<!– Class –> This class defines a GeoBrush of a single color. Brushes are used to fill area shapes on a GeoCanvas.
*System.Object ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush *ThinkGeo.MapSuite.WindowsPhoneCore.GeoSolidBrush
GeoSolidBrush | This is the constructor used to create a new GeoSolidBrush. | ||
GeoSolidBrush | GeoColor | This is the constructor used to create a new GeoSolidBrush. |
This constructor creates a GeoSolidBrush in the color black.
This constructor creates a GeoSolidBrush by passing in a GeoColor.
| color | GeoColor<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoColor –> | This parameter represent the color of the GeoSolidBrush. |
This property gets or sets the color of the GeoSolidBrush.
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoSolidBrush –> Go Back
The id of the GeoBrush. This is always used as a key when in the cached brushes.
| Int64<!– System.Int64 –> |
<!– ThinkGeo.MapSuite.WindowsPhoneCore.GeoBrush –> Go Back
