thinkgeo.mapsuite.wpfdesktopedition.trackinteractiveoverlay
ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay
This class inherits from InterativeOverlay abstract class. This specified overlay describle the TrackShape interative process with MapControl using Mouse or Keyborad.
    • ThinkGeo.MapSuite.WpfDesktopEdition.Overlay
      • ThinkGeo.MapSuite.WpfDesktopEdition.InteractiveOverlay
        • ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay
TrackInteractiveOverlay()
  • Default constructor of the class. If you use this constructor, please set the properties correctly or it will use their default values.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#TrackInteractiveOverlay.28.29
GetTrackingShape()
  • This method gets the current Tracking shape.
  • This method is the concrete wrapper for the abstract method GetTrackingShapeCore. This method draws the representation of the overlay based on the extent you provided.
  • Type:BaseShape
  • Description:Returns a shape represents the current status of tracking shape.
MouseDown(InteractionArguments)
  • This method will simulate the MouseDown interaction.
  • This method is the concrete wrapper for its virtual Core method. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • interactionArguments
MouseMove(InteractionArguments)
  • This method will simulate the MouseMove interaction.
ManipulationStarted(InteractionArguments)
ManipulationDelta(InteractionArguments)
ManipulationCompleted(InteractionArguments)
MouseUp(InteractionArguments)
  • This method will simulate the MouseUp interaction.
MouseClick(InteractionArguments)
  • This method will simulate the MouseClick interaction.
MouseDoubleClick(InteractionArguments)
  • This method will simulate the MouseDoubleClick interaction.
MouseWheel(InteractionArguments)
  • This method will simulate the MouseWheel interaction.
MouseLeave(InteractionArguments)
  • Occurs when the mouse leave the map.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#MouseLeave.28InteractionArguments.29
MouseEnter(InteractionArguments)
  • Occurs when the mouse enter the map.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#MouseEnter.28InteractionArguments.29
  • Description:A interactive result for mouse entering the map.
KeyUp(KeyEventInteractionArguments)
  • Occurs when key up on the map.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#KeyUp.28KeyEventInteractionArguments.29
KeyDown(KeyEventInteractionArguments)
  • Occurs when key down on the map.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#KeyDown.28KeyEventInteractionArguments.29
Refresh(IEnumerable<RectangleShape>)
Refresh(TimeSpan)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Refresh.28TimeSpan.29
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,RequestDrawingBufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Refresh.28RectangleShape.2C_TimeSpan.29
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Initialize(MapArguments)
  • This method initializes overlay object.
  • This is a wrapper method for the virtual method InitializeCore.
  • mapArguments
    • Description:This parameter maintains current map information for calculating mechanism.
Refresh(RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Refresh.28RectangleShape.29
Refresh()
  • This method refreshes all the content in the OverlayCanvas. For example, LayerOverlay with multiple tiles; when the style of one layer is changed, call Refresh to refresh all the tiles to accept new styles.
  • The difference from Draw() method is that Refresh() method refreshs all the elements while Draw() does not.
Close()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Close.28.29
Open()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Open.28.29
Draw(RectangleShape)
  • This method draws the overlay with the provided extent in world coordinate.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Draw.28RectangleShape.29
  • targetExtent
    • Description:This parameter indicates an extent in world coordinate for drawing the overlay.
Draw(RectangleShape,OverlayRefreshType)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Draw.28RectangleShape.2C_OverlayRefreshType.29
  • targetExtent
  • refreshType
    • Description:This parameter indicates whether the elements of this overlay needs to be refreshed. For example, TileOverlay is formed by tiles. When panning the map around, the existing tile doesn't need to be redraw, the only thing we need to do is modifying the position of these tiles. On another hand, when click to change the style of the overlay, we need to redraw the tile images to change the appearance. So we need refresh mode.
PanTo(RectangleShape)
  • This method pans the overlay to the provided world extent.
  • Some overlay doesn't need to continously drawing all the tile. For example, MarkerOverlay is formed by markers. When mouse down to pan, the markers don't need to redraw, we can only change its position. When mouse up to end panning, we can redraw the overlay for better performance.
  • targetExtent
    • Description:This parameter is the target world extent for panning.
GetBoundingBox()
  • This method gets a bounding box of the Overlay.
  • This method is the concrete wrapper for the abstract method GetBoundingBoxCore. This method returns the bounding box of the Overlay. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
  • Description:A RectangleShape indicating the bounding box of this overlay
SaveState()
  • This method saves overlay state to a byte array.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#SaveState.28.29
  • Type:Byte[]
  • Description:A byte array indicates current overlay state.
LoadState(Byte[])
  • This method restore the overlay state back from the specified state.
  • state
    • Type:Byte[]
    • Description:This parameter indicates the state for restore the overlay.
Dispose()
  • This method dispose unmanaged resource used in this class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Dispose.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#ToString.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Equals.28Object.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#GetHashCode.28.29
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#GetType.28.29
EndTracking()
  • This method ends the tracking shape by initialize some variables.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#EndTracking.28.29
MouseDownCore(InteractionArguments)
  • This overrides the MouseDown logic in its base class InterativeOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#MouseDownCore.28InteractionArguments.29
MouseMoveCore(InteractionArguments)
  • This overrides the MouseMove logic in its base class InterativeOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#MouseMoveCore.28InteractionArguments.29
MouseUpCore(InteractionArguments)
  • This overrides the MouseUp logic in its base class InterativeOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#MouseUpCore.28InteractionArguments.29
MouseClickCore(InteractionArguments)
  • This overrides the MouseClick logic in its base class.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#MouseClickCore.28InteractionArguments.29
MouseDoubleClickCore(InteractionArguments)
  • This overrides the MouseDoubleClick logic in its base class InterativeOverlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#MouseDoubleClickCore.28InteractionArguments.29
GetTrackingShapeCore()
  • This is the Core method of GetTrackingShape.You could overrides this method to have your own logic. This method gets the current Tracking shape.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#GetTrackingShapeCore.28.29
  • Type:BaseShape
OnTrackEnded(TrackEndedTrackInteractiveOverlayEventArgs)
  • This event will be fired after the end of Tracking a shape.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnTrackEnded.28TrackEndedTrackInteractiveOverlayEventArgs.29
OnTrackEnding(TrackEndingTrackInteractiveOverlayEventArgs)
  • This event will be fired before the end of Tracking a shape.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnTrackEnding.28TrackEndingTrackInteractiveOverlayEventArgs.29
OnTrackStarting(TrackStartingTrackInteractiveOverlayEventArgs)
  • This event will be fired before the start of Tracking a shape.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnTrackStarting.28TrackStartingTrackInteractiveOverlayEventArgs.29
OnTrackStarted(TrackStartedTrackInteractiveOverlayEventArgs)
  • This event will be fired after the start of Tracking a shape.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnTrackStarted.28TrackStartedTrackInteractiveOverlayEventArgs.29
OnVertexAdding(VertexAddingTrackInteractiveOverlayEventArgs)
  • This event will be fired before adding a vertex to the Tracking shape.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnVertexAdding.28VertexAddingTrackInteractiveOverlayEventArgs.29
OnVertexAdded(VertexAddedTrackInteractiveOverlayEventArgs)
  • This event will be fired after adding a vertex to the Tracking shape.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnVertexAdded.28VertexAddedTrackInteractiveOverlayEventArgs.29
OnMouseMoved(MouseMovedTrackInteractiveOverlayEventArgs)
  • This event will be fired when mouse moved a vertex to the Tracking shape.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMouseMoved.28MouseMovedTrackInteractiveOverlayEventArgs.29
ManipulationStartedCore(InteractionArguments)
ManipulationDeltaCore(InteractionArguments)
ManipulationCompletedCore(InteractionArguments)
DrawCore(RectangleShape,OverlayRefreshType)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#DrawCore.28RectangleShape.2C_OverlayRefreshType.29
DrawTileCore(GeoCanvas)
  • This methods draws tracking shapes on the map.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#DrawTileCore.28GeoCanvas.29
  • geoCanvas
    • Type:GeoCanvas
    • Description:The drawing context for drawing shapes.
SaveStateCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#SaveStateCore.28.29
  • Type:Byte[]
LoadStateCore(Byte[])
  • state
    • Type:Byte[]
Dispose(Boolean)
  • This method disposes unmanaged resourece in this object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Dispose.28Boolean.29
  • disposing
MouseWheelCore(InteractionArguments)
  • This protected virtual method is the Core method of MouseWheel API.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#MouseWheelCore.28InteractionArguments.29
MouseLeaveCore(InteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#MouseLeaveCore.28InteractionArguments.29
MouseEnterCore(InteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#MouseEnterCore.28InteractionArguments.29
KeyUpCore(KeyEventInteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#KeyUpCore.28KeyEventInteractionArguments.29
KeyDownCore(KeyEventInteractionArguments)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#KeyDownCore.28KeyEventInteractionArguments.29
OnMapMouseDown(MapMouseDownInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseDown is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseDown.28MapMouseDownInteractiveOverlayEventArgs.29
OnMapMouseMove(MapMouseMoveInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseMove is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseMove.28MapMouseMoveInteractiveOverlayEventArgs.29
OnMapMouseUp(MapMouseUpInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseUp is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseUp.28MapMouseUpInteractiveOverlayEventArgs.29
OnMapMouseClick(MapMouseClickInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseClick is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseClick.28MapMouseClickInteractiveOverlayEventArgs.29
OnMapMouseDoubleClick(MapMouseDoubleClickInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseDoubleClick is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseDoubleClick.28MapMouseDoubleClickInteractiveOverlayEventArgs.29
OnMapMouseWheel(MapMouseWheelInteractiveOverlayEventArgs)
  • This event will be fired when MapMouseWheel is called.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseWheel.28MapMouseWheelInteractiveOverlayEventArgs.29
OnMapMouseLeave(MapMouseLeaveInteractiveOverlayEventArgs)
  • Occurs when mouse leave from the map object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseLeave.28MapMouseLeaveInteractiveOverlayEventArgs.29
OnMapMouseEnter(MapMouseEnterInteractiveOverlayEventArgs)
  • Occurs when mouse enter on the map object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseEnter.28MapMouseEnterInteractiveOverlayEventArgs.29
OnMapKeyUp(MapKeyUpInteractiveOverlayEventArgs)
  • Occurs when key up on the map object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapKeyUp.28MapKeyUpInteractiveOverlayEventArgs.29
OnMapKeyDown(MapKeyDownInteractiveOverlayEventArgs)
  • Occurs when key down on the map object.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapKeyDown.28MapKeyDownInteractiveOverlayEventArgs.29
LhQ=(LayerTile)
IhQ=(RectangleShape,Double)
  • resolution
InitializeCore(MapArguments)
  • When implementing this method, consider initializing the overlay canvas such as setting its z-index, setting current map reference to the CurrentMap property.
  • mapArguments
RefreshCore(RectangleShape)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#RefreshCore.28RectangleShape.29
RefreshCore()
CloseCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#CloseCore.28.29
OpenCore()
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OpenCore.28.29
4hM=(GeoCanvas)
DrawAttributionCore(GeoCanvas)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#DrawAttributionCore.28GeoCanvas.29
OnDrawingAttribution(DrawingAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnDrawingAttribution.28DrawingAttributionOverlayEventArgs.29
OnDrawnAttribution(DrawnAttributionOverlayEventArgs)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnDrawnAttribution.28DrawnAttributionOverlayEventArgs.29
PanToCore(RectangleShape)
  • targetExtent
OnDrawing(DrawingOverlayEventArgs)
  • This method raises before the overlay is drawing.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnDrawing.28DrawingOverlayEventArgs.29
OnDrawn(DrawnOverlayEventArgs)
  • This method raises after the overlay is drawn.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnDrawn.28DrawnOverlayEventArgs.29
GetBoundingBoxCore()
  • This method returns the bounding box of the Overlay.
  • Description:This method returns the bounding box of the Overlay.
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Finalize.28.29
OnRefreshing(OverlayRefreshType)
  • For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#MemberwiseClone.28.29
IsEmpty
This property override the logic in its base class by watching the feature count in trackShapeLayer. If it is empty ,we can skip drawing it for better performance.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#IsEmpty
TrackShapeLayer
This property gets the TrackShape layers which holds the track shapes.
TrackShapesInProcessLayer
MouseDownCount
Gets and sets the the times of mouse click.
VertexCountInQuarter
PolygonTrackMode
TrackMode
Gets a mode of TrackOverlay.
The default mode is TrackMode.None which means you cannot draw or edit features. By setting the mode to TrackMode.Point, TrackMode.Line, TrackMode.Polygon etc., you could add point, line or polygon to the FeatureOverlay. Setting the mode to TrackMode.Edit, you could edit the shapes.
DrawingMarginPercentage
RenderMode
This property gets and sets the render mode for drawing this overlay.
Set GdiPlus to render map image with Gdi+. We recommend use this value with large data. Set DrawingVisual to render map image with DrawingVisual feature in WPF. Use it when the spatial data is small to get better responding.
AutoRefreshInterval
  • Type:TimeSpan
Gets or sets the name of this overaly.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#Name
MapArguments
Gets or sets current map information which will be used for calculating mechanism.
OverlayCanvas
Gets or sets the actual canvas which maintains all the visual elements on the overlay.
  • Type:Canvas
IsBase
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#IsBase
CanRefreshRegion
DrawingExceptionMode
This property gets and sets the DrawingExceptionMode used when an exception occurs during drawing.
IsVisible
Gets or sets if this overlay is visible.
Attribution
Vertices
This property gets the vertices to make up the track shape. This is a protected property which probablly need to be used in its sub classes.
PreviousExtent
Gets or sets the previous exent of the overlay.
3BM=
IsOverlayInitialized
Gets or sets if the overlay canvas is initialized.
TrackEnded This event will be fired after the end of tracking shape.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnTrackEnded.28TrackEndedTrackInteractiveOverlayEventArgs.29
Event Arguments:TrackEndedTrackInteractiveOverlayEventArgs
TrackEnding This event will be fired before the end of tracking shape.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnTrackEnding.28TrackEndingTrackInteractiveOverlayEventArgs.29
Event Arguments:TrackEndingTrackInteractiveOverlayEventArgs
TrackStarted This event will be fired after the start of tracking shape.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnTrackStarted.28TrackStartedTrackInteractiveOverlayEventArgs.29
Event Arguments:TrackStartedTrackInteractiveOverlayEventArgs
TrackStarting This event will be fired before the start of tracking shape.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnTrackStarting.28TrackStartingTrackInteractiveOverlayEventArgs.29
Event Arguments:TrackStartingTrackInteractiveOverlayEventArgs
VertexAdded This event will be fired after a vertex added to the tracking shape.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnVertexAdded.28VertexAddedTrackInteractiveOverlayEventArgs.29
Event Arguments:VertexAddedTrackInteractiveOverlayEventArgs
VertexAdding This event will be fired before a vertex added to the tracking shape.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnVertexAdding.28VertexAddingTrackInteractiveOverlayEventArgs.29
Event Arguments:VertexAddingTrackInteractiveOverlayEventArgs
MouseMoved This event will be fired when mouse moved on the vertex of tracking shape.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMouseMoved.28MouseMovedTrackInteractiveOverlayEventArgs.29
Event Arguments:MouseMovedTrackInteractiveOverlayEventArgs
MapMouseDown This event will be fired when Mouse pressed Down on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseDown.28MapMouseDownInteractiveOverlayEventArgs.29
Event Arguments:MapMouseDownInteractiveOverlayEventArgs
MapMouseMove This event will be fired when Mouse moved on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseMove.28MapMouseMoveInteractiveOverlayEventArgs.29
Event Arguments:MapMouseMoveInteractiveOverlayEventArgs
MapMouseUp This event will be fired when Mouse released up on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseUp.28MapMouseUpInteractiveOverlayEventArgs.29
Event Arguments:MapMouseUpInteractiveOverlayEventArgs
MapMouseClick This event will be fired when Mouse clicked(mouse up and mouse down in the same postion) on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseClick.28MapMouseClickInteractiveOverlayEventArgs.29
Event Arguments:MapMouseClickInteractiveOverlayEventArgs
MapMouseDoubleClick This event will be fired when Mouse double clicked on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseDoubleClick.28MapMouseDoubleClickInteractiveOverlayEventArgs.29
Event Arguments:MapMouseDoubleClickInteractiveOverlayEventArgs
MapMouseWheel This event will be fired when Mouse wheel on the Map.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseWheel.28MapMouseWheelInteractiveOverlayEventArgs.29
Event Arguments:MapMouseWheelInteractiveOverlayEventArgs
MapMouseLeave Occurs when mouse leave the map canvas.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseLeave.28MapMouseLeaveInteractiveOverlayEventArgs.29
Event Arguments:MapMouseLeaveInteractiveOverlayEventArgs
MapMouseEnter Occurs when mouse enter the map canvas.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapMouseEnter.28MapMouseEnterInteractiveOverlayEventArgs.29
Event Arguments:MapMouseEnterInteractiveOverlayEventArgs
MapKeyDown Occurs when key down on the map canvas.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapKeyDown.28MapKeyDownInteractiveOverlayEventArgs.29
Event Arguments:MapKeyDownInteractiveOverlayEventArgs
MapKeyUp Occurs when key up on the map canvas.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnMapKeyUp.28MapKeyUpInteractiveOverlayEventArgs.29
Event Arguments:MapKeyUpInteractiveOverlayEventArgs
Drawing This event raises before the overlay is drawing.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnDrawing.28DrawingOverlayEventArgs.29
Event Arguments:DrawingOverlayEventArgs
Drawn This event raises after the overlay is drawn.
For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackInteractiveOverlay#OnDrawn.28DrawnOverlayEventArgs.29
Event Arguments:DrawnOverlayEventArgs
DrawingAttribution N/A
thinkgeo.mapsuite.wpfdesktopedition.trackinteractiveoverlay.1442912225.txt.gz · Last modified: 2015/09/22 08:57 by admin
