<!– NamespacePage –> <!– MapSuiteFormsEdition –>
| Name | Summary |
| AdornmentOverlayAdapter | |
| BingMapsOverlayAdapter | This class represents an BingMapsTileOverlay's adapter. |
| CenterCoordinateMapToolApater | The adapter represents the coordinates of the map center, display in the lower right corner of the map. |
| EditInteractiveOverlayAdapter | This class inherits from InterativeOverlay abstract class. This specified overlay describle the EditShape interative process with MapControl using Mouse or Keyborad. |
| GoogleMapsOverlayAdapter | This class represents the GoogleMapsOverlay's adapter which requests images from Google's image server by its StaticAPI. |
| GpsMarkerAdapter | |
| LayerOverlayAdapter | This class represents a group of layers; each layer can be of any layer type. |
| MapElementAdapter | This class represents the MapElementAdapter. |
| MapToolAdapter | This class represents the base class maptool adapter. |
| MapToolsAdapter | The Aadpter contains the different map tools as properties and acts as an entrance for setting these map controls. |
| MapViewAdapter | Class MapViewAdapter. |
| MarkerAdapter | Represents a marker control on the map. |
| MarkerOverlayAdapter | This class represents an overlay which maintaining markers. |
| OpenStreetMapOverlayAdapter | This class represents an overlay that requesting images from OpenStreet Map Service. |
| OverlayAdapter | This class is the base class of all overlay adapters in this overlay adapter system. |
| PopupAdapter | This class represents a popup control for placing on the map. |
| PopupOverlayAdapter | This class represents an overlay to place popups on the map. |
| TileOverlayAdapter | |
| TrackInteractiveOverlayAdapter | This class inherits from InterativeOverlay abstract class. This specified overlay describle the TrackShape interative process with MapControl using Mouse or Keyborad. |
| WmsOverlayAdapter | Represents an overlay object that gets map images from the WMS server you specify. |
| WorldMapKitOverlayAdapter | This class represents an WmsOverlay which has MapSuite world map kit server integrated. |
| ZoomMapToolAdapter | Represents the zooming panel in the upper left corner of the map. |
| Name | Summary |
| Name | Summary |
| Name | Summary |
| IMapElementAdaptable | This class represents the interface IMapElementAdaptable |
<!– MapSuiteFormsEdition –> Note: * – not public released, might be removed in the next release. MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition.Adapters UpdateDocumentation
