thinkgeo.mapsuite.iosedition.processotheroverlaysmode
ThinkGeo.MapSuite.iOSEdition.ProcessOtherOverlaysMode
This enumeration specifies the mode to process other overlays when doing interactive actions with InterativeOverlay.
Items
  • Summary:This enumeration item means that other overlays will still be executed.
DoNotProcessOtherOverlays
  • Summary:This enumeration item means that other overlays will be ignored.
Default
  • Summary:Default value of the enumeration, the same as ProcessOtherOverlays.
thinkgeo.mapsuite.iosedition.processotheroverlaysmode.txt · Last modified: 2017/03/16 21:59 (external edit)
