<!– Enumeration –> This enumeration represents the spline type for labeling.
| Name | Summary |
| Default | Default SplineType provided in PositionStyle. |
| None | This SplineType will label the text in a line type without any spling effects, this kinds of type will gain better performance compare to StandardSplining. |
| StandardSplining | This SplineType will label the text in a standard Spline way, it will have much better outlook in some situations while it will lose slightly some performance. |
| ForceSplining | This SplineType will force the labe text using Spline way, otherwise the label won't display.Usually it is just used for Asian languages like Chinese or Japanese. |
