thinkgeo.mapsuite.windowsphonecore.positionstyle
Table of Contents
ThinkGeo.MapSuite.WindowsPhoneCore.PositionStyle
<!– Class –> This abstract class encapsulates the labeling position logic. It is inherited by other styles, such as the TextSytle.
This abstract class is meant to be inherited by other classes and specialized to meet the needs of various labelers.
Protected MethodPositionStyle This is the default constructor for the class.
Public MethodDraw IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style This method draws the shapes on the canvas you provided.
Public MethodDraw IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style This method draws the features on the canvas you provided.
Public MethodDrawSample GeoCanvas, DrawingRectangleF Style
Public MethodGetRequiredColumnNames Style This method returns the column data for each feature that is required for the style to properly draw.
Public MethodGetType Object
Public MethodToString Object
Protected MethodCheckDuplicate LabelingCandidate, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> This method will determine whether the label will be suppressed because it is a duplicate.
Protected MethodCheckDuplicateCore LabelingCandidate, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> This method will determine if the label will be suppressed because it is a duplicate.
Protected MethodCheckOverlapping LabelingCandidate, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> This method will determine if the label will be suppressed because of overlapping.
Protected MethodCheckOverlappingCore LabelingCandidate, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> This method will determine whether the label will be suppressed because of overlapping.
Protected MethodStatic MemberConvertToScreenShape Feature, GeoCanvas This method converts a feature in world coordinates to screen coordinates.
Protected MethodDrawCore IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate> Style(overriden) This method draws the features on the canvas you provided.
Protected MethodDrawSampleCore GeoCanvas, DrawingRectangleF Style
Protected MethodFilterFeaturesCore IEnumerable<Feature>, GeoCanvas This method filters the features based on the grid size to facilitate deterministic labeling.
Protected MethodGetLabelingCandidateCore Feature, GeoCanvas This method determines whether the specified feature is a good candidate to be labeled, based on the labeling properties set.
Protected MethodGetLabelingCandidates Feature, GeoCanvas This method determines whether the specified feature is a good candidate to be labeled, based on the labeling properties set.
Protected MethodGetRequiredColumnNamesCore Style(overriden) This method returns the column data for each feature that is required for the style to properly draw.
Public PropertyIsActive Boolean Style This property gets and sets the active status of the style.
Public PropertyName String Style This property gets and set the name of the style.
Public PropertyRequiredColumnNames Collection<String> Style This property gets the collection of fields that are required for the style.
Protected PropertyAdvanced TextStyleAdvanced This property gets the advanced properties of the class.
Protected PropertyAllowLineCarriage Boolean This property gets and sets whether the labeler will allow carriage returns to be inserted.
Protected PropertyAllowSpline Boolean This property gets and sets whether line labels are allowed to spline around curved lines.
Protected PropertyBestPlacement Boolean This property gets and sets whether the labeler will attempt to change the label position to avoid overlapping for point-based features.
Protected PropertyCustomTextStyles Collection<TextStyle> This property returns a collection of area styles, allowing you to stack multiple area styles on top of each other.
Protected PropertyDateFormat String This property gets and sets the format that will be applied to the text which can be parsed to DateTime type.
Protected PropertyDrawingLevel DrawingLevel Gets or sets the DrawingLavel for this style.
Protected PropertyDuplicateRule LabelDuplicateRule This property gets and sets the rule that determines how duplicate labels are handled.
Protected PropertyFittingLineInScreen Boolean This property gets and sets whether the labeler will try to fit the label as best as it can on the visible part of a line on the screen.
Protected PropertyFittingPolygon Boolean This property gets and sets whether the labeler will try to fit the label as best as it can within the boundary of a polygon.
Protected PropertyFittingPolygonFactor Double This property gets and sets the factor to which it will keep the label inside of the polygon.
Protected PropertyFont GeoFont This property gets and sets the font that will be used to draw the text.
Protected PropertyForceHorizontalLabelForLine Boolean This property gets and sets whether we should force horizontal labeling for lines.
Protected PropertyForceLineCarriage Boolean This property gets and sets whether the labeler will force carriage returns to be inserted.
Protected PropertyFormat String This property gets and sets the format that will be applied to the text.
Protected PropertyGridSize Int32 This property gets and sets the grid size used for deterministic labeling.
Protected PropertyHaloPen GeoPen This property gets and sets the halo pen you may use to draw a halo around the text.
Protected PropertyLabelAllLineParts Boolean This property gets and sets whether the labeler will label every part of a multi-part line.
Protected PropertyLabelAllPolygonParts Boolean This property gets and sets whether the labeler will label every part of a multi-part polygon.
Protected PropertyLabelPositions Dictionary<String,WorldLabelingCandidate> Gets a value represents a keyValuepair which is a feature id and label position of the feature
Protected PropertyMask AreaStyle This property gets and sets the AreaStyle used to draw a mask behind the text.
Protected PropertyMaskMargin Int32 This property gets and sets the margin around the text that will be used for the mask.
Protected PropertyNumericFormat String This property gets and sets the format that will be applied to the text which can be parsed to double type.
Protected PropertyOverlappingRule LabelOverlappingRule This property gets and sets the rule that determines how overlapping labels are handled.
Protected PropertyPointPlacement PointPlacement This property gets and sets the location of the label for point features relative to the point.
Protected PropertyPolygonLabelingLocationMode PolygonLabelingLocationMode This property gets and sets the mode that determines how to locate polygon's labeling
Protected PropertyRotationAngle Double This property gets and sets the rotation angle of the item being positioned.
Protected PropertySplineType SplineType Gets or sets the SplineType for labeling.
Protected PropertySuppressPartialLabels Boolean This property gets and sets whether a partial label in the current extent will be drawn or not.
Protected PropertyTextColumnName String This property gets and sets the column name in the data that you want to get the text from.
Protected PropertyTextFormat String This property gets and sets the format that will be applied to the text.
Protected PropertyTextLineSegmentRatio Double This property gets and sets the ratio required for the label length to match the line length.
Protected PropertyTextSolidBrush GeoSolidBrush This property gets and sets the SolidBrush that will be used to draw the text.
Protected PropertyXOffsetInPixel Single This property gets and sets the X pixel offset used for drawing each feature.
Protected PropertyYOffsetInPixel Single This property gets and sets the Y pixel offset used for drawing each feature.
PositionStyle()
Name Type Description
Go Back
Draw(IEnumerable<BaseShape>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
Return Type Description
Void<!– System.Void –>
shapes IEnumerable<BaseShape><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape} –> This parameter represents the shapes you want to draw on the canvas.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter represents the canvas you want to draw the shapes on.
labelsInThisLayer Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> The labels will be drawn in the current layer only.
labelsInAllLayers Collection<SimpleCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.SimpleCandidate} –> The labels will be drawn in all layers.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Style –> Go Back
Draw(IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
features IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> This parameter represents the features you want to draw on the canvas.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter represents the canvas you want to draw the features on.
DrawSample(GeoCanvas, DrawingRectangleF)
drawingExtent DrawingRectangleF<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingRectangleF –>
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
GetRequiredColumnNames()
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> This method returns a collection of column names that the style needs.
Type<!– System.Type –>
String<!– System.String –>
CheckDuplicate(LabelingCandidate, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
This method is the concrete wrapper for the abstract method CheckDuplicateCore. This method will determine if the label will be suppressed because it is a duplicate. It also takes into consideration the duplicate rules for the class. So, for example, if we set to allow duplicates, then the method will always return false. If the class is set to not allow duplicates and this label is a duplicate, then it will return true and be suppressed.
Boolean<!– System.Boolean –> This method returns whether the label will be suppressed as a duplicate.
labelingCandidate LabelingCandidate<!– ThinkGeo.MapSuite.WindowsPhoneCore.LabelingCandidate –> This parameter is the labeling candidate that will be checked to determine if it is a duplicate.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter is the canvas used for calculations.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.PositionStyle –> Go Back
CheckDuplicateCore(LabelingCandidate, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
This overridden method is called from the concrete public method CheckDuplicate. This method will determine if the label will be suppressed because it is a duplicate. It also takes into consideration the duplicate rules for the class. So, for example, if we set to allow duplicates, then the method will always return false. If the class is set to not allow duplicates and this label is a duplicate, then it will return true and be suppressed.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter is the canvas that will be used for calculations.
CheckOverlapping(LabelingCandidate, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
This method is the concrete wrapper for the abstract method CheckOverlappingCore. This method will determine if the label will be suppressed because it is overlapping another label. It also takes into consideration the overlapping rules for the class. So, for example, if we set to allow overlap, then the method will always return false. If the class is set to not allow overlap and this label is overlapping, then it will return true and be suppressed.
Boolean<!– System.Boolean –> This method returns whether the label will be suppressed because of overlapping.
labelingCandidate LabelingCandidate<!– ThinkGeo.MapSuite.WindowsPhoneCore.LabelingCandidate –> This parameter is the labeling candidate that will be checked to determine if it is overlapping.
CheckOverlappingCore(LabelingCandidate, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
This overridden method is called from the concrete public method CheckOverlapping. This method will determine if the label will be suppressed because it is overlapping another label. It also takes into consideration the overlapping rules for the class. So, for example, if we set to allow overlap, then the method will always return false. If the class is set to not allow overlap and this label is overlapping, then it will return true and be suppressed.
ConvertToScreenShape(Feature, GeoCanvas)
<!– static –> This method converts a feature in world coordinates to screen coordinates.
This overridden method can be called by this class and its sub concrete classes. In this method, we take the canvas and the feature in world coordinates and convert it to screen coordinates.
BaseShape<!– ThinkGeo.MapSuite.WindowsPhoneCore.BaseShape –> A screen coordinate shape.
feature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the feature to be converted from world coordinates.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter is the canvas that will be used to convert the world coordinate feature to a screen coorindate feature.
DrawCore(IEnumerable<Feature>, GeoCanvas, Collection<SimpleCandidate>, Collection<SimpleCandidate>)
This overridden method is called from the concrete public method Draw. In this method, we take the features you passed in and draw them on the canvas you provided. Each style (based on its properties) may draw each feature differently.
When overriding this method, consider each feature and its column data values. You can use the full power of the GeoCanvas to do the drawing. If you need column data for a feature, be sure to override the GetRequiredColumnNamesCore and add the columns you need to the collection. In many of the styles, we add properties to allow the user to specify which field they need; then, in the GetRequiredColumnNamesCore, we read that property and add it to the collection.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.Style(overriden) –> Go Back
DrawSampleCore(GeoCanvas, DrawingRectangleF)
FilterFeaturesCore(IEnumerable<Feature>, GeoCanvas)
This overridden method is called from the concrete public method FilterFeatures. In this method, we filter the features based on the grid size to facilitate deterministic labeling.
Collection<Feature><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> This method returns the features that will be considered for labeling.
features IEnumerable<Feature><!– System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.WindowsPhoneCore.Feature} –> This parameter represents the features that will be filtered.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter is the canvas that will be used for calculating font sizes.
GetLabelingCandidateCore(Feature, GeoCanvas)
This overridden method is called from the concrete public method GetLabelingCanidate. In this method, we take the feature you passed in and determine if it is a candidate for labeling. If it is, then we will add it to the return collection. The algorithm to determine whether the label will draw is complex and determined by a number of properties and factors.
Collection<LabelingCandidate><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.LabelingCandidate} –> A collection of labeling candidates.
feature Feature<!– ThinkGeo.MapSuite.WindowsPhoneCore.Feature –> This parameter is the feature that will be considered as a labeling candidate.
canvas GeoCanvas<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoCanvas –> This parameter is the canvas that will be used to draw the feature. This method will not draw on this canvas, but rather will use it to determine font size, etc.
GetLabelingCandidates(Feature, GeoCanvas)
This method is the concrete wrapper for the abstract method GetLabelingCanidatesCore. This method determines if the feature passed in is a good candidate to be labeled based on the labeling properties set.
GetRequiredColumnNamesCore()
This abstract method is called from the concrete public method GetRequiredFieldNames. In this method, we return the column names that are required for the style to draw the feature properly. For example, if you have a style that colors areas blue when a certain column value is over 100, then you need to be sure you include that column name. This will ensure that the column data is returned to you in the feature when it is ready to draw.
Collection<String><!– System.Collections.ObjectModel.Collection{System.String} –> This method returns a collection of the column names that it needs.
IsActive
Return Type
Return Type
RequiredColumnNames
Return Type
Advanced
The advanced properties have been consolidated in the Advanced property. This way, the standard options are more easily visible and the advanced options are hidden away.
Return Type
TextStyleAdvanced<!– ThinkGeo.MapSuite.WindowsPhoneCore.TextStyleAdvanced –>
AllowLineCarriage
This property enables the labeler to split long labels into multiple lines if need be. For instance, if you have a lake whose name is “Southern Homestead Lake,” then the labeler may try and break the name onto multiple lines in order to better label the feature.
Return Type
AllowSpline
This property will allow the labeler to spline the label around curved lines. This is useful for curved streets that need to be labeled. This can have a considerable performance impact, so we suggest you experiment with it to ensure it can meet your needs.
Return Type
BestPlacement
The positioning of point labels is mainly determined by the PointPlacement property. This allows you place the text to the right, top, bottom, etc. of the point. In some cases, placing the text in a certain place will cause many labels to be suppressed when the points are dense. This property allows you to override the PointPlacement property and allow the labeler to try other locations, if the default location would cause the label to be suppressed.
Return Type
CustomTextStyles
Using this collection you can stack multiple area styles on top of each other. When we draw the feature we will draw them in order in the collection. You can use these stacks to create drop shadow effects along with multiple colored outlines etc.
Return Type
Collection<TextStyle><!– System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.WindowsPhoneCore.TextStyle} –>
DateFormat
With this property, you can apply formats to the text that is retrieved from the feature.
Return Type
DrawingLevel
Return Type
DrawingLevel<!– ThinkGeo.MapSuite.WindowsPhoneCore.DrawingLevel –>
DuplicateRule
There are three ways to handle duplicate label names. The first is to suppress all duplicates, which means if there are two street segments with the same name then only one will be drawn. The second way is to suppress duplicate labels only if they are in one quarter of the screen. In this way, the screen will be divided into four quadrants, and if the two duplicate labels are in different quadrants, then they will both draw. The last way is to draw all duplicates.
Return Type
LabelDuplicateRule<!– ThinkGeo.MapSuite.WindowsPhoneCore.LabelDuplicateRule –>
FittingLineInScreen
A label will normally be displayed in the center of a line. If only a small piece of the line is visible on the screen, we cannot see it's label by default. If we set this property to ture though, the label will be displayed in the center of that piece in screen.
Return Type
FittingPolygon
Return Type
Return Type
Double<!– System.Double –>
Font
Return Type
GeoFont<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoFont –>
Normally, lines are labeled in the direction of the line. There may be some cases, however, when you want to have the line labeled horizontally regardless of the line's direction. In such a case, you can set this property to force the lines to be labeled horizontally.
Return Type
ForceLineCarriage
This property forces the labeler to split long labels into multiple lines. For instance, if you have a lake whose name is “Southern Homestead Lake,” then the labeler will break the name onto multiple lines in order to better label the feature.
Return Type
Format
Return Type
GridSize
The grid size determines how many labels will be considered as candidates for drawing. The smaller the grid size, the higher the density of candidates. Making the grid size too small may have a performance impact.
Return Type
HaloPen
The halo pen allows you to draw a halo effect around the text, making it stand out more on a busy background.
Return Type
GeoPen<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoPen –>
LabelAllLineParts
In some cases, you may want to label all of the parts of a multi-part line, while in other cases you may not.
Return Type
In some cases, you may want to label all of the parts of a multi-part polygon, while in other cases you may not. For example, you may have a series of lakes where you do want to label each polygon. In another case, you may have a country with many small islands and in this case you only want to label the largest polygon.
Return Type
LabelPositions
Return Type
Dictionary<String,WorldLabelingCandidate><!– System.Collections.Generic.Dictionary{System.String,ThinkGeo.MapSuite.WindowsPhoneCore.WorldLabelingCandidate} –>
Mask
A mask is a plate behind the text that is rectangular and slightly larger than the width and height of the text. It allows the label to stand out well on a busy background. You can also try the HaloPen property instead of the mask, if the mask effect is too pronounced.
Return Type
AreaStyle<!– ThinkGeo.MapSuite.WindowsPhoneCore.AreaStyle –>
MaskMargin
This determines how much larger the mask is than the text, in pixels.
Return Type
NumericFormat
Return Type
OverlappingRule
This defines the rules for label overlapping. Currently, either we allow overlapping or we do not. In the future, we may extend this to allow some percentage of partial overlapping.
Return Type
LabelOverlappingRule<!– ThinkGeo.MapSuite.WindowsPhoneCore.LabelOverlappingRule –>
PointPlacement
This property allows you to choose where the labels are created relative to the point. For example, you can set the property to RightCenter, which would ensure that all labels are placed to the right of and vertically centered with the point. Different kinds of point layers can be positioned differently. If the point layer is dense and position is not a main concern, then you can try the BestPlacement property. That property overrides this property and tries to fit the label in the best location so that the minimum number of labels are suppressed due to overlapping issues.
Return Type
PointPlacement<!– ThinkGeo.MapSuite.WindowsPhoneCore.PointPlacement –>
There are two ways to handle polygon's labeling location. The first is to use polygon's centroid as the labeling location, the second way is to use polygon's boungdingbox center as the labeling location.
Return Type
PolygonLabelingLocationMode<!– ThinkGeo.MapSuite.WindowsPhoneCore.PolygonLabelingLocationMode –>
RotationAngle
Return Type
SplineType
Return Type
SplineType<!– ThinkGeo.MapSuite.WindowsPhoneCore.SplineType –>
This property provides a solution to the “cut off” label issue in Map Suite Web Edition and Desktop Edition, which occurs when multiple tiles exist. When you set this property to true, any labels outside of the current extent will not be drawn.
Return Type
TextColumnName
This property is used when retrieving text from a feature. You will want to specify the name of the column that contains the text you want to draw.
Return Type
TextFormat
Return Type
This allows you to suppress labels where the label length would greatly exceed the line length. For example, if you set the ratio to 1, then the label will be suppressed if it is longer than the line. If the ratio is lower, then the label would need to be shorter than the line. If higher, then the label is allowed to run past the length of the line. This allows you to control the look of things like road labeling.
Return Type
TextSolidBrush
You can use this property to draw a solid color; however, if you need to use other brushes, you can access them through the Advanced property of this class.
Return Type
GeoSolidBrush<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoSolidBrush –>
XOffsetInPixel
This property allows you to specify an X offset. When combined with a Y offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
Return Type
Single<!– System.Single –>
YOffsetInPixel
This property allows you to specify a Y offset. When combined with an X offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
Return Type
thinkgeo.mapsuite.windowsphonecore.positionstyle.txt · Last modified: 2017/03/16 21:59 (external edit)
