ThinkGeo.MapSuite.iOSEdition.VertexRemovingEditInteractiveOverlayEventArgs
VertexRemovingEditInteractiveOverlayEventArgs()
VertexRemovingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex)
  • cancel
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • removingVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex to be removed.
AffectedVertexFeature
This property gets or sets the Feature to be used to remove vertex.
RemovingVertex
This property gets or sets the vertex to be removed.
Cancel
thinkgeo.mapsuite.iosedition.vertexremovingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
